Today's Daily special (March 17, 2016) is DI Microfiber Black and Yellow Towel.
Regular Price for 16" x 16" is $4.99. Today's price is $3.17!
  • Two sided towel that is perfect for cleaning inside and out
  • Plush on one side with a shorter nap on the other
  • Tag less design with bounded edges for added durability
  • Safely and easily removes polishes, sealants, waxes, etc.
  • Can be cleaned with the Micro-Restore Microfiber Detergent Concentrate
  • 407 GSM
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Today's Daily special (March 18, 2016) is Lake Country Hydro Tech Crimson Ultra Fine Finishing Pad.
Regular Price for 6.5" is $11.99. Today's price is $7.23!
Regular Price for 5.5" is $9.99. Today's price is $6.18!
Regular Price for 4" is $5.99. Today's price is $3.74!
Regular Price for 3" is $3.99. Today's price is $2.47!
Regular Price for 2" is $3.99. Today's price is $2.41!
  • Bring out the maximum depth and gloss of any polish
  • Use the Hydro Tech Crimson pads to apply finishing polishes, glazes or even sealants and waxes
  • Experience longer work time and less dusting with less product absorption
  • You can clean these pads with the Lake Country Snappy Clean Pad Cleaner
Today's Daily special (March 21, 2016) is DI Accessories Detailed Image Kneeling Pad.
Regular Price for 12" x 12" is $5.99. Today's price is $4.62!
  • Use it as a kneeling pad or as a seat cushion
  • It's weatherproof and durable!
  • Thin design yet very strong for great support
  • Proudly display your love of Detailed Image!
Today's Daily special (March 22, 2016) is Scangrip I-View.
Regular Price is $75.99. Today's price is $59.57!
  • Works great for polishing inspection, painting, or as a general work light
  • Hands free and comfortable headlamp design
  • Up to 6 hours of operating time, from rechargable battery
  • Lightweight and durable construction
  • One year manufacturer warranty
Today's Daily special (March 23, 2016) is Rupes Blue Coarse Foam Pad.
Regular Price for 4" is $9.99. Today's price is $6.59!
Regular Price for 6" is $12.99. Today's price is $8.69!
Regular Price for 7" is $14.99. Today's price is $9.65!
  • Remove heavy imperfections, swirl marks, scratches, etc. with ease!
  • Works great with your favorite corrective compound or the Rupes Zephir Gloss Coarse Gel Compound
  • Extremely durable design
Today's Daily special (March 28, 2016) is DI Accessories Medium Grade Clay Bar.
Regular Price for 100 g is $10.99. Today's price is $5.34!
  • Use to remove stubborn contamination such as tree sap, tar, rail dust and paint overspray
  • Large enough to break into several pieces for multiple uses
  • We recommend Dodo Juice Born Slippy as a clay lube
  • If you drop a piece of clay, throw it away!
Today's Daily special (March 29, 2016) is DI Brushes Scrub Brush.
Regular Price is $4.99. Today's price is $3.12!
  • Great for deep cleaning carpets, mats, fabric convertible tops, fabric seats, and more!
  • Strong durable bristles break down contamination with ease
  • Easy to hold Iron-style handle allows for maximum comfort
  • Packed with 1.12" crimped polypropylene bristles
Today's Daily special (March 30, 2016) is Meguiar's Soft Buff DA Foam Finishing Disc.
Regular Price for 5" is $10.99. Today's price is $7.56!
Regular Price for 6" is $12.99. Today's price is $8.94!
  • High quality finishing disc to remove light imperfects and leave behind an amazing finish!
  • Low operating temperature and clarity when used with your favorite finishing polish
  • Thin 17.5mm disc design
  • Recommended on the MT300 or any other DA Polisher
  • Perfect fit on the Soft Buff DA Backing Plate
Today's Daily special (April 1, 2016) is Lake Country Blue Hybrid Foamed Wool Pad.
Regular Price for 6" is $11.99. Today's price is $7.84!
  • Remove heavy imperfections with ease!
  • Similar to the Purple Foamed Wool Pad, but sheds less and cut better!
  • Commonly used with a medium or heavy cut compound
Today's Daily special (April 4, 2016) is Dodo Juice Born to be Mild Shampoo.
Regular Price for 250 ml is $16.99. Today's price is $12.88!
  • One of the best shampoos we've tested in terms of lubricity and maximizing your coats of protection
  • Highly concentrated formula means only a little bit of product is needed to achieve great results
  • Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
Today's Daily special (April 5, 2016) is DI Accessories "Do Not Wash Rear View Mirror Hang Tag".
Regular Price is $2.99. Today's price is $1.54!
  • Protect your car from dealer induced swirls!
  • Made of sturdy .035" white polyethylene
  • Measures 3.375" x 9"
  • Throw it in your glove compartment for easy storage!
Today's Daily special (April 6, 2016) is DI Accessories Bug Sponge.
Regular Price is $2.99. Today's price is $1.77!
  • Remove dirt, grime, bug splatter, and more
  • High quality, soft, durable foam
  • Easily rinses clean
Today's Daily special (April 7, 2016) is Lake Country HD Orbital Blue Cutting Pad.
Regular Price for 6" is $13.99. Today's price is $9.67!
Regular Price for 7" is $15.99. Today's price is $11.05!
  • The most aggressive LC HD Pad, designed to remove heavy scratches, swirls, and defects.
  • Runs 10% cooler than traditional Lake Country pads
  • Perfectly balanced, cushioned, and features thinner foam
  • Removes imperfections easily while reducing hazing and marring from heavier polishing compounds
Today's Daily special (April 8, 2016) is Optimum Hyper Spray Compound.
Regular Price for 18 oz is $29.99. Today's price is $20.74!
