Today's Daily special (April 28, 2016) is Meguiar's Plastic and Vinyl Coating D45.
Regular Price for 10 oz is $7.99. Today's price is $5.24!
  • Protect and enhance your plastic and vinyl pieces
  • Long lasting protection from cracking and fading
  • Leaves behind a clean natural looking dark finish
  • Easy to apply!
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Today's Daily special (April 29, 2016) is Grit Guard Grit Guard Insert.
Regular Price for BLUE is $9.99. Today's price is $6.43!
Regular Price for RED is $9.99. Today's price is $6.45!
Regular Price for WHITE is $9.99. Today's price is $6.40!
  • A must have for any detailer. Minimize adding imperfections during the wash phase
  • Simply place the Grit Guard insert into the bottom of a bucket to trap dirt and contamination
  • Gently glide your wash medium over the Grit Guard insert to release contamination
  • Excellent results with the Lake Country Grout Sponge paired with a Grit Guard bucket insert
  • Works great with any of the DI Accessories Buckets
Today's Daily special (May 2, 2016) is DI Brushes Caliper Wheel Woolies.
Regular Price for 2" is $20.99. Today's price is $15.41!
Regular Price for 3" is $23.99. Today's price is $18.04!
  • Extremely soft and plush wheel brush with a 45 degree bend
  • Safe on painted, chrome, aluminum, clear coated, alloy, bare metals, matte wheels, etc.
  • 45 degree bend allows you to reach behind spokes, calipers, rims, etc. with ease
  • Come in two great sizes, 1" diameter (12" long) and 2" diameter (18" long)
  • Straight DI Brushes Wheel Woolies come without the 45 degree bend
Today's Daily special (May 3, 2016) is Lake Country Hydro Tech Cyan Light Cutting & Polishing Pad.
Regular Price for 6.5" is $11.99. Today's price is $7.23!
Regular Price for 5.5" is $9.99. Today's price is $6.18!
Regular Price for 4" is $5.99. Today's price is $3.77!
Regular Price for 3" is $3.99. Today's price is $2.47!
Regular Price for 2" is $3.99. Today's price is $2.36!
  • Powerful cutting action but the ability to finish down haze free
  • Hydro Tech foam keeps more polish on the surface of the pad for longer work time
  • Experience less dusting than traditional foam pads due to less product build up
  • Lake Country Snappy Clean Pad Cleaner help clean these pads
  • Works great with the Meguiar's Ultra-Cut Compound M105 and the Menzerna Super Intensive Polish SI 1500 (PO83)
Today's Daily special (May 4, 2016) is Gtechniq W8 Bug Remover.
Regular Price for 250 ml is $9.99. Today's price is $6.26!
  • Remove nasty bug splatter and surface contaminants with ease!
  • High quality 100% biodegradable & pH neutral formula
  • Easy to apply and will not strip off existing protection
Today's Daily special (May 5, 2016) is CarPro Eraser Intensive Oil and Polish Cleaner.
Regular Price for 500 ml is $14.99. Today's price is $11.99!
Regular Price for 5 L is $89.99. Today's price is $71.99!
Regular Price for 1000 ml is $21.99. Today's price is $17.59!
  • Easily removes oils left behind by virtually all polishes that are hidden to the naked eye
  • Helps any sealant or wax bond to the paint better
  • Essential to use before using the CarPro Cquartz Ceramic Quartz Paint Protection
  • Just spray it on and wipe it away with a microfiber towel for a streak free shine
  • Pleasant scent and anti-static properties are a nice bonus!
Today's Daily special (May 6, 2016) is Meguiar's Synthetic X-Press Spray Wax D156.
Regular Price for 128 oz is $29.99. Today's price is $22.18!
