Today's Daily special (May 25, 2010) is Gilmour Brass Connector High Flow Shut-off Valve.
Regular Price is $6.99. Today's price is $5.17!
  • Easily kill water flow with a simple twist of a knob instead of walking back to the hose source
  • Perfect for removing your hose nozzle or foam gun to utilize the sheeting method
Today's Daily special (May 27, 2010) is Black WOW Black WOW.
Regular Price for 4 oz is $24.99. Today's price is $19.50!
  • Restore faded and neglected trim pieces, while leaving behind a bold even finish
  • Removes product residue from trim and lasts through multiple washes
  • Only a tiny bit of product is needed, use sparingly
Today's Daily special (May 28, 2010) is Chemical Guys Citrus Wash.
Regular Price for 16 oz is $9.99. Today's price is $7.09!
Regular Price for 128 oz is $32.99. Today's price is $24.41!
  • Ultra concentrated paintwork cleaning shampoo designed to strip off protection to start fresh
  • Powerful concentrated formula only requires 1oz of product per gallon of water to effectively remove layers of protection
  • Works well in a Gilmour Foam Gun
Today's Daily special (May 29, 2010) is Chemical Guys M-Seal.
Regular Price for 16 oz is $19.99. Today's price is $14.39!
  • One of the best bang for the buck, pure sealants for under $20
  • Easy to apply and remove when applied properly, which is as thin as possible
  • M-Seal not only protects your paint, but leaves behind a great shine and sharp reflections
  • Best applied with a foam applicator pad and removed with a microfiber towel
  • When using a buffer, best applied with a blue fine finishing pad
Today's Daily special (May 30, 2010) is Chemical Guys Fade 2 Black.
Regular Price for 13 oz is $12.99. Today's price is $9.48!
  • One of the most unique trim restorers that turns faded trim back to a deep factory black finish
  • Perfect option for wheel wells, engine bay dressing, tire dressing and exterior trim pieces
Today's Daily special (June 2, 2010) is Menzerna Final Finish.
Regular Price for 32 oz is $29.99. Today's price is $21.89!
  • A great finishing polish, designed to remove hazing, holograms and light surface imperfections
  • Restores depth and gloss to the paints finish and is easy to work with
  • Easy to remove when worked into the paint properly
  • Recommended application is using a buffer with a white polishing pad
  • For accurate product dispensing, we recommend using a 4oz dispenser bottle
Today's Daily special (June 3, 2010) is Raggtopp Fabric Protectant.
Regular Price for 14 oz is $22.99. Today's price is $16.55!
  • Properly protect your fabric top that is endorsed by Haartz, the OEM of most American and European convertible tops
  • Easy to use aerosol spray can that will not harm paint, glass, chrome or plastic
  • Best applied after properly cleaning your convertible top
Today's Daily special (June 4, 2010) is P21S Concours Carnauba Wax.
Regular Price for 6.2 oz is $31.99. Today's price is $26.05!
  • Very easy to apply and remove carnauba wax that looks great on any color vehicle
  • Includes an applicator pad that conveniently stores inside the top of the wax
  • Unlike other waxes, P21S Concours Carnauba wax will not stain your trim
  • Excess product should be removed with a quality microfiber towel
  • P21S recommends prepping the surface with Paintwork Cleanser for best results
Today's Daily special (June 6, 2010) is Chemical Guys Fabric Clean.
Regular Price for 16 oz is $7.99. Today's price is $5.83!
  • Powerful concentrated fabric cleaner and deodorizer that works wonders on carpet and upholstery
  • Dilute down to an 8:1 ratio with distilled water, or use full strength for stubborn stains
  • We recommend using a brush to agitate stubborn stains in fabric and carpets
  • For easy dilution and usability, we recommend a 22 oz spray bottle
Today's Daily special (June 7, 2010) is Poorboy's World Black Hole.
Regular Price for 16 oz is $15.99. Today's price is $11.91!
