Psychostang
Ok, so my 1996 Gen I IMRC plate pivot bushings are leaking. What do you people recommend as a fix. Can these bushings be replaced? Is there a part number for them?
I can also see what the valves look like!
You won't be happy with what you see on the non-injector side of the intake valve. Tons of deposits will be sitting on top of the valve stem.
So the butterfly assemblies come apart and can be disassembled from the aluminum? The bearing can be removed from the assembly? And the o-ring is pressed into the aluminum runner and needs to be pressed in there?
I was racing Monday morning when I had my IRMCs off so I didn't have an opportunity to really study it.
