Today's Daily special (May 20, 2011) is Stoner Tarminator.
Regular Price for 10 oz is $5.99. Today's price is $4.37!
  • Safely and effectively remove tar, grease and sap from painted surfaces
  • Simply spray Tarminator onto the effected area, let dwell for a minute or two, then wipe clean
  • Remember to protect the areas you use Tarminator on with a sealant or wax
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Today's Daily special (May 22, 2011) is Meguiar's DA Microfiber Cutting Disc Buffing Pad - 2 pack.
Regular Price for 5.5" is $21.99. Today's price is $16.05!
Regular Price for 6.25" is $23.99. Today's price is $17.03!
Regular Price for 3" is $11.99. Today's price is $8.63!
  • Combine this pad with the Meguiar's DA Microfiber Correction Compound for best results
  • Includes 2 Pads
  • Exceptional cutting power that removes swirls while finishing down crystal clear
  • A brand new technology that is changing the detailing world
  • Use a Porter Cable 7424 XP and the Meguiar's Professional Backing Plate
Today's Daily special (May 23, 2011) is Lake Country Hydro Tech Tangerine Ultra Fine Polishing Pad.
Regular Price for 6.5 inch is $11.99. Today's price is $8.75!
Regular Price for 5.5 inch is $9.99. Today's price is $7.44!
Regular Price for 4 inch is $5.99. Today's price is $4.31!
  • Great polishing power with the ability to finish down haze and marring free
  • Hydro Tech foam keeps more polish on the surface of the pad for long work time
  • Experience less dusting than traditional foam pads due to less product buildup
  • Save time and improve your results!
Today's Daily special (May 24, 2011) is Chemical Guys Maxi Suds II.
Regular Price for 16 oz is $8.99. Today's price is $6.56!
Regular Price for 128 oz is $25.99. Today's price is $19.36!
  • One of our best selling shampoos, lots of foam, great lubricity, and gentle cleaning power
  • An addicting cherry scent that makes washing your car a pleasure
  • Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
  • High sudsing formula makes this a great option to use in foam guns
Today's Daily special (May 25, 2011) is Lake Country Tire Dressing Applicator.
Regular Price is $1.99. Today's price is $1.48!
  • A perfect applicator pad to apply your favorite tire dressing
  • Firm foam design that will not shred like cheaper tire dressing applicator pads
  • Works excellent with Poorboy's Bold 'n Bright water based tire dressing
Today's Daily special (May 26, 2011) is Meguiar's All Purpose Cleaner Plus D103.
Regular Price for 128 oz is $13.99. Today's price is $9.93!
  • Best used to degrease engine bays, wheel wells, tires, interior clean ups, and much more
  • Effective even at a 10:1 dilution ratio making this an extremely good value
  • Works well in carpet extractors due to the low sudsing formula
  • Dilute and dispense using a 22 oz trigger spray bottle
Today's Daily special (May 27, 2011) is DI Accessories Gentle Fine Grade Clay.
Regular Price for 200 g is $18.99. Today's price is $13.86!
Regular Price for 100 g is $10.99. Today's price is $8.02!
  • Safely and effectively remove tar, sap, paint over spray and more
  • Fine grade clay bars will not mar your finish when used properly
  • We recommend using Dodo Juice Born Slippy as your clay lube
Today's Daily special (May 31, 2011) is Lake Country Hydro Tech Crimson Ultra Fine Finishing Pad.
Regular Price for 6.5 inch is $11.99. Today's price is $8.87!
Regular Price for 5.5 inch is $8.99. Today's price is $6.70!
Regular Price for 4 inch is $5.99. Today's price is $4.46!
  • Bring out the maximum depth and gloss of any polish
  • Use the Hydro Tech Crimson pads to apply finishing polishes, glazes or even sealants and waxes
  • Experience longer work time and less dusting with less product absorption
Today's Daily special (June 2, 2011) is Chemical Guys Jetseal 109.
