New FREE Car Care Product every week at DetailedImage.com
This week's Weekly Special is P21S Gel Wheel Cleaner - 1000 ml.
Use Coupon Code WSGELWH3211 to receive it for Free. A $22.99 value! Min spend $100. Offer ends 8/16/11 at 11:59 PM EST.
  • One of the safest, most effective, pH balanced wheel cleaners on the market
  • Gel based formula allows the product to penetrate vertical surfaces for a more effective cleaning
  • Perfect option for after market wheels as it is safe for virtually any wheel surface
  • Works best when an E-Z Detail Brush is used in conjunction with P21S Gel Wheel Cleaner
  • Follow up with Poorboy's World Wheel Sealant for wheels that are easier to maintain
This week's Weekly Special is Einszett 1Z Gummi Pflege Stift Rubber Care Stick .
Use Coupon Code WSGUMMI3311 to receive it for Free. A $8.99 value! Min spend $55. Offer ends 8/23/11 at 11:59 PM EST.
  • Restore and care for rubber trim and seals to keep them elastic and looking like new
  • Protects against extreme temperature and UV rays
  • Shoe polish like applicator makes the application extremely easy and smooth
This week's Weekly Special is Chemical Guys Maxi Suds II - 16 oz.
Use Coupon Code WSMAXIS3411 to receive it for Free. A $8.99 value! Min spend $45. Offer ends 8/30/11 at 11:59 PM EST.
  • One of our best selling shampoos, lots of foam, great lubricity, and gentle cleaning power
  • An addicting cherry scent that makes washing your car a pleasure
  • Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
  • High sudsing formula makes this a great option to use in foam guns
This week's Weekly Special is P21S Gel Wheel Cleaner - 500ml Kit.
Use Coupon Code WSGELWH3511 to receive it for Free. A $17.99 value! Min spend $70. Offer ends 9/6/11 at 11:59 PM EST.
This week's Weekly Special is Poorboy's World Wheel Sealant - 8 oz.
Use Coupon Code WSWHEEL3611 to receive it for Free. A $19.99 value! Min spend $115. Offer ends 9/13/11 at 11:59 PM EST.
  • Properly protect any wheel finish and minimize the amount of brake dust and road contamination
  • Has an amazing watermelon scent that everyone loves!
  • The thinner the application the better, which allows you to get dozens and dozens of applications
  • Apply with a foam applicator pad or soft cloth and remove with a clean microfiber towel
  • Extremely easy to apply and remove, feels ultra slick upon completion
  • Prevents brake dust from etching in to the wheels finish
This week's Weekly Special is DI Brushes Leather and Vinyl Scrub Brush.
Use Coupon Code WSLEATH3711 to receive it for Free. A $3.99 value! Min spend $15. Offer ends 9/20/11 at 11:59 PM EST.
  • Outstanding leather care brush to deep clean leather!
  • Works great with all leather care products, especially the Leatherique Prestine Clean and Leatherique Rejuvenator Oil
  • Soft and gentle leather brush that works great
This week's Weekly Special is DI Accessories Sheepskin Wash Mitt.
Use Coupon Code WSSHEEP3811 to receive it for Free. A $9.99 value! Min spend $55. Offer ends 9/27/11 at 11:59 PM EST.
  • Perfect wash medium to help minimize adding swirls and other imperfections to the paint
  • The natural fibers help pull contamination away from the surface without grinding them in
  • When done using, rinse any contamination using free flowing water than hang dry with leather hoop
  • For best results, use in conjunction with a 2 bucket wash system utilizing Grit Guard Inserts
This week's Weekly Special is Meguiar's Ultra-Cut Compound M105 - 8 oz.
Use Coupon Code WSULTRA3911 to receive it for Free. A $9.49 value! Min spend $45. Offer ends 10/4/11 at 11:59 PM EST.
  • Very effective at cutting through deeper imperfections
  • Finishes down nicely, but we still recommend a finishing polish after 105
  • Commonly used with an orange light cutting pad, yellow cutting pad or purple foamed wool pad
This week's Weekly Special is Stoner Invisible Glass - 19 oz.
