Today's Daily special (April 16, 2011) is SONAX High Speed Wax.
Regular Price for 500 ml is $12.99. Today's price is $9.22!
  • Breakthrough nanotechnology gives you more protection and a faster application
  • Durable protection with a great shine
  • Looks outstanding on all colors
  • Applies and removes with ease
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Today's Daily special (April 18, 2011) is Lake Country Yellow Cutting Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.44!
Regular Price for 5.5 inch is $8.99. Today's price is $6.65!
Regular Price for 4 inch is $4.99. Today's price is $3.64!
  • The most aggressive foam cutting pad, designed to remove the deepest swirls and scratches
  • Optimum Hyper Compound is a great polish to use with a yellow cutting pad
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Today's Daily special (April 20, 2011) is DI Microfiber Waffle Weave Drying Towel.
Regular Price for 36" x 24" is $17.99. Today's price is $12.77!
  • One of the best options for drying your vehicle and most commonly used by professional detailers
  • The waffle weave texture helps pull contamination away from the surface compared to a flat chamois
  • Our microfiber waffle weave towel has silk edging to minimize adding imperfections
  • This towel can hold up to 5 times its weight with water
  • We recommend using the sheeting method prior to drying with the towel for maximum efficiency
  • Always wash your microfiber products prior to first use
Today's Daily special (April 21, 2011) is Meguiar's DA Microfiber Cutting Disc Buffing Pad - 2 pack.
Regular Price for 5.5" is $21.99. Today's price is $15.61!
Regular Price for 6.25" is $23.99. Today's price is $17.51!
Regular Price for 3" is $11.99. Today's price is $8.87!
  • Combine this pad with the Meguiar's DA Microfiber Correction Compound for best results
  • Includes 2 Pads
  • Exceptional cutting power that removes swirls while finishing down crystal clear
  • A brand new technology that is changing the detailing world
  • Use a Porter Cable 7424 XP and the Meguiar's Professional Backing Plate
Today's Daily special (April 22, 2011) is SONAX Nano Technology Paint Cleaner.
Regular Price for 500 ml is $19.99. Today's price is $14.59!
  • AIO product that deep cleans, polishes and protects
  • Can restore neglected paint and maintain newer finishes
  • Utilizes nano technology to create a highly refined wax particle
Today's Daily special (April 25, 2011) is P21S Finish Restorer.
Regular Price for 75 ml is $10.99. Today's price is $8.68!
  • Clean, restore and polish your wheels and metal trim in one easy step
  • A little goes a long way, work a small amount of product into the metal with light pressure
  • We recommend using a foam applicator pad for application
  • Use a two sided metal polishing towel to remove excess product and to buff to desired finish
Today's Daily special (April 26, 2011) is Menzerna Power Lock Polymer Sealant.
Regular Price for 16 oz is $29.99. Today's price is $21.89!
Regular Price for 32 oz is $49.99. Today's price is $36.49!
  • First true sealant produced by Menzerna
  • Long durable protection with a great shine!
  • Long lasting protection from durable polymer formula
  • Deep and glossy shine while easy to apply
Today's Daily special (April 27, 2011) is Menzerna Power Gloss.
Regular Price for 16 oz is $18.99. Today's price is $14.63!
  • One of our most aggressive compounds we have to offer, allowing for deep paint correction
  • Most commonly used on a yellow cutting pad or purple foamed wool pad
  • Will leave behind marring and hazing, so it is important to follow up with a less aggressive polish
Today's Daily special (April 28, 2011) is Chemical Guys Diablo Gel Rim and Wheel Cleaner.
Regular Price for 16 oz is $16.99. Today's price is $12.66!
Regular Price for 128 oz is $84.99. Today's price is $61.19!
  • pH balanced wheel cleaner safe on ALL wheel finishes and competes amongst the best wheel cleaners available
  • Powerful concentrated suspension allows for dilution of product without the loss of cleaning power, making it a great value
  • Perfect for high end professional detailers who detail expensive wheels
Today's Daily special (April 29, 2011) is Menzerna Micro Finish (PO85RD Polish).
Regular Price for 32 oz is $34.99. Today's price is $26.30!
  • When you want the absolute maximum depth and gloss, finish your polishing with PO85RD
  • Works best after correcting paint imperfections with more aggressive polishes
  • Easy to work with, with long work times and easy removal when properly broken down
  • Most commonly applied with a crimson, black or blue finishing pad
Today's Daily special (May 2, 2011) is Lake Country Snappy Clean Pad Cleaner.
Regular Price is $1.49. Today's price is $1.10!
  • A citrus degreaser designed to help release product and contamination from foam pads
  • Simply pour into a 5 gallon bucket of water and allow your foam pads and applicators to soak
  • To further the cleaning, massage the pads while soaking, rinse with pressured water, repeat
Today's Daily special (May 4, 2011) is Surbuf R Series MicroFingers Buffing Pads.
Regular Price for 2x 6.5" is $14.99. Today's price is $11.09!
Regular Price for 2x 5.5" is $11.99. Today's price is $8.87!
Regular Price for 2x 4" is $7.99. Today's price is $6.94!
  • Perfect match for Porter Cable users with Meguiar's M105
  • Read a professionals recommendations on how-to use Surbuf pads properly
  • Each pack comes with 2 pads!
Today's Daily special (May 5, 2011) is
Optimum
Opti-Mitt 8" Foam Wash Mitt
Regular Price is $15.99. Today's price is $11.67!
