GreyWisent
My thoughts exactly!I think you are probably on to it, but while you are there, take a look at the big vacuum hose that goes to the check valve for the brake vacuum booster. It's right above where you were pointing the propane. Those hoses do get porous over time (unless you already replaced it).
That corner of the manifold is also about 1/2" away from where the aforementioned vacuum hose connects to the metal pipe going to the back of the intake manifold. The rear cover of the intake manifold (and gasket/ring) is also there. Maybe try temporarily sealing those areas better and repeat your experiment before tearing into the manifold. Even taping a plastic bag around there to redirect the air flow is worth the effort, IMO.
(REPLACE YOUR COOLING SYSTEM - 2004 Fun and Easy StepsREPLACE YOUR COOLING SYSTEM - 2004 Fun and Easy Steps)
