dannyquest
lol... nice pedals.
Gota ya.
Gota ya.
Finally!
Ok, I actually had some free time tonight to finish this sucker up. I'm glad to report that everything works as it did except for one exception, the shifter indicator lights on the console are not working. Must be a plug I forgot.
After taking the car out for a test drive, which was so nice to be back in, on the way home I hear a metalic 'tap-tap-tap' from the back of the car. I pull into the drive to find a sizable bolt in the tread of the drivers side rear tire.I guess I'll get that plugged.
Oh, I will do a quickie write up on this if you guys want and all I can say is that I way over did it on tearing the car apart. In not doing it before I had no idea, but lets just say I didn't have to disassemble as much as I did. Oh well.Now, time to get the A/C charged and this thing cleaned up!! :steering
...Why they put the expansion valve inside the firewall while most have it in the engine bay is beyond stupid imo
Well... a few years later and I’m in the process of removing my dash to replace the expansion valve and core.
Quick question if someone can answer, can I remove the steering column from the shaft inside the car? There appears to be a 12mm bolt on a sleeve by the firewall. De-Markolooks to have pulled the shaft from the rack in the engine bay.
Got the dash out, but have a question.
It’s hard to tell at this point. Is the heater core coming out with everything (expansion valve and evaporator)requiring me to drain the antifreeze and go through the fill and purge process?
Fortunately, almost all of the fasteners are 7 or 8 mm and few 12mm thrown in to keep it interesting.
The heater core should be the thing with the three large metal tubes running to the firewall. It should be closest to you, and the AC evaporator should be between it and the firewall.
I am wondering how long do you think the r&r take? I am looking
for a defrost mode door issue.
Thanks
Anyone know the exact location of the engine bay bolts for the core? This part is almost as difficult as the dash with the tight space in the engine compartment. I want to make sure I’m removing the right fasteners.
No.
Try to start it again, and this time wait for the PATS light to slow down (takes a little while). When it does, it will flash out a two digit code a few times. What code does it flash out?
No.
