Today's Daily special (June 12, 2014) is DI Brushes Wheel Wash Boar's Hair Brush.
Regular Price is $33.99. Today's price is $25.15!
  • Clean your wheel safely and easily!
  • Breaks up road grime and brake dust with ease
  • 50% more boar's hair bristles than many similar brushes
  • Safe on clear coated, anodized, polished, aluminum, painted, powder coated and chrome wheels
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Today's Daily special (June 13, 2014) is Chemical Guys Diablo Gel Rim and Wheel Cleaner.
Regular Price for 16 oz is $16.99. Today's price is $12.40!
  • pH balanced wheel cleaner safe on ALL wheel finishes and competes amongst the best wheel cleaners available
  • Powerful concentrated suspension allows for dilution of product without the loss of cleaning power, making it a great value
  • Perfect for high end professional detailers who detail expensive wheels
Today's Daily special (June 16, 2014) is Sonax Polymer Net Shield.
Regular Price for 210 ml is $27.99. Today's price is $19.87!
  • Aerosol based spray on sealant
  • Can be applied easily in minutes
  • Protects up to 6 months
  • Adds gloss and depth to your paint
Today's Daily special (June 17, 2014) is DI Accessories Razor Blade Holder with Soft Grip.
Regular Price is $2.99. Today's price is $2.15!
  • Perfect way to hold your plastic or metal razor blades
  • Easy way to remove stickers from paint, glass, license plates, etc.
  • All standard razor blades will fit this holder
  • Made in the USA
Today's Daily special (June 18, 2014) is Chemical Guys Signature Series Orange Degreaser.
Regular Price for 16 oz is $8.99. Today's price is $6.70!
  • A versatile degreaser that you can use all over your vehicle
  • Professional strength, super concentrated, citrus-based formula
  • Removes tough grease, grime, dirt and debris with ease
  • Works great on paint, engine bay, tires, rims, undercarriages etc.
  • Amazing value, you can dilute in Trigger Spray Bottle
Today's Daily special (June 19, 2014) is Chemical Guys Wet Mirror Finish.
Regular Price for 16 oz is $19.99. Today's price is $14.79!
  • Clean and protect your paint in one simple step while enhancing the gloss and depth
  • Easily apply by hand or with a buffer and remove with a quality microfiber towel to reveal a mirror like finish
  • Works great on both light and dark colored paint for a head turning finish
Today's Daily special (June 20, 2014) is DI Microfiber Glass Polishing Towel (Blue).
Regular Price for 16" x 16" is $5.99. Today's price is $4.46!
  • The ideal solution for achieving that streak free finish when caring for glass
  • Use a slow wiping motion, while applying some pressure to the glass polishing towel
  • The low, ultra thin nap ensures that there is no lint left behind on glass
  • Ideally, use a separate towel to apply your favorite glass cleaner and initially wipe dry
  • Always wash your microfiber products prior to first use and remove tags to ensure paint safe
  • 240 GSM
Today's Daily special (June 23, 2014) is Chemical Guys Mr. Pink.
Regular Price for 16 oz is $8.99. Today's price is $6.65!
Regular Price for 128 oz is $29.99. Today's price is $22.19!
  • Suds, Suds and more SUDS!
  • Extra slick for swirl free washing
  • pH neutral formula that is tough on dirt yet gentle on sealants or waxes
  • Safely and easily removes contamination from your paint
  • Great weekly maintenance shampoo
Today's Daily special (June 24, 2014) is Tuf Shine Tire Appearance Kit.
Regular Price is $39.99. Today's price is $29.59!
  • The first ever semi-permanent tire dressing that looks amazing and truly lasts
  • One coat rich and dark finish, two or more coats is extremely glossy
  • Contains no oils or silicone's that can harm the tire
  • Will not sling off, dries to the touch in minutes and applies with ease
  • Tires look stunning and do not feel greasy or oily at all
Today's Daily special (June 25, 2014) is Lake Country Hydro Tech Tangerine Ultra Fine Polishing Pad.
Regular Price for 6.5 inch is $11.99. Today's price is $8.87!
Regular Price for 5.5 inch is $9.99. Today's price is $7.29!
Regular Price for 4 inch is $5.99. Today's price is $4.25!
Regular Price for 3 inch is $3.99. Today's price is $2.95!
  • Great polishing power with the ability to finish down haze and marring free
  • Hydro Tech foam keeps more polish on the surface of the pad for long work time
  • Experience less dusting than traditional foam pads due to less product buildup
  • Clean pads with the Lake Country Snappy Clean Pad Cleaner
  • Commonly used with the Meguiar's Ultra Finishing Polish M205 and the Menzerna SF 4000 (PO106FA)
Today's Daily special (June 26, 2014) is Chemical Guys Silk Shine Dressing & Protectant.
Regular Price for 16 oz is $12.99. Today's price is $9.35!
  • Very versatile dressing that restores vinyl, rubber and tires to a beautiful low gloss finish
  • Properly protect your vinyl and rubber surfaces from UV fading with CG Silk Shine Dressing
  • To avoid over spray, we recommend misting Silk Shine Dressing into a microfiber towel to apply
  • We recommend using a 4oz pump spray bottle to apply a thin, even layer of dressing
Today's Daily special (June 27, 2014) is CarPro Reset Intensive Car Shampoo.
Regular Price for 500 ml is $14.99. Today's price is $11.56!
Regular Price for 1000 ml is $24.99. Today's price is $17.99!
  • The perfect shampoo to clean your paint without damaging an underlying coating layer!
  • Works great with all coatings (i.e. 22ple, Cquartz, C1, EXOv2, etc.)