Regular Price for 16 oz is $29.99. Today's price is $22.87!
  • One of our best selling sealants due to how well rounded of a product Jet Seal 109 is
  • Offers wax like depth and gloss, strong protection, ease of use, slick surface, and good durability
  • Works great on any colored vehicle, light, dark, metallic or non-metallic
  • Easy to apply and remove when applied properly, which is as thin as possible
  • For maximum durability, allow the sealant to cure for 24 hours prior to applying another coat
  • Best applied with a foam applicator pad and removed with a microfiber towel
  • When using a buffer, best applied with a blue fine finishing pad
Today's Daily special (June 3, 2011) is P21S Gel Wheel Cleaner.
Regular Price for 500 ml Kit is $17.99. Today's price is $14.21!
Regular Price for 1000 ml is $22.99. Today's price is $18.16!
Regular Price for 5000 ml is $99.99. Today's price is $80.16!
  • One of the safest, most effective, pH balanced wheel cleaners on the market
  • Gel based formula allows the product to penetrate vertical surfaces for a more effective cleaning
  • Perfect option for after market wheels as it is safe for virtually any wheel surface
  • Works best when an E-Z Detail Brush is used in conjunction with P21S Gel Wheel Cleaner
  • Follow up with Poorboy's World Wheel Sealant for wheels that are easier to maintain
Today's Daily special (June 6, 2011) is DI Microfiber Mini-Towel.
Regular Price for 6" x 7" is $2.99. Today's price is $2.15!
  • Works well at keeping glass and other surfaces clean and free of fingerprints and smudges
  • Perfect for keeping your sunglasses clean and free of fingerprints
Today's Daily special (June 7, 2011) is Chemical Guys Citrus Wash and Clear.
Regular Price for 16 oz is $8.99. Today's price is $6.38!
Regular Price for 128 oz is $24.99. Today's price is $20.34!
  • One of our most versatile shampoos that can strip off previous coats of protection or maintain it depending on dilution
  • A great sudsing shampoo makes it a hit in foam guns, lots of lubricity and powerful cleaners, makes it very effective
Today's Daily special (June 8, 2011) is TUF SHINE Tire Cleaner.
Regular Price for 22 oz is $9.99. Today's price is $7.29!
  • Excellent tire cleaner that releases road grime and old tire dressing residue
  • Use it with the TUF SHINE Tire Brush for optimal results
  • Make sure you use this cleaner before applying the TUF SHINE Tire Clearcoat
Today's Daily special (June 9, 2011) is Chemical Guys GlossWorkz Paintwork Cleanser.
Regular Price for 16 oz is $12.99. Today's price is $10.21!
Regular Price for 128 oz is $42.99. Today's price is $32.84!
  • Extends the protection of your sealant or wax while enhancing the gloss and depth of your paint
  • Used like a shampoo, GlossWorkz is a pH balanced, biodegradable, detergent free and non-toxic paintwork cleanser
  • Use 1 oz per 4 to 5 gallons of water
Today's Daily special (June 10, 2011) is Stoner Tarminator.
Today's Daily special (June 13, 2011) is Lake Country Orange Light Cutting Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.09!
Regular Price for 5.5 inch is $8.99. Today's price is $6.65!
Regular Price for 4 inch is $4.99. Today's price is $3.54!
  • A light cutting pad designed to remove moderate swirls and scratches with an abrasive polish
  • Menzerna Super Intensive Polish (SIP) is one of the most popular products to use with an orange pad
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Today's Daily special (June 15, 2011) is DI Accessories Sheepskin Wash Mitt w/no thumb.
Regular Price is $8.99. Today's price is $6.47!
  • Perfect wash medium to help minimize adding swirls and other imperfections to the paint
  • The natural fibers help pull contamination away from the surface without grinding them in
  • When done using, rinse any contamination using free flowing water than hang dry with leather hoop
  • For best results, use in conjunction with a 2 bucket wash system utilizing Grit Guard Inserts
Today's Daily special (June 16, 2011) is TUF SHINE Tire Brush.
