New FREE Car Care Product every week at DetailedImage.com
This week's Weekly Special is DI Accessories Gentle Fine Grade Clay - 200 g.
Use Coupon Code WSGENTL3412 to receive it for Free. A $18.99 value! Min spend $55. Offer ends 8/28/12 at 11:59 PM EST.
  • Safely and effectively remove tar, sap, paint over spray and more
  • Fine grade clay bars will not mar your finish when used properly
  • We recommend using Dodo Juice Born Slippy as your clay lube
This week's Weekly Special is SONAX Wheel Cleaner Full Effect - 500 ml.
Use Coupon Code WSWHEEL3512 to receive it for Free. A $15.99 value! Min spend $85. Offer ends 9/4/12 at 11:59 PM EST.
  • Sprays on fluorescent green and changes to a deep red as it reacts with contaminants on your wheel
  • Extra strong wheel cleaner that is very gentle and pH neutral
  • Safe on chrome, alloy, anodized, stainless steel, clear coat and polished wheels
  • The 500ml bottle's spray nozzle provides a fine mist and steady stream which helps conserve product
  • A premium wheel cleaner professional detailers absolutely love
This week's Weekly Special is Poorboy's World Spray & Wipe (S&W) .
Use Coupon Code WSSPRAY3612 to receive it for Free. A $8.99 value! Min spend $60. Offer ends 9/11/12 at 11:59 PM EST.
  • Quick and easy waterless wash product for lightly contaminated vehicles, an excellent clay bar lubricant and perfect for quick clean ups
  • Extremely versatile cleaning product that is a favorite amongst professional detailers and enthusiasts
  • Perfect product to keep in your glove compartment to clean up emergency bird bombs, sap, tar, etc.
  • Best applied with a plush microfiber towel to minimize any micro-marring in the paint
  • For maximum efficiency and convenient storage use in a 4oz pump spray bottle
This week's Weekly Special is P21S Gel Wheel Cleaner - 500ml Kit.
Use Coupon Code WSGELWH3712 to receive it for Free. A $17.99 value! Min spend $95. Offer ends 9/18/12 at 11:59 PM EST.
  • One of the safest, most effective, pH balanced wheel cleaners on the market
  • Gel based formula allows the product to penetrate vertical surfaces for a more effective cleaning
  • Perfect option for after market wheels as it is safe for virtually any wheel surface
  • Works best when an E-Z Detail Brush is used in conjunction with P21S Gel Wheel Cleaner
  • Follow up with Poorboy's World Wheel Sealant for wheels that are easier to maintain
This week's Weekly Special is DI Accessories Orange Blossom Air Freshener.
Use Coupon Code WSORANG3812 to receive it for Free. A $4.99 value! Min spend $25. Offer ends 9/25/12 at 11:59 PM EST.
  • Orange blossom scent is universally loved!
  • Comes with a string and a clip so you can place it anywhere
  • Gel based scent lasts much longer than traditional ones
  • Helps eliminate odors
  • Also available in Fresh and Clean Scent
This week's Weekly Special is Stoner Invisible Glass - 19 oz.
Use Coupon Code WSINVIS3912 to receive it for Free. A $5.99 value! Min spend $25. Offer ends 10/2/12 at 11:59 PM EST.
  • Foam based glass cleaning formula that is ammonia free, making it safe on tinted windows
  • Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more from glass
  • Best applied with an all purpose microfiber towel, then wiped clean with a dry low nap microfiber towel
  • Do not apply in direct sunlight or hot glass, otherwise streaking may occur
Hey man, I have a question. Here's what im doing, I've sanded my aluminum hood all the way down to the aluminum and worked my way up to 3,000 water sand. (about 25 total hours of sanding) I have some incredible aluminum polish (nushine NuVite S) best stuff I've ever used but I need a cotton pad
Does your company carry a cotton pad?
I've done my hood once before but had to double layer 100% cotton rags and zip tie them to my dewalt buffer with a foam pad for cushion.
Today's Daily special (October 3, 2012) is Clay Magic Medium Grade Clay Bar.
Regular Price for 200 g is $24.99. Today's price is $18.24!