  • Enhance the depth and gloss of darker colored vehicles with ease
  • Best used after polishing and before applying your layer of sealant or wax
  • Easily applied by hand or machine and removes effortlessly
Today's Daily special (June 8, 2010) is Poorboy's World Super Slick & Suds.
Regular Price for 32 oz is $15.99. Today's price is $12.79!
  • Lots of suds, great lubricity, gentle cleaning agents and ease of use makes this shampoo a favorite, both for bucket use or in foam guns
  • Only a cap full of shampoo is needed to produce an abundance of suds in a 5 gallon bucket of water
  • Will not remove previous coats of protection from your paint, an ideal maintenance shampoo
  • Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
Today's Daily special (June 10, 2010) is Meguiar's Ultimate Quik Detailer.
Regular Price for 22 oz is $9.99. Today's price is $7.63!
  • Increases the depth and gloss of any color vehicle
  • Adds a layer of protection with high surface tension which repels water very well
  • Perfect product to use after a maintenance wash between details
  • Best applied with a plush microfiber towel
Today's Daily special (June 12, 2010) is DI Accessories Polishing Pal.
Regular Price is $12.99. Today's price is $9.22!
  • Even distribution of any product and better results from hand applications
  • Get the same variety in cutting and finishing pads as you would with a buffer using 4" pads!
Today's Daily special (June 14, 2010) is Poorboy's World Wheel Sealant.
Regular Price for 8 oz is $17.99. Today's price is $13.13!
  • Properly protect any wheel finish and minimize the amount of brake dust and road contamination
  • Easily clean and maintain your wheels to a like new condition when protected with Wheel Sealant
  • One jar will last dozens of applications when applied correctly. The thinner the coat the better.
  • Cleans, restores, protects and enhances gloss all in one simple step.
  • Very easy to apply and remove. Once removed, the surface of your wheels is very slick.
  • Apply with a foam applicator pad and remove with a clean microfiber towel
Today's Daily special (June 16, 2010) is Poorboy's World Quick Wax Plus (QW+).
Regular Price for 16 oz is $12.99. Today's price is $9.22!
  • Best applied just after washing to enhance the depth and gloss as well as add protection to the paint
  • Very easy to apply and remove when applied correctly, either in the shade or sun
  • Also works well on chrome, polished aluminum and wheels
  • Best applied with a plush microfiber towel to minimize any micro-marring in the paint
Today's Daily special (June 17, 2010) is Dodo Juice Orange Crush Soft Wax.
Regular Price for 250 ml is $69.99. Today's price is $54.72!
Regular Price for 30 ml is $13.99. Today's price is $9.93!
  • A Dodo Juice soft carnauba wax designed to work exceptionally well on warmer colored vehicles
  • Extremely easy to apply and remove, especially when applied in thin layers
  • Strong protection and tight water beading makes maintaining your vehicle a breeze afterwards
  • Can be applied with a foam applicator pad or literally with your bare hands
  • Dodo Juice soft waxes offer slightly more depth and gloss over the Dodo Juice hard waxes
  • Remove any Dodo Juice wax with a plush microfiber towel
Today's Daily special (June 18, 2010) is Dodo Juice Time to Dry Drying Detailer.
Regular Price for 250 ml is $12.99. Today's price is $10.18!
  • Dry your paint faster and more effectively
  • Helps minimize adding imperfections during wipe downs
  • Reduce potential water spots on your paint
  • Best used in conjunction with a waffle weave drying towel
Today's Daily special (June 20, 2010) is Chemical Guys Extreme V.R.T. Dressall.
Regular Price for 16 oz is $9.99. Today's price is $7.39!
  • Very versatile dressing that restores vinyl, rubber and plastic to a clean, low gloss finish
  • Properly protect your vinyl and rubber surfaces from UV fading with CG Extreme V.R.T.
