New FREE Car Care Product every week at DetailedImage.com
This week's Weekly Special is 3M Automotive Masking Tape - 18 mm.
Use Coupon Code WSAUTOM4714 to receive it for Free. A $3.99 value! Min spend $20. Offer ends 11/25/14 at 11:59 PM EST.
  • Quality masking tape for protecting your trim, paint and more!
  • Instantly sticks on surfaces and releases quickly and cleanly without residue left behind
  • Great value!
This week's Weekly Special is P21S Gel Wheel Cleaner - 1000 ml.
Use Coupon Code WSGELWH4814 to receive it for Free. A $24.99 value! Min spend $105. Offer ends 12/2/14 at 11:59 PM EST.
  • One of the safest, most effective, pH balanced wheel cleaners on the market
  • Gel based formula allows the product to penetrate vertical surfaces for a more effective cleaning
  • Perfect option for after market wheels as it is safe for virtually any wheel surface
  • Works best when an E-Z Detail Brush is used in conjunction with P21S Gel Wheel Cleaner
  • Follow up with Poorboy's World Wheel Sealant for wheels that are easier to maintain
This week's Weekly Special is Chemical Guys Black Light Hybrid Radiant Finish - 16 oz.
Use Coupon Code WSBLACK4914 to receive it for Free. A $25.99 value! Min spend $155. Offer ends 12/9/14 at 11:59 PM EST.
  • Incredibly deep reflection that makes any color paint look great
  • Get the protection of a sealant with the gloss of a high end wax or glaze
  • WARNING Insane Gloss Levels!
  • Extremely easy to apply and remove
This week's Weekly Special is DI Accessories Medium Grade Clay Bar - 100 g.
Use Coupon Code WSMEDIU5014 to receive it for Free. A $10.99 value! Min spend $25. Offer ends 12/16/14 at 11:59 PM EST.
  • Use to remove stubborn contamination such as tree sap, tar, rail dust and paint overspray
  • Large enough to break into several pieces for multiple uses
  • We recommend Dodo Juice Born Slippy as a clay lube
  • If you drop a piece of clay, throw it away!
This week's Weekly Special is Meguiar's Ultra Finishing Polish M205 - 8 oz.
Use Coupon Code WSULTRA5114 to receive it for Free. A $9.99 value! Min spend $70. Offer ends 12/23/14 at 11:59 PM EST.
  • Removes swirls and light imperfections on any type of paint
  • Finishes down haze, hologram and marring free
  • Perfect follow up to Meguiar's Ultra Cut Compound 105
  • Commonly used with a white polishing pad or a black finishing pad
This week's Weekly Special is 303 Fabric Guard - 16 oz Original.
Use Coupon Code WSFABRI0114 to receive it for Free. A $4.99 value! Min spend $40. Offer ends 1/6/15 at 11:59 PM EST.
  • Protects carpet, canvas and upholstery from staining by repelling liquids
  • Makes maintaining interior carpets, floor mats and canvas seats significantly easier when protected
  • Works great on canvas convertible tops and outdoor patio furniture
  • For maximum efficiency use in a 4oz pump spray bottle
  • Formally known as the 303 High Tech Fabric Guard
This week's Weekly Special is DI Microfiber Double Thick Edgeless Towel - 16" x 16".
Use Coupon Code WSDOUBL0215 to receive it for Free. A $5.99 value! Min spend $30. Offer ends 1/13/15 at 11:59 PM EST.
  • Edgeless design saves you time while improving results!
  • Very plush, long, and soft microfiber threads
  • Very durable design that can be machine washed
  • Can be used for virtually any detailing task
  • 470 GSM
mage account
This week's Weekly Special is 303 Spot Cleaner - 32 oz Original.
Use Coupon Code WSSPOTC0315 to receive it for Free. A $4.49 value! Min spend $20. Offer ends 1/20/15 at 11:59 PM EST.
  • A great pre-diluted all purpose cleaner for carpets, upholstery, vinyl, rubber, leather, plastic and much more
  • Safely removes oil, grease, ink, coffee, tea, wine, juice, blood, and tons more
  • Cleaning action increases when agitated with a Carpet Scrub Brush
  • Formally known as the 303 Cleaner & Spot Remover
  • The 303 Spot Clear is the diluted and ready to use version of the 303 Multi-Surface Cleaner.