  • Optimum Opti-Mitt 8" Foam Wash Mitt works great with the Optimum No
    Rinse or any auto shampoo
  • Two sided wash mitt with ultra soft black foam for washing and a
    firmer yellow foam for scrubbing
  • 85-90 pores per square inch makes it incredibly porous and safe to wash with
by signing up for
Today's Daily special (May 6, 2011) is 303 Fabric & Vinyl Cleaner.
Regular Price for 32 oz is $14.99. Today's price is $10.79!
Regular Price for 128 oz is $42.99. Today's price is $31.81!
  • Concentrated all purpose cleaner for carpets, upholstery, vinyl, rubber, leather, plastic and much more
  • Cleaning action increases with warm water, agitation, and longer dwell time
  • Safely removes oil, grease, ink, coffee, tea, wine, juice, blood, and tons more
  • Dilute into a 22oz empty spray bottle or a handy 4oz pump spray bottle
Today's Daily special (May 8, 2011) is Optimum Car Wax.
Regular Price for 17 oz is $14.99. Today's price is $10.79!
Regular Price for 128 oz is $39.99. Today's price is $28.79!
  • One of the best spray on waxes that is super easy to apply and remove
  • Provides that WOW factor with strong protection!
  • Perfect for maintaining your vehicles gloss and protection after a wash
  • High quality professional detailers love it!
Today's Daily special (May 9, 2011) is Chemical Guys Black Light Hybrid Radiant Finish.
Regular Price for 16 oz is $27.99. Today's price is $20.85!
  • Incredibly deep reflection that makes any color paint look great
  • Get the protection of a sealant with the gloss of a high end wax or glaze
  • WARNING Insane Gloss Levels!
  • Extremely easy to apply and remove
Today's Daily special (May 10, 2011) is TUF SHINE Black Restore Kit.
Regular Price is $19.99. Today's price is $14.59!
  • Restores trim, moldings, bumpers, etc. so they are dark and natural looking
  • Applies in minutes and the shine truly lasts!
  • Vibrant black finish makes the trim look like new
  • Apply the TUF SHINE Tire Clearcoat on top of it to preserve the new look!
  • Comes with a FREE TUF SHINE Applicator Sponge
Today's Daily special (May 11, 2011) is Optimum Power Clean.
Regular Price for 17 oz is $11.99. Today's price is $8.93!
Regular Price for 128 oz is $35.99. Today's price is $26.27!
  • A versatile degreaser that can be used on a wide variety of surfaces
  • Powerful concentrated formula can be diluted up to a 3:1 ratio for even more value
  • Perfect for degreasing tires, wheel wells, engine bays, stubborn contamination and to clean carpets
Today's Daily special (May 12, 2011) is Chemical Guys 50/50 Limited Series Concourse Paste Wax.
Regular Price for 8 oz is $59.99. Today's price is $46.39!
  • Bang for the buck, one of the best carnauba waxes we offer
  • Offers outstanding depth and gloss as well as sharp reflections on any colored vehicle, light, dark, metallic or non-metallic
  • Easy to apply and remove when applied properly, which is as thin as possible
  • Best applied with a foam applicator pad and removed with a microfiber towel
Today's Daily special (May 13, 2011) is Poorboy's World Wheel Sealant.
Regular Price for 8 oz is $19.99. Today's price is $14.79!
  • Properly protect any wheel finish and minimize the amount of brake dust and road contamination
  • Easily clean and maintain your wheels to a like new condition when protected with Wheel Sealant
  • One jar will last dozens of applications when applied correctly. The thinner the coat the better.
  • Cleans, restores, protects and enhances gloss all in one simple step.
  • Very easy to apply and remove. Once removed, the surface of your wheels is very slick.
  • Apply with a foam applicator pad and remove with a clean microfiber towel
Today's Daily special (May 16, 2011) is Lake Country White Polishing Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.29!
Regular Price for 5.5 inch is $8.99. Today's price is $6.56!
Regular Price for 4 inch is $4.99. Today's price is $3.59!
  • A polishing pad designed to remove minor surface imperfections with an abrasive polish on a buffer
  • Menzerna PO106FF polish is one of the most popular products to use with the white pad
Today's Daily special (May 17, 2011) is Poorboy's World Spray & Wipe (S&W).
Regular Price for 16 oz is $8.99. Today's price is $6.99!
Regular Price for 32 oz is $14.99. Today's price is $11.09!
Regular Price for 128 oz is $32.99. Today's price is $27.66!
  • Quick and easy waterless wash product for lightly contaminated vehicles, an excellent clay bar lubricant and perfect for quick clean ups
  • Extremely versatile cleaning product that is a favorite amongst professional detailers and enthusiasts
  • Perfect product to keep in your glove compartment to clean up emergency bird bombs, sap, tar, etc.
  • Best applied with a plush microfiber towel to minimize any micro-marring in the paint
  • For maximum efficiency and convenient storage use in a 4oz pump spray bottle
Today's Daily special (May 18, 2011) is Poorboy's World Wheel Sealant.
Regular Price for 8 oz is $19.99. Today's price is $14.89!
Today's Daily special (May 19, 2011) is Einszett 1Z Atomizer Pump Sprayer.
Regular Price for 1.5 Liter is $30.99. Today's price is $22.00!
  • Evenly and accurately dispense you favorite liquid products in those hard to reach areas
  • Pump action primes the sprayer but you control the flow with the touch of the trigger
  • Made of high quality, chemical resistant plastic
