Today's Daily special (November 1, 2012) is DI Brushes Foam Brush.
Regular Price for 2" is $1.49. Today's price is $1.09!
  • Highest quality foam brush made proudly in the USA
  • Helps spread any detailing product uniformly
  • Very soft and gentle yet durable and strong
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Today's Daily special (November 2, 2012) is Menzerna Paint Refresh Professional Grade Detail Spray.
Regular Price for 22 oz is $23.99. Today's price is $17.03!
  • Cleans, shines, and protects your paint all in one step
  • Safe for painted surfaces, glass, plastic, chrome, etc.
  • Quickly removes dust, dirt, fingerprints, and light contamination
  • Leaves behind a layer of protection and anti-static properties
Today's Daily special (November 5, 2012) is Meguiar's Professional DA Polisher Backing Plate W67DA.
Regular Price for 5" is $19.99. Today's price is $15.53!
  • Soft core foam allows for easier maneuverability compared to stiffer backing plates
  • Works with any polisher with a 5/16th shaft (such as the Porter Cable 7424XP)
  • Durable one piece construction ensures a long life
  • Works best with 5.5" pads or larger
Today's Daily special (November 6, 2012) is Optimum Opti-Clean.
Regular Price for 18 oz is $8.99. Today's price is $6.65!
Regular Price for 32 oz is $15.99. Today's price is $11.67!
Regular Price for 128 oz is $39.99. Today's price is $29.79!
  • True waterless wash product that can be used to clean nearly every surface your car has in one simple step
  • The 32 oz and 128 oz version is concentrated and recommends a 3:1 dilution ratio (water:cleaner)
  • Versatile cleaner that makes cleaning quick and easy
Today's Daily special (November 7, 2012) is Lake Country Red Foam Applicator Pad.
Regular Price is $2.49. Today's price is $1.86!
  • Our softest and plushest foam applicator pad that has two distinct sides to apply products with
  • Most commonly used for applying last step products (LSPs), such as sealants and waxes
Today's Daily special (November 8, 2012) is Lake Country Tire Dressing Applicator.
Regular Price is $1.99. Today's price is $1.48!
  • A perfect applicator pad to apply your favorite tire dressing
  • Firm foam design that will not shred like cheaper tire dressing applicator pads
  • Works excellent with Poorboy's Bold 'n Bright water based tire dressing
Today's Daily special (November 9, 2012) is DI Accessories Yellow Foam Applicator Pad.
Regular Price is $1.49. Today's price is $1.07!
  • Most commonly used for applying polishes, glazes, sealants, and waxes!
  • Helps you apply a thin and even coating over any surface for maximum results
  • Washable and reusable so they provide a great value for years to come
Today's Daily special (November 12, 2012) is Meguiar's Self Cleaning Dispenser Bottle.
Regular Price for 16oz is $3.49. Today's price is $2.48!
  • A self cleaning dispenser bottle that helps you work faster and neatly
  • Purchase larger sizes of your favorite products and pour them in a convenient dispenser bottle
  • Dispenses exactly the right amount of product each time
  • Will not clog and you won't get dried out product left in the tip
Today's Daily special (November 13, 2012) is Lake Country Purple Foamed Wool Pad.
Regular Price for 6 inch is $11.99. Today's price is $8.63!
Regular Price for 5 inch is $9.99. Today's price is $7.29!
Regular Price for 4 inch is $5.99. Today's price is $4.79!
  • Our most cutting pad option, however, due to the wool strands, not as much heat is generated
  • Works best on high powered buffers, for fast, effective paint correction
  • Commonly used with a medium or heavy cut compound to remove deep imperfections and wet sanding marks
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Today's Daily special (November 14, 2012) is DI Accessories Detailed Image Kneeling Pad.
Regular Price for 12" x 12" is $5.99. Today's price is $4.93!
  • Use it as a kneeling pad or as a seat cushion
  • It's weatherproof and durable!
  • Thin design yet very strong for great support
  • Proudly display your love of Detailed Image!
Today's Daily special (November 15, 2012) is Menzerna Micro Polish SF 4500 (PO85RD).
Regular Price for 32 oz is $34.99. Today's price is $26.07!
  • When you want the absolute maximum depth and gloss, finish your polishing with SF 4500
  • Works great alone or after correcting paint imperfections with more aggressive polishes
  • Easy to work with, with long work time and easy removal
  • Most commonly applied with a crimson, black or blue finishing pad
Today's Daily special (November 16, 2012) is DI Microfiber Micro-Restore Microfiber Detergent Concentrate.
Regular Price for 32 oz is $14.99. Today's price is $11.09!
Regular Price for 128 oz is $34.99. Today's price is $25.54!
  • Microfiber, cotton, chamois and towel revitalizer
  • Breaks down heavy wax, oil and grease
  • Contains no bleach or fabric softeners
  • Use 2 ounces for full loads or 1 ounce for smaller loads
  • Biodegradable
Today's Daily special (November 19, 2012) is DI Brushes Boar's Hair Detailing Brush.
Regular Price for 1" is $15.99. Today's price is $12.63!
Regular Price for 1.25" is $17.99. Today's price is $13.80!
  • Use it to clean your wheels, exterior trim and so much of the interior
  • Ultra soft boar's hair fibers make it safe to use everywhere
  • Very durable design and fibers so you can use this brush for years
  • Helps clean tough to reach areas safely and easily
Today's Daily special (November 20, 2012) is Gilmour Foamaster II Foam Gun.
Regular Price for 1/4 Gallon Tank is $59.99. Today's price is $44.39!