Today's Daily special (January 27, 2015) is DI Accessories Isopropyl Alcohol.
Regular Price for 70% 16 oz is $5.99. Today's price is $4.31!
  • Quickly and easily remove waxes, sealants, or polishing residue
  • Ensure that you have a clean surface to polishing away imperfections
  • Get maximum durability from your sealant, wax or coating system
  • Use at full strength 70/30 ratio, or easily dilute to 50/50 ratio
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
This week's Weekly Special is P21S Finish Restorer - 75ml.
Use Coupon Code WSFINIS0515 to receive it for Free. A $11.99 value! Min spend $65. Offer ends 2/3/15 at 11:59 PM EST.
  • Clean, restore and polish your wheels and metal trim in one easy step
  • A little goes a long way, work a small amount of product into the metal with light pressure
  • We recommend using a foam applicator pad for application
  • Use a two sided metal polishing towel to remove excess product and to buff to desired finish
This week's Weekly Special is DI Brushes Pet Hair Removal Brush.
Use Coupon Code WSPETHA0615 to receive it for Free. A $4.99 value! Min spend $20. Offer ends 2/10/15 at 11:59 PM EST.
  • Easily remove pesky pet hair from your interior carpets and upholstery
  • Rubber bristles use static electricity to attract and collect pet hair
  • Great for removing hair from furniture and carpets in your home too!
  • Handle can be used as a squeegee to remove water from windows
This week's Weekly Special is DI Microfiber Waffle Weave Drying Towel - 36" x 24".
Use Coupon Code WSWAFFL0715 to receive it for Free. A $13.49 value! Min spend $60. Offer ends 2/17/15 at 11:59 PM EST.
  • One of the best options for drying your vehicle safely and quickly
  • Continues to soak up large amounts of water even after it's damp or wet
  • A fine silk edging ensures this is a safe towel
  • This towel can hold up to 10 times its weight with water
  • Use this towel with the sheeting method for the most efficient drying process
  • 480 GSM
This week's Weekly Special is DI Accessories Fine Grade Clay - 200 g.
Use Coupon Code WSFINEG0815 to receive it for Free. A $18.99 value! Min spend $35. Offer ends 2/24/15 at 11:59 PM EST.
  • Safely remove road grime, brake dust, tar, sap, paint over spray and more
  • Fine grade clay bars are gentle on your exterior paint
  • We recommend using Dodo Juice Born Slippy or Poorboy's World Spray & Wipe as your clay lube
  • Can be used on brand new cars to older vehicles with light to medium build ups
This week's Weekly Special is Sonax Wheel Cleaner Full Effect - 500 ml.
Use Coupon Code WSWHEEL0915 to receive it for Free. A $15.99 value! Min spend $70. Offer ends 3/3/15 at 11:59 PM EST.
  • Sonax Wheel Cleaner 2 pack & Bonus Dashboard Cleaner ONLY $30!!!
  • Extra strong wheel cleaner that is very gentle and pH neutral
  • Safe on chrome, alloy, anodized, stainless steel, clear coat and polished wheels
  • The 500ml bottle's spray nozzle provides a fine mist and steady stream which helps conserve product
  • A premium wheel cleaner professional detailers absolutely love
  • Sprays on fluorescent green and changes to a deep red as it reacts with contaminants on your wheel
This week's Weekly Special is P21S Gel Wheel Cleaner - 500 ml Kit.
Use Coupon Code WSGELWH1015 to receive it for Free. A $19.99 value! Min spend $85. Offer ends 3/10/15 at 11:59 PM EST.
This week's Weekly Special is P21S Deluxe Wax Applicator 2 Pack.
Use Coupon Code WSDELUX1115 to receive it for Free. A $9.99 value! Min spend $40. Offer ends 3/17/15 at 11:59 PM EST.
  • Apply any polish, glaze, sealant or wax with the P21S Deluxe Applicator
  • Includes 2 premium foam applicators
  • Very soft and safe on any surface
Use Coupon Code WSFINIS1415 to receive it for Free. A $11.99 value! Min spend $90. Offer ends 4/7/15 at 11:59 PM EST.
