ILLS
I think one of the major obstacles in using this system in an LS, would be all the plumbing involved. There is not much room to work with under an LS and using a twin turbo setup would double the tubing. Not to mention the oil lines and everything else that goes with those turbos.
I've seen the STS turbo system in person in a Corvette and a Camaro. They both took up a lot of space under and in back of the car. The main thing that always worried me was the air filter down under the back of the car. I wouldn't want to drive through any deep water puddles or in the rain and forget about having your LS lowered.
But the system does work and anything is possible with enough time, money and effort.
Doing a remote TT LS would not add more tubing. Actually the exhaust tubing would be much more simple. When doing a single turbo LS you will need to Y the exhaust under the middle of the car and run a single pipe back to the turbo. This will all be new custom piping. Then if you want to retain the dual exhaust exits you will have to come back out of the turbo split the Y back off and then go to your exhaust outlets. Trust me when I say that it is a respectable amount of custom exhaust tubing work. Then all you have to do is run the cold side intake tubing to the intake.
With a TT system about 90% of your stock exhaust can be reused, as opposed to only about 40% in the single turbo. Your exhaust will be much much simpler, and cheaper I might add. Your intake tubing will be slightly more complex due to the need to merge the two cold side intake tubes before going towards the front of the vehicle. Believe it or not, the tubing on the TT would be much easier for a remote turbo LS.
There are two areas where the mufflers are that will allow a turbo to fit quite nicely. There is enough room to fit the entire turbo and conical filter as well with a small amount of room to spare. It will also allow the turbo to be mounted quite high so that it is not hanging low at all.
There are shields that are made to protect your filter element from rain and puddles. It is made to take quite a bit of direct splashes and still allow the filter to do its job unaffected. Also, I think people are much too concerned than need be on this. I have never taken my LS in more than a few inches of water and I do not see many cases where water crossing, besides the occasional puddle, is necessary. I do not think many people cross creeks in their LS's so I think for most it will not even become an issue. The area where I see concern that is truly warranted is when some of my offroader customers ask about STS turbo systems for their vehicles. That is when the filter placement and turbo placement under the vehicle become extremely critical. I usually steer them towards a PD blower at that point anyways due to them seeking a different kind of power.
