thehamm99
Hi,
I'm Will.
I recently purchased my first Mark VIII, a car I've had my eye on for awhile.
I think I got a decent deal too.
She's a '97 LSC, with 76k, no engine tranny issues whatsoever. The guy I bought it from replaced the air ride compressor (all works great), and did a complete brake job.
I had a mechanic look at it, and the only real issue seemed to be it "probably" needed an AC compressor. (Other than that, it definitely needs a paint job. It's black but peeling/chipping).
So we settled on $1800 and I felt I got a decent deal.
The guy even gave me a "working" engine from a 1998 LSC with 120k or so miles on it (heads, valve covers, manifold, fuel rails, damper, flywheel, etc.)...which I'd like to sell for a few hundred $$$, as well as an extra air ride compressor and an extra steering column.
I soon realized the mechanic wasn't that great as my driver's side front wheel fell off the car while I was driving on the highway (from him not tightening the lugs correctly)...but at least I was okay, and he took full responsibility for the parts. He still owes me an abs sensor and a left front fender (I found the rim on the off ramp and it was fine!)
I also realized the Cruise control wasn't working, so I checked the fuse box, and voila- no fuse in that spot- which also controlled the AC.
So now I seem to have great working AC...but I have one problem:
The heat/defroster -- which worked up until last week (when the mechanic put on a new rotor and didn't yet install a new abs sensor) still blows, but no hot air whatsoever.
1. I checked both hoses connected to the heater core...both get hot
2. In order to drive without the abs sensor I have to turn traction control off. I read somewhere that with TC off heat won't work. So I turned TC on...but still no heat.
3. I want to locate the Heater Control Valve to check it, but don't know where it is.
So if anybody has read this far and has a clue as to my heater issues, any help would be appreciated.
I'm still very excited to now own a mark viii. If anybody's ever interested in seeing what she looks like I'll post a pic or two.
Thanks,
Will
I'm Will.
Thanks,
Will
