Today's Daily special (May 5, 2014) is Chemical Guys Sofast Odor Eater.
Regular Price for 16 oz is $8.99. Today's price is $6.47!
  • Remove odors from your interior by killing the bacteria causing the foul smell
  • Leaves behind a fresh apple scent that lingers for days
  • To maximize your product, we recommend using a 4oz pump spray bottle to dispense
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Today's Daily special (May 6, 2014) is DI Microfiber Double Thick Edgeless Towel.
Regular Price for 16" x 16" is $5.99. Today's price is $4.37!
  • Edgeless design saves you time while improving results!
  • Very plush, long, and soft microfiber threads
  • Very durable design that can be machine washed
  • Can be used for virtually any detailing task
  • 470 GSM
Today's Daily special (May 7, 2014) is Blackfire Total Polish and Seal.
Regular Price for 16 oz is $19.99. Today's price is $14.59!
  • Cleans, shines and protects in one step!
  • Polishes the surface and leaves behind the Wet Diamond polymers for protection
  • You only need about one ounce per coat, so it's a great value!
  • Applies and removes with ease
  • Pleasant scent makes working with this product fun!
Today's Daily special (May 8, 2014) is 303 Aerospace Protectant.
Regular Price for 16 oz is $12.99. Today's price is $9.35!
Regular Price for 32 oz is $19.99. Today's price is $14.19!
Regular Price for 128 oz is $57.99. Today's price is $41.17!
Regular Price for 10 oz is $7.99. Today's price is $5.83!
  • An excellent UV protectant and dressing for vinyl, leather, rubber and plastic surfaces
  • Leaves behind a beautiful matte finish that is not greasy, shiny or oily
  • Treated surfaces resist dust, soiling, staining and also repel water
  • Most commonly used on interior dashboards, center consoles, door trim, leather seats, and in the engine bay
  • Works great on vinyl convertible tops, plastic rear windows, clear bras, and tonneau covers
  • For maximum efficiency use in a 4oz pump spray bottle and apply with a microfiber towel
Today's Daily special (May 9, 2014) is Leatherique Rejuvenator Oil.
Regular Price for 16 oz is $31.99. Today's price is $24.00!
Regular Price for 32 oz is $49.99. Today's price is $37.24!
Regular Price for 8 oz is $18.99. Today's price is $13.48!
  • Detailed Image's best leather care product to restore neglected, faded, hardened leather
  • Restores oils and proteins that are naturally found in leather for a soft and supple feel
  • Works best when allowed to penetrate leather for up to 48 hours, ideally in the heat
  • Using a hair drier to heat up the leather surface allows for maximum penetration and best results
  • Apply Rejuvenator Oil by massaging the product into the leather with your bare hands
  • Must be removed by following up with Leatherique Prestine Clean
Today's Daily special (May 12, 2014) is Stoner Tarminator.
Regular Price for 10 oz is $5.99. Today's price is $4.43!
  • Safely and effectively remove tar, grease and sap from painted surfaces
  • Simply spray Tarminator onto the effected area, let dwell for a minute or two, then wipe clean
  • Remember to protect the areas you use Tarminator on with a sealant or wax
Today's Daily special (May 13, 2014) is Chemical Guys Microfiber Wash Cleaning Detergent.
Regular Price for 128 oz is $32.99. Today's price is $24.58!
  • Restore your microfiber to a like new condition every wash
  • Helps extend the life of your microfiber towels by keeping them fresher longer
  • Works great with any microfiber product: towel, applicator, mitt, etc.
Today's Daily special (May 14, 2014) is Dodo Juice Red Mist Tropical Protection Detailer.
Regular Price for 250 ml is $16.99. Today's price is $12.57!
Regular Price for 500 ml is $29.99. Today's price is $22.19!
