Bluesman73
So that brings me to my next question: What combinations have brought the highest torque curves in the dyno pulls and still be a reliable, streetable engine? N/A of course.
Bluesman73 said:So that brings me to my next question: What combinations have brought the highest torque curves in the dyno pulls and still be a reliable, streetable engine? N/A of course.
Dr. Paul said:A car that has only maybe 350 rwhp, but a real nice long, flat torque curve is going to be absolute blast to drive, and will annhilate 99.9% of what you're going to encounter on the street - from Mustangs to Camaro, and vettes and maybe even the occasional Viper since he will probably spin the tires into next week.
EconomySpeedNStyle said:Engine technical-babble aside, you'll actually get a bunch of "free" rear wheel horsepower by using the proper transmission.... i.e. a stick shift.
I think a manual trans absorbs something like 10-15 percent of the flywheel horsepower that reaches the axle.
An automatic gobbles up as much as 30% of that energy due to all the slipping, and fluids sloshing around in the case.
So, you'll actually waste a ton of money by sticking with the automatic.
Example: You'd need 460 flywheel horsepower running through a manual transmission to get 400 horses to the wheels.
400hp times 1.15 (115%) = 460 hp at the crank.
You'd need 520hp going through an automatic for the same 400 rear wheel hp.
400hp times 1.30 (130%) = 520hp at the crank.
I'm not saying that getting 460hp out of a 4.6L engine is easier, but certainly it's more attainable than 520hp! Plus, you don't have to "beef up" a Tremec or TKO and hope it's going to hold up to that kind of punishment.
My 2 cents.
EconomySpeedNStyle said:You're right...
I don't know why I did the math that way... but the theme of my post is correct.
No matter how you say it, an automatic transmission will soak up a bunch of existing horsepower.
According to Superstang.com , the numbers are 10-15% for a manual and 20-25% for an automatic.
The same can be said for AWD platforms, which soak up even more power... maybe 40% or more!?
I've also read that chassis dynos give weird numbers when the test vehicle is an auto.
And even with early lockup (which wears out the converter clutch if raced heavily), on the drag strip the horsepower loss is going to be even more pronounced than a converter-locked 3rd gear dyno run.
So, regardless of my crappy math skills, the key is that there is "free" rear-wheel horsepower when running a stick shift. I'd say about 10% of the flywheel horses to be had.
Remember, the poster was asking about 400hp to the wheels. It's just a suggestion. I'd imagine a stick would also hold up better behind a 470hp engine than a 4R70W behind a 530hp engine....and be cheaper to boot.
rocket5979 said:OH THE BLASPHEMY!!!hehehhhehehehe.
Frogman said:How's this for blasphemy?
My machinist said he received the rotating assembly going into my Mark... along with the HONDA bearings that are going in there?
HONDA? He said they are used in a lot of HP cars, but since I don't know jack about it, I'll take his word for it, since he does have a few High HP cars.
rocket5979 said:I am telling you dude, those loss % numbers that superstang.com gave are inflated. Yes, there will be a difference when comparing loss through a manual and loss through an auto tranny. The thing you gain in an auto tranny is consistency and never missing a gear. That can count for A LOT in a race, especially the brackets! A stock 4R70W tranny with a shift kit and an aux. trans cooler will be able to withstand a pretty decent amount of power. Putting 400 to the tires with one in that form would be no big issue. Being that this dude already is running a 4R70W tranny it would most likely be more expensive to swap to a manual versus refreshing his 4R, if needed, and installing the kit and cooler too. 400rwhp isn't a heck of a lot for a 4R tranny to need to hold. The 4R70W in mildly modded form is more than up to the task, and will surely not lose anything more than 20% through the slushbox if that.
Or tared and featheredrocket5979 said:HONDA???!?!!!!??? HOOOOOOONDDDAAAAAAAA!!!!!??? He should be shot. lol.![]()
EconomySpeedNStyle said:My point is, you have to spend more on the engine to get the same results you'd get from a manual....
At the end of the article, he states that many manual trans'ed cars lost 35hp at the transmission REGARDLESS of how much power was being generated...
SO.... 435 flywheel hp to get 400 rear wheel hp? Or 500 flywheel hp to get 400 rear wheel hp? Which would YOU choose in a NA 4.6? In fact, how much of a difference in cost are you looking at??
