JES_LS said:Yeah Motts, Ford wants way too much for their standard flywheel and a lightweight version would help.
Hey Noah, I have been in the part fiche for the lincolns and on torries site.
The LS uses a common reservoir for the hydraulic fluid, so we will need to get a new reservior and a clutch master cylinder. Still trying to get some info on the hose to the slave cylinder on the LS. If it nothing more than a flare or banjo fitting on both ends,I will just make up a SS Braided hose assembly for our cars, Any one interested in that?
JES_LS said:Gee I just have to send my last street project off to a new home so there is room to thrash (and cash for small stuff).
Ebay is my home for the next few weeks.
As for the flywheel, I was not looking for a very light flywheel, just one with more centered mass. Aluminum flywheels with steel facing tend to way a little less than the factory, but the reduced moment of inertia is much greater.
wheelspin is not an issue then, the car will more likely bog if you try to let the clutch out to fast (we are not talking about an extreme overabundance of torque here).
Probably not. IIRC, the only non-Mazda that shares the bolt pattern of the 3.0/3.2 SHO V6 is the old pushrod 4.0 V6 they used in the Ranger. Doing a transaxle swap isn't like a tranny swap; the bellhousing is an integral part of the transaxle case, so you can't go have a custom bellhousing made unless you're willing to shell out big bucks to a pro who can cut and weld and maintain the structural integrity of the unit.bigdog1279 said:what do you think of swapping out a tranny in a 95 continental im doing other mods to it but would love to get into manual somthing with a 5 speed was thinking that a Sho TranMission Might Work From A Tarus SHO what do you guys think
SoonerLS said:Probably not. IIRC, the only non-Mazda that shares the bolt pattern of the 3.0/3.2 SHO V6 is the old pushrod 4.0 V6 they used in the Ranger. Doing a transaxle swap isn't like a tranny swap; the bellhousing is an integral part of the transaxle case, so you can't go have a custom bellhousing made unless you're willing to shell out big bucks to a pro who can cut and weld and maintain the structural integrity of the unit.
You might be able to swap in the entire Yamahammer drivetrain from a '95; they made some changes to the suspension of the '95 to increase the parts compatibility with the Conti in preparation for the '96 Taurus. (One of the cheap and easy upgrades to the '95s was to buy the Conti parts to upgrade the brakes to the '96 SHO size.)
MTXSHO93 said:What's the status on this swap? I came here looking for info on a V8/manual trans swap and found this thread. I'm also in S. Jersey and I'm always up for meeting other gear heads.
re: Al flywheel. If you find that its an issue you can also have a lightened steel FW made up. Although I have no experience with your engine, I do not suspect that an Al FW will be much of a problem. I'll be using one in a smaller displacement motor when I start my own swap in a month (3.2L)
Ian
93 SHO 5 speed
