GMAN
My junkyard spot has a lot of Explorer's. Are the Explorer's equipped with 3.73 gears? Are they 28 or 31 spline?
Solid axle diffs have different side gears and will not work in an IRS setup. You can use the ring and pinion, but not the TL unit. Your best bet for finding a TL that will work is see if they have a tbird SC in the yard, that will have a TL unit, but you will have to swap the gears from the explorer onto the tbird diff since the birds only came with 2.73s, 3.27s, or 3.31s.
geno and many others remove the clips off of the axles, they swear by it say it cant move enough in car to leak let alone come out of the diffIf you put a trak-lok out of a solid axle car into your IRS, you will never again be able to remove your axles. The side gears are different from IRS to solid axle. IRS side gears have a bevel cut into them so that when you pull them out, it pushes the circlip in and the axle can come out. With the solid axle side gears, they are flat there because they are meant to work with C-clips instead of circlips. Everything will go together just fine, but the axles will not come back out, and to get them out is more of a headache than the diff is worth. If you want to put the solid axle diff in there, go right ahead, but don't complain when you need to replace an axle and the only way to do it is to replace both axles and the entire rear diff, housing and all.
i think its only supercoupes, if it has a v6 with a blower grab the diffanyone got info on which t-birds have them?...Including years and which trans type, etc?
So you think a car that makes almost the same torque as a same year diesel F350 is gonna have a 7.5" rear?
I made this statement ONCE. Geno politely corrected me on my errorSolid axle diffs have different side gears and will not work in an IRS setup.