  • Extend the protection of any sealant or wax
  • Increase gloss and depth of your paint, perfect for after a wash
  • Promotes tight water beading which helps minimize water spots
  • Applies and removes easy with a plush microfiber towel
Today's Daily special (May 15, 2014) is Tuf Shine Tire Clearcoat.
Regular Price for 6 oz is $24.99. Today's price is $18.24!
Regular Price for 16 oz is $44.99. Today's price is $32.84!
  • The longest lasting tire shine we have ever tested, lasts several months at a minimum
  • 1 - 2 coats gives you a beautiful matte finish, 3+ coats gives you an incredibly glossy finish
  • Water based formula that is totally safe, no petroleum solvents, silicones or oils that can attract dust
  • Comes with applicator
  • To get the Tire Clearcoat and more check out the TUF SHINE Tire Appearance Kit
  • Withstands several pressure washing treatments and can be washed with gentle cleaners
Today's Daily special (May 16, 2014) is Stoner Invisible Glass.
Regular Price for 19 oz is $5.99. Today's price is $4.46!
  • Foam based glass cleaning formula that is ammonia free, making it safe on tinted windows
  • Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more from glass
  • Best applied with an all purpose microfiber towel, then wiped clean with a dry low nap microfiber towel
  • Do not apply in direct sunlight or hot glass, otherwise streaking may occur
Today's Daily special (May 20, 2014) is DI Microfiber Detailing Apron.
Regular Price is $19.99. Today's price is $14.39!
  • Protect your paint from metal and plastic clothing pieces
  • Made of ultra soft microfiber that is paint safe
  • One size fits all design
  • Two large pockets for easy access of any tools, products, or microfiber towels you are using
  • 300 GSM
Today's Daily special (May 21, 2014) is DI Brushes Fender and Grill Brush.
Regular Price is $4.99. Today's price is $3.54!
  • Safely remove built up dirt and grime from your grill
  • Soft natural tampico bristles will not mar or scratch the surface
  • 8.5" durable foam block handle
This week's Weekly Special is Lake Country Red Foam Applicator Pad.
Use Coupon Code WSREDFO2114 to receive it for Free. A $2.49 value! Min spend $10. Offer ends 5/27/14 at 11:59 PM EST.
  • Our softest and plushest foam applicator pad that has two distinct sides to apply products with
  • Most commonly used for applying last step products (LSPs), such as sealants and waxes
Today's Daily special (May 22, 2014) is Gilmour Brass Connector High Flow Shut-off Valve.
Regular Price is $7.99. Today's price is $5.75!
  • Easily kill water flow with a simple twist of a knob instead of walking back to the hose source
  • Perfect for removing your hose nozzle or foam gun to utilize the sheeting method
Today's Daily special (May 23, 2014) is DI Microfiber Micro-Restore Microfiber Detergent Concentrate.
Regular Price for 32 oz is $14.99. Today's price is $11.09!
Regular Price for 128 oz is $34.99. Today's price is $25.19!
  • Microfiber, cotton, chamois and towel revitalizer
  • Breaks down heavy wax, oil and grease
  • Contains no bleach or fabric softeners
  • Use 2 ounces for full loads or 1 ounce for smaller loads
  • Biodegradable
Today's Daily special (May 27, 2014) is DI Microfiber Black and Yellow Towel.
Regular Price for 16" x 16" is $4.99. Today's price is $3.54!
  • Two sided towel that is perfect for cleaning inside and out
  • Plush on one side with a shorter nap on the other
  • Tag less design with bounded edges for added durability
  • Safely and easily removes polishes, sealants, waxes, etc.
  • Can be cleaned with the Micro-Restore Microfiber Detergent Concentrate
  • 407 GSM
Today's Daily special (May 28, 2014) is DI Accessories reTHICKulous Wool Wash Mitt.
Regular Price is $34.99. Today's price is $26.07!