Use Coupon Code WSINVIS4011 to receive it for Free. A $5.99 value! Min spend $35. Offer ends 10/11/11 at 11:59 PM EST.
  • Foam based glass cleaning formula that is ammonia free, making it safe on tinted windows
  • Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more from glass
  • Best applied with an all purpose microfiber towel, then wiped clean with a dry low nap microfiber towel
  • Do not apply in direct sunlight or hot glass, otherwise streaking may occur
This week's Weekly Special is SONAX Wheel Cleaner Full Effect - 500 ml.
Use Coupon Code WSWHEEL4111 to receive it for Free. A $15.99 value! Min spend $90. Offer ends 10/18/11 at 11:59 PM EST.
  • Sprays on fluorescent green and changes to a deep red as it reacts with contaminants on your wheel
  • Extra strong wheel cleaner that is very gentle and pH neutral
  • Safe on chrome, alloy, anodized, stainless steel, clear coat and polished wheels
  • High quality spray nozzle provides a fine mist and steady stream which helps conserve product
  • A premium wheel cleaner professional detailers absolutely love
This week's Weekly Special is DI Microfiber Waffle Weave Drying Towel.
Use Coupon Code WSWAFFL4211 to receive it for Free. A $17.99 value! Min spend $65. Offer ends 10/25/11 at 11:59 PM EST.
  • One of the best options for drying your vehicle and most commonly used by professional detailers
  • The waffle weave texture helps pull contamination away from the surface compared to a flat chamois
  • Our microfiber waffle weave towel has silk edging to minimize adding imperfections
  • This towel can hold up to 5 times its weight with water
  • We recommend using the sheeting method prior to drying with the towel for maximum efficiency
  • Always wash your microfiber products prior to first use
This week's Weekly Special is TUF SHINE Tire Appearance Kit.
Use Coupon Code WSTIREA4311 to receive it for Free. A $39.99 value! Min spend $160. Offer ends 11/1/11 at 11:59 PM EST.
  • The first ever semi-permanent tire dressing that looks amazing and truly lasts
  • One coat rich and dark finish, two or more coats is extremely glossy
  • Contains no oils or silicone's that can harm the tire
  • Will not sling off, dries to the touch in minutes and applies with ease
  • Tires look stunning and do not feel greasy or oily at all
This week's Weekly Special is Black WOW Black WOW - 4 oz.
Use Coupon Code WSBLACK4411 to receive it for Free. A $24.99 value! Min spend $170. Offer ends 11/8/11 at 11:59 PM EST.
  • Restore faded and neglected trim pieces, while leaving behind a bold even finish
  • Removes product residue from trim and lasts through multiple washes
  • Only a tiny bit of product is needed, use sparingly
This week's Weekly Special is Meguiar's Ultra-Cut Compound M105 - 32 oz.
Use Coupon Code WSULTRA4611 to receive it for Free. A $26.99 value! Min spend $225. Offer ends 11/22/11 at 11:59 PM EST.
This week's Weekly Special is Einszett 1Z Cockpit Premium - 500 ml.
Use Coupon Code WSCOCKP4711 to receive it for Free. A $10.99 value! Min spend $60. Offer ends 11/29/11 at 11:59 PM EST.
  • One of the best interior cleaners and protectants that leaves your finish factory new
  • Easy to get streak free results every time, great scent, and UV protects
  • Best used on your dash, gauge cluster, navigation screens, audio components, shift knobs, arm rests, leatherette, steering wheels and much more
This week's Weekly Special is P21S Total Auto Wash - 1000ml Refill.
Use Coupon Code WSTOTAL4811 to receive it for Free. A $15.99 value! Min spend $85. Offer ends 12/6/11 at 11:59 PM EST.
  • One of the most versatile products we offer, degrease nearly any surface safely and effectively
  • Use on paint, trim, rubber, vinyl, carpets, plastic, glass, leather and many other surfaces
  • Can be used at full strength or diluted down to clean more delicate surfaces
  • Used by many high end detailers to properly prep surfaces for polishing, restoring or protecting
  • A must have any detailing enthusiasts or pro detailers arsenal of products
This week's Weekly Special is Menzerna Super Intensive Polish SI 1500 (PO83) .
