Today's Daily special (September 21, 2012) is Lake Country Hydro Tech Crimson Ultra Fine Finishing Pad.
Regular Price for 6.5 inch is $11.99. Today's price is $8.87!
Regular Price for 5.5 inch is $9.99. Today's price is $7.44!
Regular Price for 4 inch is $5.99. Today's price is $4.46!
Regular Price for 3 inch is $3.99. Today's price is $2.97!
  • Bring out the maximum depth and gloss of any polish
  • Use the Hydro Tech Crimson pads to apply finishing polishes, glazes or even sealants and waxes
  • Experience longer work time and less dusting with less product absorption
  • You can clean these pads with the Lake Country Snappy Clean Pad Cleaner
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Today's Daily special (September 24, 2012) is DI Accessories Sheepskin Wash Mitt without thumb.
Regular Price is $10.99. Today's price is $8.57!
  • All natural fibers makes it one of the safest wash mitts on the market
  • The natural fibers help pull contamination away from the surface without harming even the most delicate finishes
  • When done rinse any contamination away using free flowing water than hang dry with leather loop
  • Can be used with any shampoo or rinseless wash (i.e. Optimum No Rinse Wash & Shine New Formula (ONR))
Today's Daily special (September 25, 2012) is Optimum No Rinse Wash & Shine (ONR) New Formula 2012.
Regular Price for 32 oz is $15.99. Today's price is $11.67!
Regular Price for 128 oz is $39.99. Today's price is $28.39!
  • New formula launched in 2012 with more gloss, slicker feel and it releases contaminants better
  • Properly wash your car without the need for a hose or rinsing your vehicle
  • Use as a quick detailer and clay bar lubricant, mix 1 oz of ONR to 16oz of water
  • Favorite product of many high end detailers
  • Perfect for detailing on the go, those living in apartment complexes, washing in the winter, mobile detailing, etc.
Today's Daily special (September 26, 2012) is Lake Country Purple Foamed Wool Pad.
Regular Price for 6 inch is $11.99. Today's price is $8.75!
Regular Price for 5 inch is $9.99. Today's price is $7.44!
Regular Price for 4 inch is $5.99. Today's price is $4.79!
  • Our most cutting pad option, however, due to the wool strands, not as much heat is generated
  • Works best on high powered buffers, for fast, effective paint correction
  • Commonly used with a medium or heavy cut compound to remove deep imperfections and wet sanding marks
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Today's Daily special (September 27, 2012) is Lake Country Blue Grout Sponge.
Regular Price is $5.99. Today's price is $4.25!
  • One of the most popular used wash mediums by professional detailers
  • Very soft and durable, while being able to hold tons of suds and water helps reduce imperfections
  • One of the best features of the grout sponge is that it releases contamination very easily
  • For maximum results, use in combination with a Grit Guard bucket insert
Today's Daily special (September 28, 2012) is Dodo Juice Born to be Mild Shampoo.
Regular Price for 250 ml is $16.99. Today's price is $12.40!
  • One of the best shampoos we've tested in terms of lubricity and maximizing your coats of protection
  • Highly concentrated formula means only a little bit of product is needed to achieve great results
  • Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
Today's Daily special (October 1, 2012) is Dodo Juice Sour Power Gloss Enhancing Shampoo.
Regular Price for 250 ml is $13.99. Today's price is $10.78!
  • Perfect maintenance shampoo that enhances gloss and depth
  • Lots of lubricity and slickness to help minimize adding imperfections
  • Concentrated formula means only a little product is needed per wash
  • Best used with a grout sponge or sheepskin wash mitt
Today's Daily special (October 2, 2012) is Lake Country Orange Light Cutting Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.39!
Regular Price for 5.5 inch is $7.99. Today's price is $5.95!
Regular Price for 4 inch is $4.99. Today's price is $3.72!
  • A light cutting pad designed to remove moderate swirls and scratches with a medium polish
  • Works great with the Meguiar's Ultra-Cut Compound M105 and the Menzerna Super Intensive Polish SI 1500 (PO83)
  • We recommend caring for your pads with Lake Country Snappy Clean Pad Cleaner
  • Generally we recommend following up with a lighter pad and polish after
Today's Daily special (October 3, 2012) is Clay Magic Medium Grade Clay Bar.
Regular Price for 200 g is $24.99. Today's price is $18.24!
  • Remove embedded surface contamination that does not come off during the washing process
  • Medium grade bars will remove contamination quickly, however it may result in micro-marring
  • Properly preps your paints surface for polishing, using a glaze, sealant and / or wax
  • Helps you get the most out of any step you perform after using the clay bar
  • Follow up the medium grade clay bar with a finishing polish to remove any micro-marring
  • We recommend using Poorboy's Spray & Wipe as a clay bar lubricant and quick detailer
Today's Daily special (October 9, 2012) is DI Accessories DetailedImage.com License Plate Frame.
Regular Price is $5.99. Today's price is $4.46!
  • Black DetailedImage.com license plate frame with white lettering
  • "Clean Shine Protect" tag line
  • Thank you for your support!
Today's Daily special (October 10, 2012) is Chemical Guys Citrus Wash Wheel & Rim Cleaner.
Regular Price for 16 oz is $8.99. Today's price is $6.70!
  • Citrus based wheel cleaner that is safe to use on virtually any wheel surface
  • Concentrated solution makes this a great value as you can dilute it down 7:1 with water
  • Works best when an E-Z Detail Brush is used in conjunction with Wheel & Rim Citrus Cleaner
  • Protect your just cleaned wheels with Poorboy's World Wheel Sealant for easy maintenance
Today's Daily special (October 11, 2012) is Meguiar's DA Microfiber Finishing Disc Buffing Pad - 2 pack.