  • Extremely thick wash mitt that is unbelievably plush
  • One of the safest washing tools we've ever tested
  • Extra soft wool fibers provide a delicate cleaning that few if any other mitts can provide
  • Releases contaminants with ease in your rinse bucket
  • Premium wash mitt that provides a safe and effective washing
Today's Daily special (June 2, 2014) is DI Brushes Pet Hair Removal Brush.
  • Easily remove pesky pet hair from your interior carpets and upholstery
  • Rubber bristles use static electricity to attract and collect pet hair
  • Great for removing hair from furniture and carpets in your home too!
  • Handle can be used as a squeegee to remove water from windows
Today's Daily special (June 3, 2014) is DI Accessories Detailed Image Kneeling Pad.
Regular Price for 12" x 12" is $5.99. Today's price is $4.87!
  • Use it as a kneeling pad or as a seat cushion
  • It's weatherproof and durable!
  • Thin design yet very strong for great support
  • Proudly display your love of Detailed Image!
Today's Daily special (June 4, 2014) is DI Brushes Carpet Brush for Buffers.
Regular Price is $14.99. Today's price is $10.94!
  • Great for deep cleaning carpets using the added power of a buffer!
  • Packed with 7/8" long semi-stiff polyproplylene bristles
  • 5" diameter and durable hook and loop backing
  • Works great with the Lake Country DA 5" Backing Plate or the Lake Country Rotary 5" Backing Plate
Today's Daily special (June 5, 2014) is DI Accessories Universal Replacement Flip Top Caps.
Regular Price is $0.75. Today's price is $0.54!
  • Universal top that fits the majority of 16oz, 32oz, 500ml and 1000ml bottles
  • Spout helps control how much you pour out
  • Helps conserve product and save you money
  • Keep a few around the garage in case you break a cap
Today's Daily special (June 6, 2014) is Chemical Guys Extreme EZ-Creme Glaze with Acrylic Shine II.
Regular Price for 16 oz is $16.99. Today's price is $12.40!
  • The perfect prep step before applying a sealant to enhance the gloss and depth of any color paint, while hiding minor imperfections
  • The acrylic based formula makes it compatible with both sealants and waxes
  • Best applied with a foam applicator pad as thin as possible and removed with a microfiber towel
  • When using a buffer, best applied with a black finishing pad
Today's Daily special (June 9, 2014) is Optimum Opti-Bond Tire Gel.
Regular Price for 32 oz is $15.99. Today's price is $11.67!
Regular Price for 128 oz is $35.99. Today's price is $26.63!
  • Gel based tires dressing that applies easily and does not sling onto your paint
  • Can be applied in multiple layers for a glossier look or buffed down to a matte finish
  • We recommend using a Lake Country tire dressing applicator to apply Tire Shine
Today's Daily special (June 10, 2014) is Chemical Guys GlossWorkz Shampoo.
Regular Price for 16 oz is $12.99. Today's price is $9.61!
Regular Price for 128 oz is $42.99. Today's price is $32.97!
  • Extends the protection of your sealant or wax while enhancing the gloss and depth of your paint
  • Used like a shampoo, GlossWorkz is a pH balanced, biodegradable, detergent free and non-toxic paintwork cleanser
  • Use 1 oz per 4 to 5 gallons of water
Today's Daily special (June 11, 2014) is CarPro Iron X Iron Remover Cherry Scent.
Regular Price for 500 ml is $19.99. Today's price is $14.89!
Regular Price for 1000 ml is $32.99. Today's price is $24.58!
Regular Price for 4 L is $99.99. Today's price is $72.99!
  • This is the MUST have product for ALL detailers!
  • Remarkably quick and effective cleaner for the exterior paint and wheels
  • Mist Iron X on the exterior and watch it safely dissolve embedded iron deposits
  • pH balanced and gentle formula safe to use over virtually the entire exterior
  • Turns a deep and dark red color as it dissolves particles stuck to the surface
  • Cherry scented with improved formula!
  • Also available in Lemon Scent!
