does anyone have a heater hose diagram for an 01 ls v8 coolant is pissing out from a hose somewhere on top of the bell housing if it helps the coolant is not making it to the heater core tried to search but no luck
here is the diagram. there is a nipple coming off the backside of the block (just under the coolant tree) that feeds a hose under the intake and to the throttlebody,
you remove the bolts holding in the tank and try to remove it - that hose is connected to another about mid-car under the plastic cowl. if you disconnect the two hoses you can pull that hose through with the degas tank. then simply replace it and snake it back into place and reconnect.