Regular Price for 5.5" is $21.99. Today's price is $15.61!
Regular Price for 6.25" is $23.99. Today's price is $17.75!
Regular Price for 3" is $13.99. Today's price is $10.35!
  • Use this pad to apply the Meguiar's DA Microfiber Finishing Wax
  • This item includes 2x DA Microfiber Finishing Disc Buffing Pads
  • Outstanding polishing power that provides a high level of gloss
  • Microfiber buffing pads are changing the way detailers work
  • Use it with the Meguiar's Professional Backing Plate, 5" Product Code: W67DA, 6" Product Code: S6BP
Today's Daily special (October 15, 2012) is Meguiar's Self Cleaning Dispenser Bottle.
Regular Price for 16oz is $3.49. Today's price is $2.58!
  • A self cleaning dispenser bottle that helps you work faster and neatly
  • Purchase larger sizes of your favorite products and pour them in a convenient dispenser bottle
  • Dispenses exactly the right amount of product each time
  • Will not clog and you won't get dried out product left in the tip
Today's Daily special (October 16, 2012) is Lake Country Yellow Cutting Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.29!
Regular Price for 5.5 inch is $7.99. Today's price is $5.83!
Regular Price for 4 inch is $4.99. Today's price is $3.64!
  • The most aggressive foam cutting pad, designed to remove the deepest swirls and scratches
  • Medium to heavy cutting polishes work great with a yellow cutting pad
  • You need to follow up with a lighter pad and polish combo afterward to remove haze on the surface
Today's Daily special (October 17, 2012) is Surbuf R Series MicroFingers Buffing Pads.
Regular Price for 2x 6.5" is $16.99. Today's price is $12.57!
Regular Price for 2x 5.5" is $13.99. Today's price is $10.42!
Regular Price for 2x 4" is $9.99. Today's price is $7.29!
  • Excellent polishing power with minimal haze left behind!
  • Read a professionals recommendations on how-to use Surbuf pads properly
  • Each box comes with 2 pads
  • The pads can be washed and re-used many times
  • Perfect match for Porter Cable users with Meguiar's M105
Today's Daily special (October 18, 2012) is DI Accessories Reclosable Storage Bag.
Regular Price for 24" x 24" is $2.99. Today's price is $2.23!
  • Simple solution for storing microfiber towels!
  • The large 24" x 24" size offers flexibility to accommodate dozens of towels
  • Thick reclosable bags make it a durable long term solution to storage needs
Today's Daily special (October 19, 2012) is Chemical Guys Citrus Wash.
Regular Price for 16 oz is $9.99. Today's price is $7.39!
Regular Price for 128 oz is $32.99. Today's price is $24.08!
  • Ultra concentrated paintwork cleaning shampoo designed to strip off protection to start fresh
  • Powerful concentrated formula only requires 1oz of product per gallon of water to effectively remove layers of protection
  • Works well in a Gilmour Foam Gun
Today's Daily special (October 22, 2012) is SONAX Leather Foam.
Regular Price for 400 ml is $14.99. Today's price is $11.17!
  • Cleaner, conditioner and protectant in one bottle
  • Foam action makes it excellent for perforated seats
  • Works on leather and leatherette seats
Today's Daily special (October 23, 2012) is DI Microfiber Autofiber Zero Cuff Chenille Wash Mitt.
Regular Price is $9.99. Today's price is $7.39!
  • Extra long strands and extra soft strands equals excellent results
  • Zero cuff design ensures your hand and wrist are comfortable
  • Paint safe and highly effective washing tool
  • Very cool looking design that is fun to wash with
Today's Daily special (October 24, 2012) is NanoSkin AutoScrub Fine Foam Pad.
Regular Price for 4" is $59.99. Today's price is $42.59!
Regular Price for 6" is $49.99. Today's price is $36.49!
  • The fastest way to safely deep clean your paint
  • Replaces the need for a clay bar while saving you time
  • Works with most orbital buffers with a hook and loop backing
  • Can be used 30 or more times so it's a better value than clay bars
  • Works great with the NanoSkin Glide
Today's Daily special (October 26, 2012) is Lake Country Snappy Clean Pad Cleaner.
Regular Price is $1.49. Today's price is $1.07!
  • A citrus degreaser designed to help release product and contamination from foam pads
  • Simply pour into a 5 gallon bucket of water and allow your foam pads and applicators to soak
  • To further the cleaning, massage the pads while soaking, rinse with pressured water, repeat
Today's Daily special (October 29, 2012) is DI Microfiber Car Wash Mitt.
Regular Price is $3.99. Today's price is $2.91!
  • Excellent wash mitt that is soft and paint safe
  • Very cost effective washing medium
  • Can be machine washed and dried afterward
Today's Daily special (October 30, 2012) is Raggtopp Convertible Top Cleaner - Fabric and Vinyl Tops.
Regular Price for 16 oz is $12.99. Today's price is $10.00!
  • Safely and effectively removes contamination from fabric and vinyl convertible tops
  • Endorsed by Haartz, the primary OEM for American and European make convertible tops
  • After treating the surface, we recommend agitating a stain with a brush or towel
Today's Daily special (October 31, 2012) is DI Accessories Disposable Floor Mat.
Regular Price for 10 pack is $5.99. Today's price is $4.25!
  • Durable mats to help prevent adding stains to clean carpets during a detail
  • Ensure your carpets look their best when you deliver the vehicle to your customer
