Stopsign002
I'm using mobile 1. I forgot what filter I used but it wasnt the mobile 1, and it was fram. That I can remember haha. I'm going to change my oil around 7K so Ill probably get the mobile 1 filter this time around
For $30 at the dealer you can get it changed with synthetic blend (recommended by ford themselves) and a motorcraft filter which is made by purolator.
You can spend much more on a full synthetic with fancy filter but this is good deal.
You wont get the long interval with the blend. Otherwise, its fine. I think you're right about motorcraft using purolator, but they do change vendors on a whim. Also, unless its a Pure One filter rebranded, I would go with the M1.
+1
i pay around $40 at my local Lincoln dealer with taxes and everything.
It's around $40 or just over for full synthetic and Motorcraft filter if you do it yourself. My main reason of doing it myself is that I don't have to worry about the threads in the oil pan being stripped or someone starting the engine without any oil in it.
Ive done 5K miles on it twice now and it comes out clean just like when i did 5K with mobil1. I saw no difference to justify spending more.
+1 Its not that I think they are stupid or inexperienced, its that I think they are in a hurry. I dont mind spending a little more (cost me around $40 or so for mobile 1 and wix filter) to get the oil that has the best lubricancy (not sure what the technical term is for this) also
You changed early at 5K on Mobil1 (and I'm sure the blend could go longer too but you would really need to have it analyzed to be sure). By long interval I meant 10-15K. At 5K interval, I'd be changing my oil every 3 months. Its actually cheaper per mile to pay a little more for full syn and go 2-3X longer.
My cost was $45 this last time for 6 qts and the filter. I prefer full synthetic though... and I prefer the M1 over the other brands.For $30 at the dealer you can get it changed with synthetic blend (recommended by ford themselves) and a motorcraft filter which is made by purolator.
I'm with you, but I always prefer to do things myself if I can help it. You never know who's in that bay when you take your car somewhere. Some of those guys think "Oh its just a galant, who cares?" No one will ever take as much pride in stuff you own as you the owner. Another reason for doing it is so that you know your car. You may spot something else that needs work someone in a hurry may never notice.It's around $40 or just over for full synthetic and Motorcraft filter if you do it yourself. My main reason of doing it myself is that I don't have to worry about the threads in the oil pan being stripped or someone starting the engine without any oil in it.
Where are you guys getting your oil? I just paid $9.79+ tax per for 7 quarts of Mobil1 5W20(= $73.84). The K&N filter was another ~$10. I do go about 10K miles between changes; which works out to about twice per year.
Ouch. My local autozone has the 5 quart jug of Mobil1 for $35.99 and the motorcraft blend for $10 less.
Local Walmart has the five quart jugs of Mobil1 for about $27.
http://www.walmart.com/ip/Mobil-1-5W-20-5qt/17018132
If it matters, I buy the Extended Performance oil......
http://bit.ly/MokoU2Where are you guys getting your oil? I just paid $9.79+ tax per for 7 quarts of Mobil1 5W20(= $73.84). The K&N filter was another ~$10. I do go about 10K miles between changes; which works out to about twice per year.
... I put 6 qts to top off though.
Well, it gets it well within the cross hatch (do not add zone). I put 7 in my truck.The V8 takes 6.5, I always just put 7.