  • Helps minimize the addition of new imperfections by softening and separating contaminants before using your mitt
  • Pre-soak your car with a layer of sudsy shampoo instead of using your mitt on dry paint
  • Helps get shampoo in those hard to reach areas, such as in the wheel wells and engine bay
  • Change the dilution ratio with the spin of a dial on the Gilmour Foamaster II Foam Gun
Today's Daily special (November 21, 2012) is Chemical Guys LAVA Luminous Glow Infusion Wax.
Regular Price for 8.2 oz is $69.99. Today's price is $51.09!
  • The ultimate combination of shine, protection and ease of use!
  • A technologically advanced wax utilizing a color enhanced formula for more gloss on any and every color paint
  • Durable protection that is perfect for warm climates, it can resist temperatures 300 degrees F
  • Ridiculously easy to apply and remove, for best value and results apply a thin coat
  • The scent is just amazing, you'll be tempted to eat it but please don't
Today's Daily special (November 23, 2012) is TUF SHINE Tire Appearance Kit.
Regular Price is $39.99. Today's price is $29.79!
  • The first ever semi-permanent tire dressing that looks amazing and truly lasts
  • One coat rich and dark finish, two or more coats is extremely glossy
  • Contains no oils or silicone's that can harm the tire
  • Will not sling off, dries to the touch in minutes and applies with ease
  • Tires look stunning and do not feel greasy or oily at all
Today's Daily special (November 26, 2012) is Chemical Guys E-zyme Natura.
Regular Price for 8 oz is $274.99. Today's price is $200.74!
  • Our finest carnauba wax in terms of depth, gloss, sharpness of reflections, and water beading
  • Made from some of the finest natural ingredients which makes this wax eco friendly
  • Easy to apply and remove when applied properly, which is as thin as possible
Today's Daily special (November 27, 2012) is DI Microfiber Great White Towel.
Regular Price for 16" x 24" is $6.99. Today's price is $5.17!
  • The perfect work horse towel, that can remove product residue, as well as apply liquid products
  • Larger 24" x 16" towel provides more surface area to collect and trap product, dust, dirt and more
  • Silk edging helps minimize adding imperfections to delicate surfaces
  • Always wash your microfiber products prior to first use, ideally with CG Microfiber Detergent
Today's Daily special (November 28, 2012) is DI Accessories Reclosable Storage Bag.
Regular Price for 24" x 24" is $2.99. Today's price is $2.15!
  • Simple solution for storing microfiber towels!
  • The large 24" x 24" size offers flexibility to accommodate dozens of towels
  • Thick reclosable bags make it a durable long term solution to storage needs
Today's Daily special (November 29, 2012) is Glass Science Fog Clear.
Regular Price for 10 oz is $7.99. Today's price is $5.91!
  • Prevents fog from forming so you can drive safely
  • Helps maintain maximum visibility by blocking fog from forming on any glass surface
  • Amazing product to keep bathroom and shower mirrors free from fog!
Today's Daily special (November 30, 2012) is Meguia's DA Microfiber Finishing Disc Buffing Pad - 2 pack.
Regular Price for 5.5" is $21.99. Today's price is $15.61!
Regular Price for 6.25" is $23.99. Today's price is $17.75!
Regular Price for 3" is $13.99. Today's price is $10.42!
  • Use this pad to apply the Meguiar's DA Microfiber Finishing Wax
  • This item includes 2x DA Microfiber Finishing Disc Buffing Pads
  • Outstanding polishing power that provides a high level of gloss
  • Microfiber buffing pads are changing the way detailers work
  • Use it with the Meguiar's Professional Backing Plate, 5" Product Code: W67DA, 6" Product Code: S6BP
Today's Daily special (December 3, 2012) is Dodo Juice Orange Crush Soft Wax.
Regular Price for 250 ml is $69.99. Today's price is $52.14!
Regular Price for 30 ml is $13.99. Today's price is $9.93!
  • A Dodo Juice soft carnauba wax designed to work exceptionally well on warmer colored vehicles
  • Extremely easy to apply and remove, especially when applied in thin layers
  • Strong protection and tight water beading makes maintaining your vehicle a breeze afterwards
  • Can be applied with a foam applicator pad or literally with your bare hands
  • Dodo Juice soft waxes offer slightly more depth and gloss over the Dodo Juice hard waxes
  • Remove any Dodo Juice wax with a plush microfiber towel
Today's Daily special (December 4, 2012) is Chemical Guys Stripper Scent - Smell of Success.
Regular Price for 16 oz is $11.99. Today's price is $9.17!
  • Extra pleasant smell sure to please all!
  • This product comes with a happiness warning!
  • Active odor eliminators will subdue unpleasant smells at the source
Today's Daily special (December 5, 2012) is Chemical Guys Microfiber Wash Cleaning Detergent.
Regular Price for 16 oz is $8.99. Today's price is $6.70!
Regular Price for 128 oz is $32.99. Today's price is $25.50!
  • Restore your microfiber to a like new condition every wash
  • Helps extend the life of your microfiber towels by keeping them fresher longer
  • Works great with any microfiber product: towel, applicator, mitt, etc.
Today's Daily special (December 6, 2012) is Optimum Microfiber Cutting Pad.
Regular Price for 6.25" is $11.99. Today's price is $8.87!
Regular Price for 5.25" is $10.99. Today's price is $7.80!
Regular Price for 4.25" is $9.99. Today's price is $7.29!
Regular Price for 3.25" is $8.99. Today's price is $6.47!
  • Outstanding cutting pad that removes surface imperfections and finishes down extremely well
  • You can follow up with the Optimum Microfiber Polishing Pad and a lighter polish
  • Very durable design, will not delaminate
  • Can be machine washed or hand washed
  • Made in USA!