-Remove embedded surface contamination that does not come off during the washing process
-Medium grade bars will remove contamination quickly, however it may result in micro-marring
-Properly preps your paints surface for polishing, using a glaze, sealant and / or wax
-Helps you get the most out of any step you perform after using the clay bar
-Follow up the medium grade clay bar with a finishing polish to remove any micro-marring
-We recommend using Poorboy's Spray & Wipe as a clay bar lubricant and quick detailer
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
This week's Weekly Special is Brinkmann Maxfire Dual Xenon Swirl Finder.
Use Coupon Code WSMAXFI4212 to receive it for Free. A $29.99 value! Min spend $190. Offer ends 10/23/12 at 11:59 PM EST.
  • Easily reveal swirls, scratches and other imperfections with this lightweight rechargeable hand held spotlight
  • Avoid having to use bulky, corded, and hot halogen light stands!
  • Get the best polishing results with the proper lighting, no guess work if imperfections have been removed effectively
Use Coupon Code WSGELWH4412 to receive it for Free. A $17.99 value! Min spend $85. Offer ends 11/6/12 at 11:59 PM EST.
This week's Weekly Special is Stoner Tarminator - 10 oz.
Use Coupon Code WSTARMI4512 to receive it for Free. A $5.99 value! Min spend $25. Offer ends 11/13/12 at 11:59 PM EST.
  • Safely and effectively remove tar, grease and sap from painted surfaces
  • Simply spray Tarminator onto the effected area, let dwell for a minute or two, then wipe clean
  • Remember to protect the areas you use Tarminator on with a sealant or wax
This week's Weekly Special is DI Accessories Sheepskin Wash Mitt without thumb.
Use Coupon Code WSSHEEP4612 to receive it for Free. A $10.99 value! Min spend $65. Offer ends 11/20/12 at 11:59 PM EST.
  • All natural fibers makes it one of the safest wash mitts on the market
  • The natural fibers help pull contamination away from the surface without harming even the most delicate finishes
  • When done rinse any contamination away using free flowing water than hang dry with leather loop
  • Can be used with any shampoo or rinseless wash (i.e. Optimum No Rinse Wash & Shine New Formula (ONR))
This week's Weekly Special is Collinite 845 Insulator Wax - 16 oz.
Use Coupon Code WSINSUL4712 to receive it for Free. A $15.99 value! Min spend $80. Offer ends 11/27/12 at 11:59 PM EST.
  • A liquid carnauba wax that will keep your car protected like a sealant!
  • Very easy to apply and remove
  • Incredible levels of gloss that dramatically improves any color paint
  • Repels water, pollution, sun, salt, bugs and more
  • Can be applied to virtually any exterior finish
This week's Weekly Special is Gilmour Power Flow Hose Nozzle.
Use Coupon Code WSPOWER4812 to receive it for Free. A $18.99 value! Min spend $60. Offer ends 12/4/12 at 11:59 PM EST.
  • High pressure hose nozzle that offers plenty of power!
  • Excellent nozzle that fits on any hose
  • Top quality parts make this durable nozzle a great investment
  • Offers tons of power or a fine mist and everything in between
Use Coupon Code WSGELWH4912 to receive it for Free. A $17.99 value! Min spend $95. Offer ends 12/11/12 at 11:59 PM EST.
This week's Weekly Special is Leatherique Prestine Clean - 16 oz.
Use Coupon Code WSPREST5012 to receive it for Free. A $19.99 value! Min spend $105. Offer ends 12/18/12 at 11:59 PM EST.
  • A premium leather cleaner with light conditioners, perfect for cleaning and maintaining leather
  • Restores proteins that are naturally found in leather for a soft and supple feel
  • Completely matte finish that has no greasy or oily residue
  • Apply to your leather and let sit for 15 - 30 minutes, wipe with a warm damp towel and wipe dry with a second towel
  • For maximum results, Prestine Clean is best used after Leatherique Rejuvenator Oil
This week's Weekly Special is DI Microfiber Autofiber Zero Edge Towel - 16".
Use Coupon Code WSAUTOF5212 to receive it for Free. A $4.99 value! Min spend $20. Offer ends 1/1/13 at 11:59 PM EST.
