I meant valve cover bolt in my original response. I never broke any intake bolts... I messed up when replying Joegr my bad lol.. I just realized I messed up when I looked up the part number
Quote Joe:
"Just a note for all of you that keep saying to "cycle" the DCCV by changing the temperature from hot to cold and back. The DCCV cycles quite a bit if you aren't always at full heat."
I was just going by other threads I recently read while researching the DCCV. You probably know which ones. The thought was that the solenoids were sticking,,, and that cycling the temp contols seemed to get the solenoids to work better/properly. Didn't mean to give misinformation.
Well better off being a cheap guy and working around things on this car. Suggestion to anyone taking off the intake don't do it. Take off the throttle body..cut off the 2 bolts on the elbow and buy 2 new ones. **** this car and it's dumb ass parts. Bolt one on the intake comes off fine. Bolt number 2 in the back..kinda tight but comes out..lucky number 3 nope! Breaks off way down where the threads first start. Needless to stay kinda screwed. No clue what to do but put it back together at this point and hope the degas bottle was the problem. Either that or a **** ton of work.
Something that made it easier and remover the throttle body. We took off the hood. Then we remover all the molding around the windshield. This allows space to get on top of the bolts. Its very hard to work begind the motor with the hood on and the windshield molding and what else is attached.. I need a IAc and I will take off the hood and windshield moldings including wipers.
Ya, I was looking for the edit . no see any? Yes, Taking hood off won't cause any damage with 2 guys and 2 wrenches. I placed mine on cushions on car's roof No damage when re installed. Its also allows axcess to the big allen bolt holding down the air filter . Lighting is bright compaired to having hood on car.Sorry I meant And* thanks. I can't edit or else I can't see where to edit.
...Forgot to ask if I need a gasket or something when I take off the throttle body? Looks like 3 bolts and it separates from the intake..they look rusty but I'll test my luck...
It's four bolts.
You mean the throttle body adapter (with the throttle body still attached), and not just the throttle body, correct? Anyway, there is a rubber gasket between the manifold and the adapter. I don't think that Ford makes it anymore, but it seems to be available from the aftermarket. Anyway, it seems to be very reusable. I haven't replaced one yet. The gasket between the throttle body and adapter (you shouldn't need to do this) is less robust. It is available from Ford and the aftermarket.
Be very careful with the bolts when putting it back together, easy to cross-thread.
Didn't think about taking the hood off..I had the wiper cowl and wipers off because I had changed the degas bottle earlier. I could get in there with a little bit a of struggle but the bolt was very rusty down where it broke. It's holding up so far although I haven't drove the car lately due to it overheating again. Now I'm going to change the elbow and thermostat housing.
No thanks for the bolt info Joe I'll pick 2 up in the morning.
No it's a broken down almost flush a little less so it won't be easy if I have to go the route. ...
Wait, if you never removed the intake, how do you know that the bolt is flush with the head? Are you sure that it's not just nearly flush with the intake? If so, that you leave a lot of bolt exposed when you remove the intake.
