vietnamvet
I found that my OBD Code P1537 is in fact the passenger IMRC Actuator. I have obtained a new one and ready to put on.
I need some help.
First, does anyone know the part number and source for the plastic part that hold the actuator arm to the Cam. I am almost positive that it will break when I take the actuator off.
Second. Is there an easy way to get the actuator off: I thought I might be able to take the actuator off by loosening the two bolts however, there is no clearance to take the bolt out.
Wondering if both the bolts are loose with the bracket come out or must I take off something else.
Thanks in advance.
I need some help.
Thanks in advance.
