UltimateSVT
- Joined
- Jun 21, 2009
- Messages
- 4,602
- Reaction score
- 166
MUST READ, MIND BOGGLING... WHAT THE HELL?!?!?
Ok guys, when I installed the 99 Mustang Cobra pump on my car back in January I noticed the radiator fan doesn't run when the A/C is OFF. As soon as I turn ON the A/C the radiator fan turns ON. My friend is a mechanic & told me that as long as I use the A/C, my car won't overheat. I've been using my Mark this way since January without an issue. I even drove it to the Keys last month without a hiccup (over 180 total miles).
This past Friday I traveled about 35 miles to a local car show here in South FL. with Marvin. The car ran cool, no problems. After 4 hours at the show, my girlfriend was tired & a bit hot from the nasty heat. I turn on the car for her & let it idle. Turns out that 6-7 minutes into the car running my girlfriend felt cold so she turns off the A/C but leaves the car running (she has no clue about cars nor guages)...
15 minutes later we all decided to leave & as soon as I hop in my car the needle on the letter "O" on NORMAL flips me out! I notice the a/c is off so I immediately turn on the A/C assuming my fan will run & cool off the car. The A/C blows VERY HOT! I turn it off, then on again & still hot, I get on the highway & the a/c started to cool. The car temp didn't start coming down until I traveled a good 2-3 miles. After driving the 30 miles on NORMAL temperature I get off the highway. The car immedeately starts to rise in temp. AAAANNND my A/C starts blowing HOT again. WTF?!?!?
I reach the house, pop the hood & notice that the fan isn't running & the A/C compressor is acting like if it was almost empty On/Off/On/Off, etc... I figured something electrical may be the issue between the A/C & the fan so I disconnect the battery. When I connect it again, I start the car & everything is running fine, compressor ran fine, fan started to run, etc...
The following morning I was leaving to the Keys again in my Mark VIII so I start the car & I notice I'm back to square one, same sh!t is happening. I risk it, go to my g/f's house 12 blocks away, the car only reaches normal temp due to the short distance but the A/C blows hot unless I go over 40mph. By the time I reach my house again the temp needle has officially gone over the "N", my display advises me to check the engine temp & there's water/steam coming out my reservoir. DONE!
I had to leave to the Keys so I left in my truck instead of my car.
What the hell is wrong with my car? Fan? A/C compressor? Both at the same f*cking time? I'm fuming mad because I don't have cash to spend on the car. Once again my car has to sit while I'm unemployed due to it's issues.
