Today's Daily special (July 20, 2010) is Dodo Juice Red Mist Tropical Protection Detailer.
Regular Price for 250 ml is $16.99. Today's price is $12.23!
  • Extend the protection of any sealant or wax
  • Increase gloss and depth of your paint, perfect for after a wash
  • Promotes tight water beading which helps minimize water spots
  • Applies and removes easy with a plush microfiber towel
Today's Daily special (July 21, 2010) is Chemical Guys Bug Bugger & Tar Remover.
Regular Price for 16 oz is $9.99. Today's price is $7.19!
  • Remove tar, bug splatter, sap, and other stubborn forms of contamination with ease
  • Simply spray the product onto the paint, allow Bug Bugger to dwell for a bit, agitate and rinse away contamination
  • For maximum efficiency and easy storage use in a 4oz pump spray bottle
Today's Daily special (July 22, 2010) is Chemical Guys Sofast Odor Eater.
Regular Price for 16 oz is $8.99. Today's price is $6.56!
  • Remove odors from your interior by killing the bacteria causing the foul smell
  • Leaves behind a fresh apple scent that lingers for days
  • To maximize your product, we recommend using a 4oz pump spray bottle to dispense
Today's Daily special (July 23, 2010) is P21S Gel Wheel Cleaner.
Regular Price for 500 ml Kit is $17.99. Today's price is $14.21!
Regular Price for 1000 ml is $24.99. Today's price is $18.96!
Regular Price for 5000 ml is $99.99. Today's price is $80.16!
  • One of the safest, most effective, pH balanced wheel cleaners on the market
  • Gel based formula allows the product to penetrate vertical surfaces for a more effective cleaning
  • Perfect option for after market wheels as it is safe for virtually any wheel surface
  • Works best when an E-Z Detail Brush is used in conjunction with P21S Gel Wheel Cleaner
  • Follow up with Poorboy's World Wheel Sealant for wheels that are easier to maintain
Today's Daily special (July 24, 2010) is Optimum (OPT) Hyper Spray Polish.
Regular Price for 18 oz is $24.99. Today's price is $18.24!
  • Innovative spray polish that will save time while removing moderate imperfections
  • Work inside or outside with long work times and minimal dusting
  • Vary the level of cut with pad options, such as white, green, black and tangerine
Have you tried the hyper polish spray? And are you going to be getting the spray compound too? I've heard the compound is very low dusting, but has a similar cut to M105 with longer work time.
Today's Daily special (July 27, 2010) is Brinkmann TuffMax Dual LED Pivot Spotlight.
Regular Price is $39.99. Today's price is $28.79!
  • Dual LED light will reveal swirls, RIDS, holograms and other imperfections in your paint
  • Uses 6 AA batteries that are included, making it easy to get back into action. Pivoting heads and CREE LEDs make it a must have for detailers.
  • Avoid having to use bulky, corded, and hot halogen light stands!
  • Get the best polishing results with the proper lighting, no guess work if imperfections have been removed effectively
Yes the new Optimum (OPT) Hyper Spray Compound is excellent. We have it in stock and ready to ship. It's an impressive product that does help you save some time with the spray and no dusting. It is similar to the M105 in that it has a lot of cutting power but still finishes down really well. It definitely will have it's place in detailer's arsenal of products.
Today's Daily special (July 28, 2010) is DI Accessories Gentle Fine Grade Clay.
Regular Price for 200 g is $18.99. Today's price is $14.15!
Regular Price for 100 g is $10.99. Today's price is $8.02!
  • Safely and effectively remove tar, sap, paint over spray and more
  • Fine grade clay bars will not mar your finish when used properly
  • We recommend using Dodo Juice Born Slippy as your clay lube
Today's Daily special (July 30, 2010) is Optimum (OPT) Hyper Spray Polish.
Regular Price for 18 oz is $24.99. Today's price is $18.62!
Today's Daily special (August 1, 2010) is Chemical Guys Extreme Offensive Odor Eliminator - Concentrated.
Regular Price for 16 oz is $10.99. Today's price is $7.80!
  • Powerful concentrated solution can be diluted down 2:1 with water and still maintain effectiveness
Today's Daily special (August 4, 2010) is Chemical Guys Synthetic Quick Detailer.
Regular Price for 16 oz is $9.99. Today's price is $7.39!
Regular Price for 128 oz is $27.99. Today's price is $23.28!
  • A favorite quick detailer amongst professional detailers due to its outstanding shine and slickness
  • Works great as a clay bar lubricant
  • An ideal product to use after a wash to enhance the depth and gloss of your paint
  • We recommend using a plush microfiber towel to apply the Synthetic Quick Detailers
Today's Daily special (August 10, 2010) is Chemical Guys Pete's & 53 Black Pearl Signature Paste Wax.
Regular Price for 8 oz is $53.99. Today's price is $38.87!
  • A hidden gem of carnauba waxes, offering excellent depth and gloss and easy application
  • Excels on darker colored vehicles, but works well on any color, metallic and non-metallic
  • Easy to apply and remove when applied properly, which is as thin as possible
  • Best applied with a foam applicator pad and removed with a microfiber towel
Today's Daily special (August 12, 2010) is Poorboy's World Trim Restorer.
