DeviLSh
Wanted to make a new thread, as I cannot locate a comprehensive thread on LVC that lists all gaskets associated with the V8's intake manifold.
There are a total of 6 Gasket locations that attach to the manifold assembly.
Regarding Item 2b above:
I am on the quest to find a set of upper seals as I approach my intake manifold replacement project. I have searched ebay, Jag sites, Ford/Lincoln sites, etc - and have not been able to locate a set of uppers yet that match the ones I removed.
This image below shows the comparison of the kit from 2a above, vs what I found when I cracked open the upper/lower version of a spare 2006 manifold I have. Note the lack of large black tabs on my OEM red gaskets that are present of the replacements.
If anyone has access to a set of these gaskets pictured, please share. Otherwise one might have to get creative, order an entire assembly ($$$) or reuse.
Pic for reference of gasket locations:
1) Lower Manifold Gasket (2) (From spacers to head) - MotorCraft 2W9Z-9439-AA OR FelPro MS69293
2) Upper Manifold Gasket (8) (From Spacer to Plenum)
3) Throttle Body to Eblow (1) (TB Gasket) - MAHLE G31842
4) Elbow to Plenum (1) (Elbow gasket) - MAHLE G31844
5) Plenum to Rear Cover gasket (1) - Jaguar AJ87992 OR the kit here: MAHLE MS19424
6) EGR to Elbow (1) (EGR Intake side gasket) - Motorcraft 2W7Z-9D476-AA
Thought this would be a good resource for anyone looking to replace gaskets, having it all in one place. We can update this thread for other vendors, pricing and reviews on the gaskets. Some other good links and images available here in the LS MAHLE catalog (I have had good results from this supplier)2) Upper Manifold Gasket (8) (From Spacer to Plenum)
