New FREE Car Care Product every week at DetailedImage.com
This week's Weekly Special is 303 Spot Cleaner - 32 oz Original.
Use Coupon Code WSSPOTC2315 to receive it for Free. A $5.99 value! Min spend $15. Offer ends 6/9/15 at 11:59 PM EST.
  • A great pre-diluted all purpose cleaner for carpets, upholstery, vinyl, rubber, leather, plastic and much more
  • Safely removes oil, grease, ink, coffee, tea, wine, juice, blood, and tons more
  • Cleaning action increases when agitated with a Carpet Scrub Brush
  • Formally known as the 303 Cleaner & Spot Remover
  • The 303 Spot Clear is the diluted and ready to use version of the 303 Multi-Surface Cleaner.
This week's Weekly Special is Sonax MultiStar All Purpose Cleaner - 750 ml.
Use Coupon Code WSMULTI2415 to receive it for Free. A $14.99 value! Min spend $75. Offer ends 6/16/15 at 11:59 PM EST.
  • All purpose cleaner for your interior and exterior!
  • Strong enough for wheels, while gentle enough for your dashboard
  • No dilution necessary
  • Find out how to get $10, $20, or $30 back in the description below!
This week's Weekly Special is Chemical Guys Citrus Wash & Gloss - 16 oz.
Use Coupon Code WSCITRU2515 to receive it for Free. A $8.99 value! Min spend $50. Offer ends 6/23/15 at 11:59 PM EST.
  • One of our best selling shampoos, lots of foam, great lubricity, strong cleaning power and versatile
  • Can be used in high concentration to strip off previous coats of protection or diluted as a maintenance shampoo
  • Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
  • Works great in a foam gun, such as the Gilmour Foamaster II
This week's Weekly Special is Meguiar's Soft Buff DA Foam Cutting Disc - 5".
Use Coupon Code WSSOFTB2615 to receive it for Free. A $10.99 value! Min spend $70. Offer ends 6/30/15 at 11:59 PM EST.
  • Great foam cutting disc that removes medium to heavy imperfections with ease!
  • Low operating temperature and less haze left behind
  • Thin 17.5mm disc design
  • Works great on the MT300 or any other DA Polisher
  • Perfect fit on the Soft Buff DA Backing Plate
This week's Weekly Special is Sonax Wheel Cleaner Full Effect - 500 ml.
Use Coupon Code WSWHEEL2715 to receive it for Free. A $15.99 value! Min spend $70. Offer ends 7/7/15 at 11:59 PM EST.
  • Extra strong wheel cleaner that is very gentle and pH neutral
  • Safe on chrome, alloy, anodized, stainless steel, clear coat and polished wheels
  • The 500ml bottle's spray nozzle provides a fine mist and steady stream which helps conserve product
  • A premium wheel cleaner professional detailers absolutely love
  • Sprays on fluorescent green and changes to a deep red as it reacts with contaminants on your wheel
This week's Weekly Special is Collinite 845 Insulator Wax - 16 oz.
Use Coupon Code WSINSUL3015 to receive it for Free. A $18.99 value! Min spend $105. Offer ends 7/28/15 at 11:59 PM EST.
  • A liquid carnauba wax that will keep your car protected like a sealant!
  • Very easy to apply and remove
  • Incredible levels of gloss that dramatically improves any color paint
  • Repels water, pollution, sun, salt, bugs and more
  • Can be applied to virtually any exterior finish
Use Coupon Code WSINSUL3215 to receive it for Free. A $18.99 value! Min spend $115. Offer ends 8/11/15 at 11:59 PM EST.
This week's Weekly Special is Sonax Glass Cleaner - 500 ml.
Use Coupon Code WSGLASS3315 to receive it for Free. A $11.99 value! Min spend $75. Offer ends 8/18/15 at 11:59 PM EST.
  • Highly effective glass cleaner!
  • Works great inside and outside of the vehicle
  • Engineered by Germany's best from SONAX headquarters
  • Gentle and environmentally responsible formula
Use Coupon Code WSINSUL3415 to receive it for Free. A $18.99 value! Min spend $115. Offer ends 8/25/15 at 11:59 PM EST.
Use Coupon Code WSWHEEL3515 to receive it for Free. A $15.99 value! Min spend $70. Offer ends 9/1/15 at 11:59 PM EST.
This week's Weekly Special is DI Brushes Pet Hair Removal Brush.
Use Coupon Code WSPETHA3615 to receive it for Free. A $2.99 value! Min spend $20. Offer ends 9/8/15 at 11:59 PM EST.
  • Easily remove pesky pet hair from your interior carpets and upholstery
  • Rubber bristles use static electricity to attract and collect pet hair
  • Great for removing hair from furniture and carpets in your home too!
  • Handle can be used as a squeegee to remove water from windows
This week's Weekly Special is DI Microfiber Applicator Pad - Circle.