Regular Price for 16 oz is $15.99. Today's price is $11.83!
  • Restores neglected rubber, vinyl and plastic trim that has faded over time
  • For maximum results, prep the trim you plan on restoring with a degreaser and apply multiple thin coats
Today's Daily special (August 13, 2010) is Meguiar's All Purpose Cleaner Plus D103.
Regular Price for 128 oz is $13.99. Today's price is $10.21!
  • Best used to degrease engine bays, wheel wells, tires, interior clean ups, and much more
  • Effective even at a 10:1 dilution ratio making this an extremely good value
  • Works well in carpet extractors due to the low sudsing formula
  • Dilute and dispense using a 22 oz trigger spray bottle
Today's Daily special (August 17, 2010) is Poorboy's World Wheel Sealant.
Regular Price for 8 oz is $17.99. Today's price is $13.40!
  • Properly protect any wheel finish and minimize the amount of brake dust and road contamination
  • Easily clean and maintain your wheels to a like new condition when protected with Wheel Sealant
  • One jar will last dozens of applications when applied correctly. The thinner the coat the better.
  • Cleans, restores, protects and enhances gloss all in one simple step.
  • Very easy to apply and remove. Once removed, the surface of your wheels is very slick.
  • Apply with a foam applicator pad and remove with a clean microfiber towel
Today's Daily special (August 24, 2010) is P21S Metal Polishing Soap.
Regular Price for 10.5 oz is $9.99. Today's price is $8.28!
  • Cleans, restores, polishes, and protects metal surfaces to a brilliant finish in 1 easy step
  • Includes a sponge applicator pad that conveniently stores itself in the top of the jar
  • Soak supplied sponge in warm water, wring out, swipe across soap, then polish the metal
  • For best results, clean the area prior to polishing with soap and water
  • Remove excess product with a quality microfiber towel
Today's Daily special (August 26, 2010) is P21S Concours Carnauba Wax.
Regular Price for 6.2 oz is $31.99. Today's price is $26.05!
  • Very easy to apply and remove carnauba wax that looks great on any color vehicle
  • Includes an applicator pad that conveniently stores inside the top of the wax
  • Unlike other waxes, P21S Concours Carnauba wax will not stain your trim
  • Excess product should be removed with a quality microfiber towel
  • P21S recommends prepping the surface with Paintwork Cleanser for best results
Today's Daily special (August 27, 2010) is Optimum (OPT) Finish Polish.
Regular Price for 32 oz is $29.99. Today's price is $22.34!
  • Optimum's finest finishing polish for maximum gloss and depth
  • Long workability in both the sun and shade
  • Removes minor surface imperfections such as hazing and holograms
  • Best applied with a black finishing pad on a quality buffer
Today's Daily special (August 29, 2010) is Lake Country Hydro Tech Cyan Light Cutting and Polishing Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.09!
Regular Price for 5.5 inch is $8.99. Today's price is $6.56!
Regular Price for 4 inch is $4.99. Today's price is $3.59!
  • Powerful cutting action but the ability to finish down haze free
  • Hydro Tech foam keeps more polish on the surface of the pad for long work time
  • Experience less dusting than traditional foam pads due to less product buildup
  • Save time and improve your results!
Today's Daily special (September 2, 2010) is Chemical Guys Hose Free ECOwash.
Regular Price for 16 oz is $12.99. Today's price is $9.48!
  • Perfect for mobile detailers, enthusiasts without access to a hose or washing in a garage
  • All you need is to fill up 2 buckets of water and you can wash your car, no water source needed
  • Best applied with a plush microfiber towel, grout sponge or sheepskin wash mitt
  • Environmentally friendly
Today's Daily special (September 3, 2010) is Poorboy's World Bug Squash.
Regular Price for 16 oz is $10.99. Today's price is $8.19!
Regular Price for 32 oz is $15.99. Today's price is $11.67!
  • Paint safe, pre-wash degreaser designed to break up stubborn contamination prior to washing
  • Helps loosen bug splatter, tar, sap, bird droppings, and other forms of contamination
  • Concentrated solution which should be diluted down to a 3:1 ratio with distilled water
  • Remember to protect the areas you use Bug Squash on with a sealant or wax
  • For easy dilution and usability, we recommend a 22 oz spray bottle or a convenient 4 oz pump bottle
Today's Daily special (September 6, 2010) is Chemical Guys Speed Wipe (Anti-Static) Quick Detailer.
Regular Price for 16 oz is $8.99. Today's price is $7.00!
  • An outstanding quick detailer that is perfect to use after a maintenance wash and dry
  • Leaves behind a slick surface that is anti-static which helps minimize dust build ups
  • Best applied with a plush microfiber towel to minimize any micro-marring in the paint
Today's Daily special (September 8, 2010) is P21S Windshield Wash Booster.
Regular Price for 250 ml is $8.99. Today's price is $6.56!
  • Increase the cleaning power of your current windshield washer fluid
  • Helps improve visibility, which helps you drive safer in poor weather conditions
  • Simply pour some P21S Windshield Washer Booster into your existing washer fluid!