Use Coupon Code WSSUPER4911 to receive it for Free. A $29.99 value! Min spend $185. Offer ends 12/13/11 at 11:59 PM EST.
  • Most noted for its ability to easily remove imperfections, good work time, easy removal process and brilliant finish
  • You will instantly notice more gloss and depth with just one application
  • Can be applied by hand but optimal results are with a buffer and an Orange or Cyan Light Cutting Pad from Lake Country
  • A premium medium to heavy cutting polish removing visible surface imperfections while finishing down remarkably well
This week's Weekly Special is P21S Total Auto Wash - 1000 ml Kit.
Use Coupon Code WSTOTAL5011 to receive it for Free. A $17.99 value! Min spend $95. Offer ends 12/20/11 at 11:59 PM EST.
This week's Weekly Special is Meguiar's Professional Masking Tape - 1.5.
Use Coupon Code WSPROFE5111 to receive it for Free. A $4.50 value! Min spend $25. Offer ends 12/27/11 at 11:59 PM EST.
  • Properly protect trim, emblems, lights, adjacent panels and more when polishing or using a buffer
  • Instantly sticks on surfaces and releases quickly and cleanly without residue left behind
  • Perfect for protecting clear bra edges so you don't get product build up that shows
This week's Weekly Special is Chemical Guys Black on Black - 11 oz.
Use Coupon Code WSBLACK5211 to receive it for Free. A $12.99 value! Min spend $50. Offer ends 1/3/12 at 11:59 PM EST.
  • One of the most unique trim restorers that turns faded trim back to a deep factory black finish
  • Perfect option for wheel wells, engine bay dressing, tire dressing and exterior trim pieces
  • Formerly referred to as Chemical Guys Fade 2 Black
This week's Weekly Special is Meguiar's Ultra Finishing Polish M205 - 32 oz.
Use Coupon Code WSULTRA0112 to receive it for Free. A $27.99 value! Min spend $205. Offer ends 1/10/12 at 11:59 PM EST.
  • Removes swirls and light imperfections on any type of paint
  • Finishes down haze, hologram and marring free
  • Perfect follow up to Meguiar's Ultra Cut Compound 105
  • Commonly used with a white polishing pad or a black finishing pad
This week's Weekly Special is Chemical Guys Extreme EZ-Creme Glaze with Acrylic.
Use Coupon Code WSEXTRE0212 to receive it for Free. A $16.99 value! Min spend $80. Offer ends 1/17/12 at 11:59 PM EST.
  • The perfect prep step before applying a sealant to enhance the gloss and depth of any color paint, while hiding minor imperfections
  • The acrylic based formula makes it compatible with both sealants and waxes
  • Best applied with a foam applicator pad as thin as possible and removed with a microfiber towel
  • When using a buffer, best applied with a black finishing pad
This week's Weekly Special is 303 Aerospace Protectant - 16 oz.
Use Coupon Code WSAEROS0312 to receive it for Free. A $12.99 value! Min spend $60. Offer ends 1/24/12 at 11:59 PM EST.
  • An excellent UV protectant and dressing for vinyl, leather, rubber and plastic surfaces
  • Leaves behind a beautiful matte finish that is not greasy, shiny or oily
  • Treated surfaces resist dust, soiling, staining and also repel water
  • Most commonly used on interior dashboards, center consoles, door trim, leather seats, and in the engine bay
  • Works great on vinyl convertible tops, plastic rear windows, clear bras, and tonneau covers
  • For maximum efficiency use in a 4oz pump spray bottle and apply with a microfiber towel
This week's Weekly Special is SONAX Glass Cleaner - 500 ml.
Use Coupon Code WSGLASS0412 to receive it for Free. A $12.99 value! Min spend $95. Offer ends 1/31/12 at 11:59 PM EST.
  • Highly effective glass cleaner!
  • Works great inside and outside of the vehicle
  • Engineered by Germany's best from SONAX headquarters
  • Gentle and environmentally responsible formula
