Ignition wires with grounded braided metal sleeves over the cable have come and gone all over the world for (at least) the last 30 years, and similar wires were used over 20 years ago by a few car makers to solve cross-firing problems on early fuel injected engines and RFI problems on fiberglass bodied cars — only to find other problems were created. The recent Circle Track Magazine (USA, May, 1996 issue) test showed Nology "HotWires" produced no additional horsepower (the test actually showed a 10 horsepower decrease when compared to stock carbon conductor wires).
The perceived effect a brighter spark, conducted by an ignition wire, encased or partially encased in a braided metal sleeve (shield) grounded to the engine, jumping across a huge free-air gap (which bears no relationship to the spark needed to fire the variable air/fuel mixture under pressure in a combustion chamber) is continually being re-discovered and cleverly demonstrated by marketers who convince themselves there's monetary value in such a bright spark, and all sorts of wild, completely un-provable claims are made for this phenomena.
Like many in the past, Nology cleverly demonstrates a brighter free-air spark containing useless flash-over created by the crude "capacitor" (effect) of this style of wire. In reality, the bright spark has no more useful energy to fire a variable compressed air/fuel mixture than the clean spark you would see in a similar demonstration using any good carbon conductor wire. What is happening in such a demonstration is the coil output is being unnecessarily boosted to additionally supply spark energy that is induced (and wasted) into the grounded braided metal sleeve around the ignition wire's jacket. To test the validity of this statement, ask the demonstrator to disconnect the ground strap and observe just how much energy is sparking to ground.
Claims by Nology of their "HotWires" creating sparks that are "300 times more powerful," reaching temperatures of "100,000 to 150,000 degrees F" (more than enough to melt spark plug electrodes), spark durations of "4 billionths of a second" (spark duration is controlled by the ignition system itself) and currents of "1,000 amperes" magically evolving in "capacitors" allegedly "built-in" to the ignition wires are as ridiculous as the data and the depiction of sparks in photographs used in advertising material and the price asked for these wires! Most stock ignition primaries are regulated to 6 amperes and the most powerful race ignition to no more than 40 amperes at 12,000 RPM.