Regular Price is $4.99. Today's price is $3.59!
  • Great for deep cleaning the tires
  • Use with the TUF SHINE Tire Cleaner or your favorite degreaser
  • Strong yet gentle bristles
  • Cleaning your tires is critical before applying any tire dressing, especially the TUF SHINE Tire Clearcoat
Today's Daily special (June 17, 2011) is DI Microfiber Great White Towel.
Regular Price for 16" x 24" is $6.99. Today's price is $5.21!
  • The perfect work horse towel, that can remove product residue, as well as apply liquid products
  • Larger 24" x 16" towel provides more surface area to collect and trap product, dust, dirt and more
  • Silk edging helps minimize adding imperfections to delicate surfaces
  • Always wash your microfiber products prior to first use, ideally with CG Microfiber Detergent
Today's Daily special (July 6, 2011) is Optimum Opti-Mitt 8" Foam Wash Mitt.
Regular Price is $15.99. Today's price is $11.35!
  • Optimum Opti-Mitt 8" Foam Wash Mitt works great with the Optimum No Rinse or any auto shampoo
  • Two sided wash mitt with ultra soft black foam for washing and a firmer yellow foam for scrubbing
  • 85-90 pores per square inch makes it incredibly porous and safe to wash with
Today's Daily special (July 7, 2011) is Lake Country Hydro Tech Crimson Ultra Fine Finishing Pad.
Regular Price for 6.5 inch is $11.99. Today's price is $8.93!
Regular Price for 5.5 inch is $8.99. Today's price is $6.38!
Today's Daily special (July 8, 2011) is Optimum Instant Detailer & Gloss Enhancer.
Regular Price for 17 oz is $9.99. Today's price is $7.39!
Regular Price for 32 oz is $17.99. Today's price is $13.52!
Regular Price for 128 oz is $49.99. Today's price is $39.44!
  • An outstanding quick detailer that enhances gloss and depth while increasing surface slickness
  • Easy to apply and remove streak free by misting into a plush microfiber towel and wiping your paint
  • Most commonly used after washing and drying your vehicle as a maintenance product
  • The 32oz and 128oz sizes are concentrated formulas to get even more bang for your buck
Today's Daily special (July 11, 2011) is DI Microfiber Black General Purpose Towel.
Regular Price for 16" x 16" is $3.99. Today's price is $2.97!
  • Finally a great black microfiber towel is available to detailers!
  • Paint safe and very effective towel inside and outside your vehicle
  • Wash with the Chemical Guys Microfiber Wash Cleaning Detergent to help the towels last for years in great condition
  • Store in a DI Accessories Reclosable Storage Bag to help prevent dust and dirt from collecting on the towel
Today's Daily special (July 12, 2011) is TUF SHINE Tire Appearance Kit.
Regular Price is $39.99. Today's price is $28.39!
  • The first ever semi-permanent tire dressing that looks amazing and truly lasts
  • One coat rich and dark finish, two or more coats is extremely glossy
  • Contains no oils or silicone's that can harm the tire
  • Will not sling off, dries to the touch in minutes and applies with ease
  • Tires look stunning and do not feel greasy or oily at all
Today's Daily special (July 13, 2011) is DI Brushes Lambs Wool Premium Wheel Brush.
Regular Price for 1" is $11.99. Today's price is $9.00!
Regular Price for 2" is $17.99. Today's price is $14.35!
Regular Price for 3" is $28.99. Today's price is $23.00!
  • Extremely soft and plush wheel brush that is safe on all wheels
  • Three different diameter's are available - 1", 2" & 3"
  • Safe on wheels that are painted, chrome, aluminum, clear coated, alloy, bare metals, matte, etc.
  • Also use it on your front bumper, grill, spoiler, handles, trim pieces and more
  • Metal free wheel brush that is safe and effective
