Lownslowlsc
It's getting to be that time of year again...
Ok, this is the first winter the mark has seen in my 4yr/14k mile ownership. It's time to get her ready for it.
My plan is to put a couple coats of wax on the lower sections below the trim and on the inside of the door on the lower portion where salt can build up. I waxed it a little bit ago so i'll just focus on the lower sections. I still sorta consider this half assed. We'll see...
Other then that all I can think of is to put on my oem winter wheels(2 newish tires/2 fair) and a oil change to get me through the winter months(Only drive 25 miles a day)
Does spraying white lith grease on the rubber door moldings really work? What's the trick to help keep the windows from freezing up?
New Battery/Alternator and Wiper blades in the spring/summer
Bda is still holding up as it should
Engine and trans in good shape
Thick Rubber floormats,scraper are ready
Tool kit, emergency kit/cables, spare fluids ect
Sub box in truck so it has wieght
Forgetting anything?
What do you guys do before the deep freeze starts?
