JES_LS
I quess I wouldn't know anything after driving around for 11 yrs in two different four cylinder mustangs (88 & 91) that both had 11lb aluminum flywheels (down from the factory 19lbs). I put several hundred thousand miles on the two of them. While it is true that the needed to be slipped a little to get them out of the hole, the free reving of the motor when under way more than made up for that.2001LS8Sport said:I'm here to tell you that unless you have a very deep 1st gear tranny, you are going to hate life if you use an aluminum flywheel in a heavy car with no more torque than you will have. The car just won't drive away from a light. You are going to have to rev the engine and slip the clutch. Watch Cup cars leave the pits on super speedways. They are geared tall and use light clutches and flywheels. They have a heck of a time leaving without killing the engine. Same principle. But they need the lighter reciprocating components to make every available horsepower to the wheels...not spinning a clutch and flywheel. It also gives them better control into a corner if necessary.
Its not all that hard to learn how 'launch' the car when you have limited torque.
By the way guy's I'm still trying to unload the old 88 stang so I have time and money for the swap.