  • Highly effective edgeless design saves you time while improving results
  • Premium microfiber threads that feel extremely soft
  • Specializes in removing the left over product (i.e. polish, wax, etc.) from the paint
  • Very durable design that can be machine washed
  • Can be used for virtually any detailing task
This week's Weekly Special is Lake Country Tire Dressing Applicator.
Use Coupon Code WSTIRED0213 to receive it for Free. A $1.99 value! Min spend $5. Offer ends 1/15/13 at 11:59 PM EST.
  • A perfect applicator pad to apply your favorite tire dressing
  • Firm foam design that will not shred like cheaper tire dressing applicator pads
  • Works excellent with Poorboy's Bold & Bright water based tire dressing
Use Coupon Code WSINSUL0313 to receive it for Free. A $15.99 value! Min spend $80. Offer ends 1/22/13 at 11:59 PM EST.
This week's Weekly Special is DI Brushes EZ Detail Brush - Full Size.
Use Coupon Code WSEZDET0413 to receive it for Free. A $21.99 value! Min spend $120. Offer ends 1/29/13 at 11:59 PM EST.
  • Mentioned as an essential tool professionals use in Autoweek magazine
  • The professionals choice for a wheel brush to clean the inner barrels of your wheels
  • Works great with soap and water or a wheel cleaner for maintaining wheels
  • Turns a good wheel detail into an exceptional one that really shines with open spoke wheel designs
  • Can also be used in your engine bay to agitate contamination after degreasing
This week's Weekly Special is 303 Aerospace Protectant - 16 oz.
Use Coupon Code WSAEROS0513 to receive it for Free. A $9.74 value! Min spend $85. Offer ends 2/5/13 at 11:59 PM EST.
  • An excellent UV protectant and dressing for vinyl, leather, rubber and plastic surfaces
  • Leaves behind a beautiful matte finish that is not greasy, shiny or oily
  • Treated surfaces resist dust, soiling, staining and also repel water
  • Most commonly used on interior dashboards, center consoles, door trim, leather seats, and in the engine bay
  • Works great on vinyl convertible tops, plastic rear windows, clear bras, and tonneau covers
  • For maximum efficiency use in a 4oz pump spray bottle and apply with a microfiber towel
This week's Weekly Special is P21S Super-Absorbing Drying Towel.
Use Coupon Code WSSUPER0613 to receive it for Free. A $11.99 value! Min spend $65. Offer ends 2/12/13 at 11:59 PM EST.
  • High quality drying towel that soaks up large amounts of water
  • Made from 100% bio-degradable materials so it's environmentally friendly
  • Comes in an air tight plastic storage container which preserves the towel in between uses
  • German engineered to work great for years to come
This week's Weekly Special is Einszett 1Z Anti-Frost Concentrate Washer Fluid -.
Use Coupon Code WSANTIF0713 to receive it for Free. A $10.99 value! Min spend $40. Offer ends 2/19/13 at 11:59 PM EST.
  • Concentrated anti-frost washer fluid that will leave your glass streak free
  • Product is 100% bio-degradable which means it won't damage surrounding rubber, plastic, vinyl and painted surfaces
  • Good value, can dilute down 2:1 water to fluid and still remain effective
This week's Weekly Special is Collinite 476s Super Doublecoat Auto Wax - 9 oz.
Use Coupon Code WSSSUPE0813 to receive it for Free. A $16.99 value! Min spend $125. Offer ends 2/26/13 at 11:59 PM EST.
  • A paste wax that will stand up to the rigors of every day driving!
  • Versatile product that can be used on the exterior paint and more
  • Easy to apply and remove
  • Has a wax type gloss with sealant like protection
  • Repels water, pollution, UV rays, salt, bugs, and more
This week's Weekly Special is P21S Deluxe Wax Applicator 2 Pack.
Use Coupon Code WSDELUX0913 to receive it for Free. A $9.99 value! Min spend $45. Offer ends 3/5/13 at 11:59 PM EST.
  • Apply any polish, glaze, sealant or wax with the P21S Deluxe Applicator
  • Includes 2 premium foam applicators
  • Very soft and safe on any surface