  • Almost entirely made up of organic ingredients
  • Strong foaming cleaner, while still remaining mild and pH-Neutral
  • Economical 1:500 dilution ratio
Today's Daily special (June 30, 2014) is Lake Country Blue Grout Sponge.
Regular Price is $5.99. Today's price is $4.37!
  • One of the most popular used wash mediums by professional detailers
  • Very soft and durable, while being able to hold tons of suds and water helps reduce imperfections
  • One of the best features of the grout sponge is that it releases contamination very easily
  • For maximum results, use in combination with a Grit Guard bucket insert
Today's Daily special (July 1, 2014) is 303 Multi-Surface Cleaner.
Regular Price for 32 oz is $12.99. Today's price is $9.48!
Regular Price for 128 oz is $33.99. Today's price is $24.13!
  • Great cleaner for your carpets, dashboard, doors, console and more!
  • Cleaning action increases with warm water, agitation, and longer dwell time
  • Safely removes oil, grease, ink, coffee, tea, wine, juice, blood and more
  • Dilute up to 10:1 in a Spray Bottle for maximum value
  • Formerly known as the 303 Fabric & Vinyl Cleaner
Today's Daily special (July 2, 2014) is Meguiar's Generic Spray Bottle.
Regular Price for 32 oz is $2.99. Today's price is $2.23!
  • Dilute your favorite cleaning chemicals in this bottle
  • Chemical resistant bottle is OSHA compliant
  • Pick up this bottle and a DI Accessories Chemical Resistant Spray Trigger
  • Bottle is color coded and has a spot for you to label it accordingly
Today's Daily special (July 3, 2014) is Dodo Juice Red Mist Tropical Protection Detailer.
Regular Price for 250 ml is $16.99. Today's price is $13.97!
Regular Price for 500 ml is $29.99. Today's price is $25.56!
  • Extend the protection of any sealant or wax
  • Increase gloss and depth of your paint, perfect for after a wash
  • Promotes tight water beading which helps minimize water spots
  • Applies and removes easy with a plush microfiber towel
Today's Daily special (July 7, 2014) is Sonax Polymer Net Shield.
Regular Price for 210 ml is $27.99. Today's price is $20.85!
Today's Daily special (July 8, 2014) is Lake Country Snappy Clean Boost Pad Cleaner.
Regular Price is $1.49. Today's price is $1.11!
  • A citrus degreaser designed to help release product and contamination from foam pads
  • Simply pour into a 5 gallon bucket of water and allow your foam pads and applicators to soak
  • To further the cleaning, massage the pads while soaking, rinse with pressured water, repeat
Today's Daily special (July 9, 2014) is DI Microfiber Grey on Gray Towel.
Regular Price for 16" x 16" is $3.99. Today's price is $2.91!
  • Tight weave and low/medium nap for easy removal of polish, wax, sealants, etc
  • Can be used to clean and apply virtually any product
  • Use it on the vehicle's interior and around the home!
  • Soft fibers are safe and effective!
  • Can be washed hundreds of times, we recommend Micro-Restore Microfiber Detergent Concentrate
  • 307 GSM
Today's Daily special (July 10, 2014) is DI Accessories Foam Lance.
Regular Price is $89.99. Today's price is $65.69!
  • Spray tons of suds all over your exterior quickly and easily
  • Pre-soaking the paint helps make washing safer and more effective
  • Can be used with most pressure washers from 700 - 3000 PSI
  • Adjustable nozzle for various spray patterns
Today's Daily special (July 11, 2014) is Optimum Instant Detailer & Gloss Enhancer.
Regular Price for 17 oz is $9.99. Today's price is $7.09!
Regular Price for 32 oz is $19.99. Today's price is $14.89!
Regular Price for 128 oz is $59.99. Today's price is $43.19!
  • An outstanding quick detailer that enhances gloss and depth while increasing surface slickness
  • Easy to apply and remove streak free by misting into a plush microfiber towel and wiping your paint
  • Most commonly used after washing and drying your vehicle as a maintenance product
  • The 32oz and 128oz sizes are concentrated formulas to get even more bang for your buck
Today's Daily special (July 14, 2014) is Chemical Guys Diablo Gel Rim and Wheel Cleaner.
Regular Price for 16 oz is $16.99. Today's price is $12.23!
Today's Daily special (July 15, 2014) is Chemical Guys CG Speed Wipe (Anti-Static) Quick Detailer.
  • An outstanding quick detailer that is perfect to use after a maintenance wash and dry
  • Leaves behind a slick surface that is anti-static which helps minimize dust build ups
  • Best applied with a plush microfiber towel to minimize any micro-marring in the paint
Today's Daily special (July 16, 2014) is Rupes White Finishing Foam Pad.
Regular Price for 4" is $9.99. Today's price is $7.09!
Regular Price for 6" is $12.99. Today's price is $9.61!
Regular Price for 7" is $14.99. Today's price is $11.09!
  • Bring back that deep glossy finish safely and easy!
  • Removes ultra fine imperfections and finishes down extremely well
  • Pairs great with the Rupes Diamond Ultra Fine Gel Polish
This week's Weekly Special is DI Accessories Fine Grade Clay - 100 g.
Use Coupon Code WSFINEG2914 to receive it for Free. A $10.99 value! Min spend $15. Offer ends 7/22/14 at 11:59 PM EST.
  • Safely remove road grime, brake dust, tar, sap, paint over spray and more
  • Fine grade clay bars are gentle on your exterior paint
  • We recommend using Dodo Juice Born Slippy or Poorboy's World Spray & Wipe as your clay lube
  • Can be used on brand new cars to older vehicles with light to medium build ups
