They should get just as hot as yours..
This process also work on first gens i assume?
The warning light should only come on when the running light are on. That is the wire where a bulb out is detected
You dont need resistors for the turb bulbs if you install all 4 of them, 2 in the front and 2 in the rear. You only need resistors for the brake bulbs
Does this apply to 1st Gens? I bought a pair of front turn bulbs from V-leds, but I get a front bulb error. They blink as long as all the lights are off. As soon as I turn the lights on I get an error on my dash, and they won't blink. 180755124017
OK. I just went out and tested. This is the procedure to replicate the warning message, and it works every time.
1. Insert the keys, and turn to the "On" position, but do not start the car.
2. Turn the lights to the "Parking Lamp" or completely "On" positions (either/or).3. Depress the brake pedal, and the "Check Brake Lamps" will appear as soon as you do.
Now, if the above steps are done with the car running, the warning message does not appear. Not quite sure what causes this, but like I said, it's not a huge deal to me since I always start and drive the car. I was just curious if anyone else who performed the LED upgrade and resistor install experienced the same thing.
My problem isn't just with the message coming up, its that the lights don't blink if the parking lights are in the on position, if everything is off and I put the turn signal or hazards on they will work but as soon as I turn on the parking lights they no longer blink and I get an error on the dash.
