Sorry, but I have to correct that statement from my experience.
"Anyhow, point was, a marginal coil may throw a flashing CEL but..."
I have seen marginal COPs do neither (no flashing light and no DTC stored).
No prob Joe, I can understand that, your experiences were different than mine, "will" may have been too harsh, "may" would've be a more appropriate word indeed.
"However" A coil that is already marginally failing, should you choose to put the peddle to the floorboard, I'm convinced you "may" find yourself facing a short flashing light on the dash. During my experience, I was at that time still new to the LS and was learning as I went, gathering info from this forum and checking with you guys, I knew I had a misfire, it wasn't always there but during WOT it would reveal it's self, couldn't get a code from it, so as I explained, had to read code as it was flashing and it was easy for me to duplicate at that time.
I would drive it all casual and the flashing CEL would go out by it'self and no code stored, had to stress test sort a speak and read on the fly.
I'm with Joe. The only indication of a failing/marginal coil I had was a slight miss going up a slight grade and an ETC Failsafe Mode warning. Never a flashing CEL or stored code. Yes, I have nice OBD II reader.
Ok, Ok, fine, you have a nice OBDII reader, should see mine ... point was, different experiences with marginal failing coils, yours didn't, Joe had different experiences, I had mine.
Trust me I get nothing out of sitting here typing bull crap ... I was able to get mine to flash during WOT and it read P0304 when I managed to read it before it cleared itself.
As you noted, it doesn't store the code and clears it's self during same drive cycle when back to within tolarance. I could also have had a stress test performed on them to discover this but as I mentioned I clued in on when/how/why ... end result as per advice from here, was all new coils and plugs. Problem done ... stock piled some of the last Visteon's for the V8 and purchased some custom hold downs for the Accel coils from Hite Performance for when that times comes and I switch to the yellow Stang COPs ... LOL.
you fellas talking about cops should use the search function and put this whole side conversation in a thread thats actually confirmed to be about cops instead of hijacking the OPs thread about rough idle... you know, practice what ya preach bc it sets a bad example for the noobs like jjuncool!
ha
hehehe ... you have this way of bringing out the Queen G of this forum don't ya!
We know there is more to the OP's problem and "may" not be related to coils ... however, far too often, you know it, I know it and everyone else here knows it, the LS'es like to eat coils on a regular basis unless it's done right and not beaten on, on a daily basis. Think of the expensive Catalytic converters others are trying to save the man!
Goes without saying, there are furter items to check to clear a rough idle, MAF, fuel & air filter, looking for leaks and so one.
I know you don't like it but COPs and Plugs are priority on that list.
