I have a 01 LS Sprot w/~ 98k on it. Recently replaced all the plugs, coils, etc.
Occassionally I've had the check engine light on my car come on. I had associated this with the gasoline being used (on the occassions it occured I had just filled up the car. Adding STP Injector cleaner resolved the issue). Per recommendations from this forum I brought the car to the dealer to check out the code. What came back was "Road tested self tested P0133 P0735 Daig P0133 Bank 1 Up stream EGO Sensor slow respone needs new EGO" When I asked how much it would be to replace the oxygen sensor the said $400. Now it's been a while since I replaced an O2 sensor but the $400 seemed a little bit too much.
Is there anyone who can offer advice on the cost on a new sensor and the difficulty to replace an new sensor?
Also, coincidently, as I was bring in the car to be checked, the "check transimmision" light came on for the first time ever. So I had them check that. The diagnosis there was " DIAG P0735 Trans5 Gear Code Trans will need to be overhauled in the future'.
Any advise/experience on that one?
BTW, to had the dianosis performed costs $137.72...hence my skeptisim on "dealer repair" shops.
I think this is a great forum with some pretty good mechanic types. Any advice would be apprecited.
jd
jd