Use Coupon Code WSAPPLI3715 to receive it for Free. A $2.99 value! Min spend $5. Offer ends 9/15/15 at 11:59 PM EST.
  • Ideal for applying a sealant or wax, can also be used for polishes, glazes and more
  • Very soft and safe applicator
  • It should last years if you hand wash the Microfiber Applicator
  • Can be used to apply interior care products like leather cleaners and conditioners, trim restorers and other protectants
  • 300 GSM and reusable!
  • Comes in two great shapes, rectangle and circle!
This week's Weekly Special is P21S Total Auto Wash - 1000 ml.
Use Coupon Code WSTOTAL3815 to receive it for Free. A $16.99 value! Min spend $75. Offer ends 9/22/15 at 11:59 PM EST.
  • One of the most versatile products we offer, degrease nearly any surface safely and effectively
  • Use on paint, trim, rubber, vinyl, carpets, plastic, glass, leather and many other surfaces
  • Can be used at full strength or diluted down to clean more delicate surfaces
  • Used by many high end detailers to properly prep surfaces for polishing, restoring or protecting
  • A must have any detailing enthusiasts or pro detailers arsenal of products
This week's Weekly Special is Einszett Anti Insekt Bug & Sap Remover - 500 ml.
Use Coupon Code WSANTII3915 to receive it for Free. A $10.99 value! Min spend $60. Offer ends 9/29/15 at 11:59 PM EST.
  • Paint safe pre-wash degreaser that effectively helps loosen stubborn contamination prior to washing
  • Avoid scrubbing to remove tar, bugs, etc. which will minimize adding swirls and scratches to your paint
  • Safe to use on head lights, chrome, glass, rubber, plastic and paint surfaces
Use Coupon Code WSWHEEL4015 to receive it for Free. A $15.99 value! Min spend $75. Offer ends 10/6/15 at 11:59 PM EST.
This week's Weekly Special is Einszett ColourTec Wheel Cleaner - 16.9 oz.
Use Coupon Code WSCOLOU4115 to receive it for Free. A $11.89 value! Min spend $85. Offer ends 10/13/15 at 11:59 PM EST.
  • Extra strong and effective wheel cleaner that is very gentle and non-corrosive
  • This product changes colors after it breaks down select contaminants
  • A premium wheel cleaner professionals and enthusiasts will absolutely love
Use Coupon Code WSTOTAL4315 to receive it for Free. A $16.99 value! Min spend $75. Offer ends 10/27/15 at 11:59 PM EST.
This week's Weekly Special is DI Accessories Medium Grade Clay Bar - 100 g.
Use Coupon Code WSMEDIU4515 to receive it for Free. A $7.99 value! Min spend $25. Offer ends 11/10/15 at 11:59 PM EST.
  • Use to remove stubborn contamination such as tree sap, tar, rail dust and paint overspray
  • Large enough to break into several pieces for multiple uses
  • We recommend Dodo Juice Born Slippy as a clay lube
  • If you drop a piece of clay, throw it away!
This week's Weekly Special is 303 Aerospace Protectant - 16 oz.
Use Coupon Code WSAEROS4615 to receive it for Free. A $12.99 value! Min spend $85. Offer ends 11/17/15 at 11:59 PM EST.
  • An excellent UV protectant and dressing for vinyl, leather, rubber and plastic surfaces
  • Leaves behind a beautiful matte finish that is not greasy, shiny or oily
  • Treated surfaces resist dust, soiling, staining and also repel water
  • Most commonly used on interior dashboards, center consoles, door trim, leather seats, and in the engine bay
  • Works great on vinyl convertible tops, plastic rear windows, clear bras, and tonneau covers
  • For maximum efficiency use in a 4oz pump spray bottle and apply with a microfiber towel
Use Coupon Code WSWHEEL4715 to receive it for Free. A $15.99 value! Min spend $70. Offer ends 11/24/15 at 11:59 PM EST.
This week's Weekly Special is Einszett Gummi Pflege Stift Rubber Care Stick - 100 ml.
Use Coupon Code WSGUMMI4815 to receive it for Free. A $8.99 value! Min spend $55. Offer ends 12/1/15 at 11:59 PM EST.
  • Restore and care for rubber trim and seals to keep them elastic and looking like new
  • Protects against extreme temperature and UV rays
  • Shoe polish like applicator makes the application extremely easy and smooth
This week's Weekly Special is Einszett Cockpit Premium - 500 ml.
Use Coupon Code WSCOCKP4915 to receive it for Free. A $8.99 value! Min spend $60. Offer ends 12/8/15 at 11:59 PM EST.
  • One of the best interior cleaners and protectants that leaves your finish factory new
  • Easy to get streak free results every time, great scent, and UV protects
  • Best used on your dash, gauge cluster, navigation screens, audio components, shift knobs, arm rests, leatherette, steering wheels and much more