  • Innovative compound that will remove moderate to deep imperfections in an easy to apply solution
  • Work inside or outside with long work times and minimal dusting
  • Typically used with cyan, orange, yellow, cyan or purple foamed wool pads
Today's Daily special (April 11, 2016) is Lake Country Blue Fine Finishing Pad.
Regular Price for 6.5" is $9.99. Today's price is $6.19!
Regular Price for 5.5" is $7.99. Today's price is $4.93!
Regular Price for 4" is $4.99. Today's price is $3.40!
Regular Price for 3" is $3.99. Today's price is $2.79!
  • Our softest foam pad, the blue fine finishing pad, designed to apply ultra fine polishes, sealants and liquid waxes
  • Also commonly used to burnish the paint to a high gloss with a gloss enhancing polish
  • Blackfire Wet Diamond All Finish Paint Protection is one of the most popular sealants to apply with a blue pad
  • We recommend caring for your pads with Lake Country Snappy Clean Pad Cleaner
  • If you want to jewel or burnish the paint for some extra shine combine with the Menzerna Micro Polish SF 4500 (PO85RD)
Today's Daily special (April 12, 2016) is CarPro Iron X Iron Remover Cherry Scent.
Regular Price for 500 ml is $18.99. Today's price is $15.19!
Regular Price for 1000 ml is $29.99. Today's price is $23.99!
Regular Price for 4 L is $99.99. Today's price is $79.99!
  • This is the MUST have product for ALL detailers!
  • Remarkably quick and effective cleaner for the exterior paint and wheels
  • Mist Iron X on the exterior and watch it safely dissolve embedded iron deposits
  • pH balanced and gentle formula safe to use over virtually the entire exterior
  • Turns a deep and dark red color as it dissolves particles stuck to the surface
  • Cherry scented with improved formula!
  • Also available in Lemon Scent!
Today's Daily special (April 13, 2016) is DI Microfiber Deep Blue Towel.
Regular Price for 16" x 16" is $8.99. Today's price is $6.00!
  • Safely remove excess product or contamination from any surface
  • One of our thickest and most plush microfiber towels
  • Safe to use on the interior or exterior of your car, along with anywhere in your home
  • Extra thick and weighs a whopping 5.4 ounces
  • 1100 GSM
Today's Daily special (April 14, 2016) is Leatherique Rejuvenator Oil.
Regular Price for 16 oz is $31.99. Today's price is $24.62!
Regular Price for 32 oz is $49.99. Today's price is $39.38!
Regular Price for 8 oz is $19.99. Today's price is $13.76!
  • Detailed Image's best leather care product to restore neglected, faded, hardened leather
  • Restores oils and proteins that are naturally found in leather for a soft and supple feel
  • Works best when allowed to penetrate leather for up to 48 hours, ideally in the heat
  • Using a hair drier to heat up the leather surface allows for maximum penetration and best results
  • Apply Rejuvenator Oil by massaging the product into the leather with your bare hands
  • Must be removed by following up with Leatherique Prestine Clean
Today's Daily special (April 15, 2016) is CarPro Inside Leather & Interior Cleaner.
Regular Price for 500 ml is $17.99. Today's price is $14.39!
  • All purpose interior cleaner with foaming formula
  • Cleans leather, vinyl, plastic, carpets, and much more
  • Pleasant fresh scent that is not overpowering
Today's Daily special (April 18, 2016) is Rupes Quarz Gloss Medium Gel Compound.
Regular Price for 250 ml is $15.99. Today's price is $10.99!
  • Remove moderate imperfections while finishing down extremely well!
  • Works great with the Rupes Green Medium Foam Pad
  • For a deep glossy finish follow up with the Rupes Keramik Gloss Fine Gel Polish or the Rupes Diamond Ultra Fine Gel Polish
  • Each Rupes Polish has a color coded cap to help you choose the correct polishing pad to pair with each polish!
Today's Daily special (April 20, 2016) is Rupes Diamond Ultra Fine Gel Polish.
Regular Price for 250 ml is $14.99. Today's price is $10.68!
  • Remove ultra fine imperfections and restore that deep glossy finish!
  • Pair with the Rupes White Finishing Foam Pad
  • Perfect maintenance polish that is safe to use as often as you desire!
Today's Daily special (April 21, 2016) is Lake Country Black Finishing Pad.
Regular Price for 6.5" is $9.99. Today's price is $6.14!
Regular Price for 5.5" is $7.99. Today's price is $4.87!
Regular Price for 4" is $4.99. Today's price is $3.35!
Regular Price for 3" is $3.99. Today's price is $2.74!
  • A finishing pad is designed to bring the paint to its maximum depth and gloss when combined with a finishing polish
  • Used to apply a light polish, finishing polish, glaze, sealant or liquid wax
  • Menzerna SF 4500 (PO85RD) is one of the most popular polishes to use with a black finishing pad
  • We recommend cleaning your pads with Lake Country Snappy Clean Pad Cleaner
Today's Daily special (April 26, 2016) is Chemical Guys Maxi Suds II.
Regular Price for 16 oz is $8.99. Today's price is $5.57!
Regular Price for 128 oz is $25.99. Today's price is $16.01!
Regular Price for 64 oz is $17.99. Today's price is $11.80!
  • One of our best selling shampoos, lots of foam, great lubricity, and gentle cleaning power
  • An addicting cherry scent that makes washing your car a pleasure
  • High sudsing formula makes this a great option to use in foam guns
Today's Daily special (April 27, 2016) is CarPro HydrO2 Foam.
Regular Price for 500 ml is $19.99. Today's price is $15.99!
  • Wash and protect your paint in one easy to use product
  • Removes contamination and leaves behind strong protection
  • pH Neutral and no cure time needed
  • Gloss and Hydrophobic durability of 3 months or more
