JAM UP PASSES though...
and you talk about losing to that cobra.
hell just the fact you were in the same zip code deserves a pat on the back
you left right with him..and made a race out of it.
you made him work for it, and unless he's familiar with your car.. you probably suprised the hell out of him...
You need to get a WOT switch at least! What was your timing on the spray at WOT?
Why can't I have spray Tommy?
you can, but please dont learn anything from this thread.
bah who needs jets.............just run that fukker wide open :shifty:
I would use the TPS switch. If your lookin into any switch other than th epush button go the TPS way. You have the best of both worlds then. The TPS switch cannt fire th eshot it the system isn't armed from the rocker switch. Thats what i use to do with my spray. launch the car then flip the switch when I wantn't to kick it. I MISS the spray BAD. Now I have my car running 13.7-13.6 all motor. Anyway if its not too much use the Tps you will never need to touch it once its set....
Hi Everyone
Do you have a wot switch on your setup? Like a rocker style? Im trying to figure out a way to mount mine but still retain the push button.
What's up buddy, why did you get rid of the spray?
Yes I have a WOT switch, it came with the kit. I have the WOT switch and then an arming switch for the nitrous. I also have a bottle heater, 15 lb bottle and purge kit. I'm using a HSW wet kit, similar to the NX wet kit. It hits hard on the 125 jet![]()
Sup man I took it off when i was making the turbo setup. now I'm running the car NA for the time being. Cannt wait to finish what i started tho. Still lookin for work... The car is making some good passes now with the new pipes. haven't gotten a good pass yet but it goes 13.6's letting off and brakes. Seems like every pass it is going faster. brokeout last two runs this weekend and not running the whole way??? i want to put the system back on and go for the 11's not sure right now.
Headers Kick some real AZZ
Yeah I have an arming switch too so it's not like I'm running straight power to the solenoid where if the pb is depressed it sprays. Idk if that clarifies anything. The kit isn't unsafe and I'll just ignore the haters...![]()