  • To avoid over spray, we recommend misting Extreme V.R.T. into a microfiber towel to apply
  • We recommend using a 4oz pump spray bottle to apply a thin, even layer of dressing
Today's Daily special (June 21, 2010) is Leatherique Rejuvenator Oil.
Regular Price for 16 oz is $29.99. Today's price is $22.65!
Regular Price for 32 oz is $49.99. Today's price is $36.99!
  • Detailed Image's best leather care product to restore neglected, faded, hardened leather
  • Restores oils and proteins that are naturally found in leather for a soft and supple feel
  • Works best when allowed to penetrate leather for up to 48 hours, ideally in the heat
  • Using a hair drier to heat up the leather surface allows for maximum penetration and best results
  • Apply Rejuvenator Oil by massaging the product into the leather with your bare hands
  • Must be removed by following up with Leatherique Prestine Clean
Today's Daily special (June 27, 2010) is Meguiar's Solo Easy-Buff Rotary Backing Plate W66.
Regular Price for 5.75" is $24.99. Today's price is $18.83!
  • Increases maneuverability and control compared to a stiffer backing plate
  • Works best with 6.5" pads
  • Fits any rotary buffer using a 5/8th - 11 spindle thread
  • Finish down easier with less chance of hazing, marring or holograms
Today's Daily special (July 6, 2010) is Chemical Guys Wet Mirror Finish.
Regular Price for 16 oz is $19.99. Today's price is $14.89!
  • Clean and protect your paint in one simple step while enhancing the gloss and depth
  • Easily apply by hand or with a buffer and remove with a quality microfiber towel to reveal a mirror like finish
  • Works great on both light and dark colored paint for a head turning finish
Today's Daily special (July 8, 2010) is Chemical Guys Citrus Wash Wheel & Rim Cleaner.
Regular Price for 16 oz is $8.99. Today's price is $6.70!
  • Citrus based wheel cleaner that is safe to use on virtually any wheel surface
  • Concentrated solution makes this a great value as you can dilute it down 7:1 with water
  • Works best when an E-Z Detail Brush is used in conjunction with Wheel & Rim Citrus Cleaner
  • Protect your just cleaned wheels with Poorboy's World Wheel Sealant for easy maintenance
Today's Daily special (July 9, 2010) is 303 Aerospace Protectant.
Regular Price for 16 oz is $12.99. Today's price is $9.48!
Regular Price for 32 oz is $22.99. Today's price is $16.78!
Regular Price for 128 oz is $54.99. Today's price is $39.59!
  • An excellent UV protectant and dressing for vinyl, leather, rubber and plastic surfaces
  • Leaves behind a beautiful matte finish that is not greasy, shiny or oily
  • Treated surfaces resist dust, soiling, staining and also repel water
  • Most commonly used on interior dashboards, center consoles, door trim, leather seats, and in the engine bay
  • Works great on vinyl convertible tops, plastic rear windows, clear bras, and tonneau covers
  • For maximum efficiency use in a 4oz pump spray bottle and apply with a microfiber towel
Today's Daily special (July 14, 2010) is Meguiar's PlastX Clear Plastic Cleaner and Polish.
Regular Price for 10 oz is $7.99. Today's price is $5.91!
  • Ideal for use on headlights, tail lights, motorcycle windshields, convertible windows and much more
  • Restore clarity to clear plastics by removing stains and imperfections
  • Leaves behind a polymer protection for easier maintenance
Today's Daily special (July 16, 2010) is Poorboy's World Trim Restorer.
Regular Price for 16 oz is $15.99. Today's price is $11.51!
  • Restores neglected rubber, vinyl and plastic trim that has faded over time
  • For maximum results, prep the trim you plan on restoring with a degreaser and apply multiple thin coats
p.s. I'll be out of town this weekend so I may not be back on the forum until Tuesday but I'm going to try and at least check e-mail over the weekend. So if you have a question please send me an e-mail. Enjoy your weekend!
