joespanova
The outlet ports to the heater core are controlled by solenoids. The core return port to engine is T'd into line that is also return from degas bottle. I'm considering bypassing aluminum supply lines to core with rubber heater hose and manual cutoffs. I'm over replacing the DCCV any more. Since the solenoids only control 2 lines to core , what's to stop the return from back feeding hot water into core? Seems like if this was an issue the functioning solenoids would do no better than manual cutoffs and hot water would still back feed into the core?
