2001 Lincoln Town Car P0351 Ignition Coil A Primary/Secondary circuit malfunction
Just replaced, each Spark Plug and each Coil Pack, two days later check engine light came on for P0351 with P0301 Pending!
The coil pack receives 12 volts, though the ground is only grounded when the PCM tells it to.
when the misfire condition i tested the ground wire to the coil pack and at first did not receive a blinking light with the test light connected to the positive side of the battery and the prob on teh connector ground side of the coil pack. However i tested Cylinder two and did receive a good strong blinking test light that blinked faster as the rpm's increased. I replaced the intake manifold was replaced a couple months ago as the heater hoes nipple deteriorated. The new one is plastic, while the other 7 cylinders work fine, it does not make since that it would be leak or faulty ground. I am going to switch the coils a with coils e and see if the misfire does not change from P0301 to P0305
