thaywood
Always happy to help a fellow Lincoln lover.
Fortunately, money is not tight for me despite the terrible economy however; my philosophy has always been to not put much money into vehicles and to drive them until they drop. The car is here to serve me and when it no longer does that, it goes to the crushers.
My plan is to buy a used pair of front air struts for cheap. I’ll keep one strut in the trunk with the tools to change it out in case I’m on the road. I’ll also bring some tire sealant along to treat the used air bladders and/or tires.
And most of all, thanks for the tips. I have already saved nearly $400 had I bought new air struts.
He is not a lincoln lover he is a cheap ass.
Other than the hole that houses the solenoid, is there a bigger hole I could put the sealant in? At the top of the strut, there is a big bolt. Does removing that bolt give access to filling the strut?
I should also mention that I am aware of all the consequences of this procedure. Also, this is actually a test experiment to test how this product works with this application. And no, it is not Slime.
if you want to ruin ALL of your suspension components, instead of just having one bad one, by all means do it.
Well if you truly don't care about the damage you are going to do to the bags I would recommend you just drill yourself a hole in the bag whatever size you want to easily fill it. Then you can really test the sealant to see if it fills that hole too!![]()
DO NOT TAKE THE NUT OFF THE TOP!!! As for the sealant, I've got green slime in the front air springs on both of my Marks. I've got a '96 with Arnott front air spring/shocks that are over a year old. No problems yet...knock on wood. I've also got a 1997 LSC with some slight dryrot on the front springs. They were leaking down overnight when I got the car. I took them off and put some green slime in the springs and they don't leak down anymore. That's been over two months ago. I'm not saying it's a good idea, but since I could not afford new air spring/shock units for the '97, I had no choice. I put the slime in the new springs on the '96 as a precaution against dryrot. So far it has worked. I've heard about the crystalization of green slime and how it can damage the air spring. So far, I've had no problems. Also, I've got half a bottle of green slime that's been sitting on a shelf in my utility room for about 3 years and it is just as fluid now as it was when I first bought it.
I added the following to my signature and as of today, the contaminated air suspension system still has not failed. What an excellent car!!
Air suspension bags treated with tire sealant on 4/26/2010
You do realize "idiocricy" is not a real word, right?:lol:
Edit: Oops. It is a real word. Just spelled wrong. It should be "idiocracy". It means a government that is based upon abstract theory. Interesting use of that particular word.
And this will be my last post in both of these M.R. [mentally retarded] threads.
This was the first post that started it all
Then it was responded to in this manner
Then this was also said in the same manner
But unfortunately the 3rd reply was from this guy:slam
Now that all the Bs has been said, and the shat was talked. We find out this.
And then more shat was talked for a little.
Then we discovered this,,, that the op is a cheapass who is just going to fix this car cheap and run it into the ground. I personally would rather see one tore apart for parts then drove like an old Omni [not the shelby of course]. We will all have the oppurtinity to see this car jerry-rigged and fall apart.
I guess my point in all this was had Thaywood not given this option this would have never been thought possible by the OP. And that has been my point from the start. GOOD DAY!![]()
It's night.:shifty: I'm in the midwest.:shifty: I was never back here.
YOU HAVE BEEN WARNED NOT TO TRY THIS.
Fix you car the right way.
LOL!!!!
Tommy you just gave me a new sig.
LOL!!!!
Go try this :q:q:q:q on org. You would be banned before you hit reply.
And the whole "keyword" thing may have been a bad idea,