  • Quickly add depth, gloss, and protection to your paint
  • Dries on clear and will NOT stain plastic trim pieces
  • Can be applied in the sun or shade
  • Works great in the Meguiar's Synthetic X-Press Spray Wax Bottle with the DI Accessories Chemical Resistant Spray Trigger
Today's Daily special (May 10, 2016) is DI Accessories Funnel.
Regular Price is $3.99. Today's price is $2.53!
  • Reduces spills when pouring
  • Wash and reuse! Extremely durable material
  • Makes it easy to dilute concentrated products
  • Strong polypropylene stands up to strong detailing chemicals
  • Concentrated products are the best value, use the funnel to help dilute them in to smaller bottles
Today's Daily special (May 11, 2016) is DI Microfiber Applicator Pad.
Regular Price for Rectangle is $2.99. Today's price is $1.37!
Regular Price for Circle is $2.99. Today's price is $1.37!
  • Ideal for applying a sealant or wax, can also be used for polishes, glazes and more
  • Very soft and safe applicator
  • It should last years if you hand wash the Microfiber Applicator
  • Can be used to apply interior care products like leather cleaners and conditioners, trim restorers and other protectants
  • 300 GSM and reusable!
  • Comes in two great shapes, rectangle and circle!
Today's Daily special (May 12, 2016) is DI Accessories Plastic Razor Blade.
Regular Price is $0.99. Today's price is $0.41!
  • Perfect to use on windows!
  • Fits all standard razor blade holders
  • Single edged design
  • Quickly remove inspection stickers and registration stickers!
Today's Daily special (May 13, 2016) is Kwazar Mercury Pro+ Sprayer.
Regular Price for 500 ml is $14.99. Today's price is $10.34!
Regular Price for 1000 ml is $16.99. Today's price is $11.91!
  • High quality spray bottles for any step in the detailing process
  • Unique double action trigger that reduces hand fatigue
  • Labeled in both ML and Pints
  • Viton seals that resist most chemicals
Today's Daily special (May 16, 2016) is DI Accessories Tire & Trim Dressing Applicator.
Regular Price is $2.49. Today's price is $1.64!
  • Durable applicator perfect for tire and trim dressing applications
  • Hard plastic storage tub doubles as a handle
  • Measures 4.25" x 2.37" x 2.00"
Today's Daily special (May 17, 2016) is Grit Guard Washboard.
Regular Price for Black is $12.99. Today's price is $8.42!
  • Cleans your wash mitt, sponge, brushes, etc.
  • Helps prevent swirls and scratches while washing
  • Attaches to your Grit Guard
  • Works great in 5 gallon and 3.5 gallon buckets
Today's Daily special (May 18, 2016) is 303 Rubber Seal Protectant.
Regular Price for 3.4 oz is $8.99. Today's price is $5.90!
  • Rejuvenate and condition your rubber trim
  • Applies extremely easy with attached applicator pad
  • Leaves your rubber trim dark and supple
  • Water based formula dries to the touch
Today's Daily special (May 20, 2016) is Lake Country Tire Dressing Applicator.
Regular Price is $2.99. Today's price is $1.92!
  • A perfect applicator pad to apply your favorite tire dressing
  • Firm foam design that will not shred like cheaper tire dressing applicator pads
  • Works excellent with Poorboy's Bold 'n Bright water based tire dressing
Today's Daily special (May 23, 2016) is Menzerna Endless Shine.
Regular Price for 16 oz is $24.99. Today's price is $18.68!
  • Clean and protect with one quick detailer
  • High gloss and water beading
  • Protection against future contamination
  • Easy to apply
Today's Daily special (May 25, 2016) is Dodo Juice Born Slippy Clay Lube Concentrate.
Regular Price for 250 ml is $15.99. Today's price is $11.86!
  • Ultra concentrated solution makes for over 2.5 liters of clay lube
  • Dilute up to a 10:1 ratio with water while remaining super slick
  • Wipes away streak free and is safe for nearly any surface
  • We recommend picking up a 22oz spray bottle for proper dilution
Today's Daily special (May 26, 2016) is Meguiar's DA Microfiber Correction Compound D300.
