RigsLS
- Joined
- Mar 10, 2012
- Messages
- 7,756
- Reaction score
- 533
These LS plastic cooling systems tend to age and deteriorate as a whole. They become rotten from the inside outwards. There is signs of anywhere from small brown pitting to complete break down and crumbling apart. I myself, like plenty others around here, have at one point already replaced and rebuilt the entire cooling systems of these cars. My 01 V8 Sport was not overheating but rather producing no heat at idle and shortly thereafter lost heat completely with a leaking degas bottle. Just to add to the fun, the thermostat housing fill cap was stuck on and threatening to crack just by looking at it. I replaced pretty near 90% of that system, the JAG upgraded T stat housing, bottle, inlet pipe, DCCV and Aux flow pump. No rad and I left the lower hose alone.
The issue is not that of the type of mix you run or pressurized vs non-pressurized but more so the fact that over time the plastics begin to deteriorate due to repeated excessive heat cycling.
A little less pressure or altering the boiling point by a couple of degrees will not solve this issue.
Lincoln LS'es, that are neglected, used as daily drivers tend to see the most deteriorating of these plastics. LS'es that have been well cared for and only seen Sundays away from the garage tend to run longer on the original plastics.
Take a thought on the following;
LS#1 Sees daily routine getting to work and back, stuck in traffic jams on every hot summer day of the week, gets the same abuse in cold winter, get's used for short runs to the local convenience store, driven even harder on football night with a case of beer in the back.
LS#2 Sees only a nice calm breezy ride on Sundays to church and back, some gentle driving to the local bingo on Thursdays perhaps. Goes back in the garage for the week.
Obviously the higher mileage daily driver is going to have it's plastic coolant system deteriorate first.
It's not written in stone obviously but we tend to aim for the 10+ yr or 100K mi ... it's not long there after that it'll needs it's plastics replaced. Some can go on several more years before the issue needs addressing. The harder of a work out, the sooner it needs parts, is what I'm getting at.
We've seen all sorts of guys become new members on LVC here, they pick up a modestly used LS and it either already needs plastics overhauled or within the month they start posting about overheating and how much of a POS they think it suddenly is.
Any car after it's 10yr mark is going to need parts ... eventually, some are more prone then others but in the case of the Lincoln LS, the plastics that make up the cooling system are going to break down, it's not a matter if it will or not, more so a matter of when it will.
You can clearly see it in many of the pictures that have been posted. Look for dirty engine bays where the plastic cooling system parts are no longer black on the outsides, the one's that reflect a degrading gray to brown are the ones that will be soon be posting about no heat or an overheating issues. Hoses blowing off because the system is crumbling apart from the inside.
Then begins the ... I am still overheating, or I can't seem to bleed it properly. Nothing comes out of the purge line, now what?
This closed looped cooling system needs to be and remain air tight to properly function as design intended. Any further leaks where the system is not able to maintain or generate it's own flow pressure, it will not begin to bleed properly or even at all.
You can choose to replace just that one failing part of course, no one here is going to stop you but the experiences from others dictate that once one part goes another follows shortly there after. As I said above, it deteriorates as a whole as time passes due to excessive heat cycling. No amount of 60/40, loosen the degas bottle cap is going to fix it when it's already at the point of breaking down. Less pressure and a slightly different boiling point mixture of antifreeze is not going to reverse the plastic break down chemistry, it's just not!
It's merely a 'make-me-feel-better-for-now' bubble gum solution.
I can get a car from one side of town to the other on water w/ a loose radiator cap as well. Anyone with any brains if they try hard can do that ... does it fix, repair, replace or even remotely correct the situation at hand? You know .... the situation of the aging plastics breaking down?
on an old LS?
does it?
You believe what you will ... Listen to the Don,
he's going to help fix your tired, overheating, broken down, cooling system in as many threads as possible by the looks.
GLWR
on an old LS?
does it?
GLWR