Use Coupon Code WSGELWH1515 to receive it for Free. A $19.99 value! Min spend $120. Offer ends 4/14/15 at 11:59 PM EST.
This week's Weekly Special is DI Microfiber Applicator Pad - Rectangle.
Use Coupon Code WSAPPLI1615 to receive it for Free. A $2.99 value! Min spend $5. Offer ends 4/21/15 at 11:59 PM EST.
  • Ideal for applying a sealant or wax, can also be used for polishes, glazes and more
  • Very soft and safe applicator
  • It should last years if you hand wash the Microfiber Applicator
  • Can be used to apply interior care products like leather cleaners and conditioners, trim restorers and other protectants
  • 300 GSM and reusable!
  • Comes in two great shapes, rectangle and circle!
This week's Weekly Special is DI Accessories Sheepskin Wash Mitt without thumb.
Use Coupon Code WSSHEEP1715 to receive it for Free. A $8.99 value! Min spend $75. Offer ends 4/28/15 at 11:59 PM EST.
  • All natural fibers makes it one of the safest wash mitts on the market
  • The natural fibers help pull contamination away from the surface without harming even the most delicate finishes
  • When done rinse any contamination away using free flowing water than hang dry with leather loop
  • Can be used with any shampoo or rinseless wash (i.e. Optimum No Rinse Wash & Shine New Formula (ONR))
  • Also available in the with thumb version!
This week's Weekly Special is Einszett Cockpit Premium - 500 ml.
Use Coupon Code WSCOCKP1815 to receive it for Free. A $11.99 value! Min spend $55. Offer ends 5/5/15 at 11:59 PM EST.
  • One of the best interior cleaners and protectants that leaves your finish factory new
  • Easy to get streak free results every time, great scent, and UV protects
  • Best used on your dash, gauge cluster, navigation screens, audio components, shift knobs, arm rests, leatherette, steering wheels and much more
Today's Daily special (May 6, 2015) is Chemical Guys Pete's '53 Black Pearl Signature Paste Wax.
Regular Price for 8 oz is $39.99. Today's price is $28.01!
  • A hidden gem of carnauba waxes, offering excellent depth and gloss and easy application
  • Excels on darker colored vehicles, but works well on any color, metallic and non-metallic
  • Easy to apply and remove when applied properly, which is as thin as possible
  • Best applied with a foam applicator pad and removed with a microfiber towel
This week's Weekly Special is DI Brushes ATLASTA Soft Tip Brush.
Use Coupon Code WSATLAS1915 to receive it for Free. A $14.99 value! Min spend $70. Offer ends 5/12/15 at 11:59 PM EST.
  • Versatile brush can be used on your interior or exterior surfaces!
  • Packed with soft filament bristles that hold their shape
  • 9.75" long with a weight of 4.3 oz
  • Amazing brush for wheels!
This week's Weekly Special is P21S Bodywork Conditioning Shampoo - 500 ml.
Use Coupon Code WSBODYW2015 to receive it for Free. A $11.99 value! Min spend $55. Offer ends 5/19/15 at 11:59 PM EST.
  • An excellent, shampoo with high lubricity and gentle cleaners that will not remove your protection
  • Only a cap full of shampoo is needed in a 5 gallon bucket of water
  • The low sudsing formula does not make this a great shampoo for a foam gun
  • Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
This week's Weekly Special is 303 Aerospace Protectant - 16 oz.
Use Coupon Code WSAEROS2115 to receive it for Free. A $12.99 value! Min spend $60. Offer ends 5/26/15 at 11:59 PM EST.
  • An excellent UV protectant and dressing for vinyl, leather, rubber and plastic surfaces
  • Leaves behind a beautiful matte finish that is not greasy, shiny or oily
  • Treated surfaces resist dust, soiling, staining and also repel water
  • Most commonly used on interior dashboards, center consoles, door trim, leather seats, and in the engine bay
  • Works great on vinyl convertible tops, plastic rear windows, clear bras, and tonneau covers
  • For maximum efficiency use in a 4oz pump spray bottle and apply with a microfiber towel