Regular Price for 16 oz is $18.99. Today's price is $14.77!
Regular Price for 32 oz is $34.99. Today's price is $26.46!
Regular Price for 128 oz is $84.99. Today's price is $65.78!
  • Superior cutting power that finishes down smooth and glossy in one step!
  • Use with Meguiar's DA Microfiber Cutting Disc Buffing Pad and a Porter Cable 7424 XP for best results
  • Revolutionary new technology that will forever change detailing!
Today's Daily special (May 27, 2016) is Lake Country Orange Light Cutting Pad.
Regular Price for 6.5" is $9.99. Today's price is $6.14!
Regular Price for 5.5" is $7.99. Today's price is $4.87!
Regular Price for 4" is $4.99. Today's price is $3.35!
Regular Price for 3" is $3.99. Today's price is $2.74!
  • A light cutting pad designed to remove moderate swirls and scratches with a medium polish
  • We recommend caring for your pads with Lake Country Snappy Clean Pad Cleaner
  • Generally we recommend following up with a lighter pad and polish after
Today's Daily special (May 31, 2016) is Lake Country CCS Yellow Cutting Pad.
Regular Price for 6.5" is $9.99. Today's price is $6.05!
Regular Price for 5.5" is $7.99. Today's price is $4.67!
Regular Price for 3" is $4.99. Today's price is $3.21!
  • Safely removes noticeable surface imperfections
  • CCS technology reduces pad friction and heat buildup when polishing
  • We highly recommend following up with a lighter pad and polish combo for best results
  • Use the Snappy Clean Pad Cleaner to clean your pads
  • Works great with your favorite heavy cutting polish or compound
Today's Daily special (June 1, 2016) is Lake Country Detailing Stick.
Regular Price is $1.99. Today's price is $1.42!
  • Excellent tool for cleaning tough to reach areas
  • Rinse and re-use these sticks over and over again
  • Great tool for the front grill, exterior trim, engine bay, lug nuts, door jambs, side mirrors, etc.
  • Remove tough stains with the Lake Country Snappy Clean Pad Cleaner
  • Durable foam tip with 8" wooden handle
Today's Daily special (June 3, 2016) is Lake Country Force White Polishing Pad.
Regular Price for 5.5" is $7.99. Today's price is $5.62!
Regular Price for 6.5" is $9.99. Today's price is $6.85!
Regular Price for 3" is $4.99. Today's price is $3.44!
  • Remove fine imperfections like swirls, spider webs, oxidation, etc.
  • Pair with your favorite finishing polish
  • Hybrid foam technology keeps the polish on the surface of the pad
  • We recommend cleaning and caring for your pads with the Lake Country Snappy Clean Boost Pad Cleaner
Today's Daily special (June 6, 2016) is DI Accessories Reclosable Storage Bag.
Regular Price for 24" x 24" is $3.49. Today's price is $1.86!
  • Simple solution for storing microfiber towels!
  • The large 24" x 24" size offers flexibility to accommodate dozens of towels
  • Thick reclosable bags make it a durable long term solution to storage needs
Today's Daily special (June 7, 2016) is DI Accessories Buffer Tool Bag.
Regular Price is $49.99. Today's price is $36.36!
  • Easily carry your favorite detailing products while on the go!
  • Fits various sized polishers and other detailing products
  • Durable high quality construction
  • Rupes Mark II, Flex XC 3401, Griot's Garage Boss Polishers fit in this bag!
  • Measures: 18" W x 11" H x 11" D
Today's Daily special (June 8, 2016) is DI Accessories Upside Down Trigger Sprayer.
Regular Price is $2.49. Today's price is $1.35!
  • Spray at any angle, including upside down!
  • Nozzle tip allows you to spray in a direct steam or mist
  • Works great on various bottles
  • Measures 9 1/4"
