No Shag, looking at ID as a form of teleology is different than looking at evolution as methodological naturalism - you hadn't discussed teleology - or if you did - can you post a link, I would be interested in seeing what was discussed previously.Look for anything having to do with methodological naturalism.
Teleology looks at the beginning and end point and then assumes that the interim points 'had' to line up to get to the end point, in this case, human beings. In ID we are the end result - and that we were 'designed'.
Where? Can you prove that? It looks like nothing more then speculation and conjecture on your part.ID 'assumes' we are the desired result.
The idea is that the difference between evolution's natural selection and an intelligent designer is that a designed object is planned in advance, with forethought, and an 'end product' has been envisioned. If we are a result of intelligent design, then we are part of that designer's desired path. We might not be the end of that path - but we are part of that path - a desired result of the proceeding steps, and perhaps a needed step in the continuation of the designer's 'plan'.
I assume you are talking about the 3rd definition, as that would seem most appropriate to this discussion. ID assumes no purpose. In fact, it assumes nothing. But it does know the end result; humans, and various other species today. Fossil records give an indication of life long before today. All this is the same for both ID and Darwinism. The only difference is that ID doesn't interpret how life came about by first disregarding the idea of anything other then natural causes. Darwinism assumes there is no explanation other then natural causes, then looks at the information and concludes Darwinian evolution is the means of creation of the various forms of diverse life.
ID takes the events required to make a human and uses that end result as a conclusion that without all those events lining up in a certain way that we wouldn't exist. It then adds an 'intelligent designer' to move us from point A through a myriad of additional points to end up at point Z. ID assumes that design equals intelligence. But if you look at chaos and complexity theory, they have established that order does appear as a property of interactions among different parts of a system. That order (design) can occur as a result of naturally occurring events and can be recreated without the interference of 'intelligence'
Darwinian evolution cannot be tested. It never has been and won't be. The process takes too long to test (millenia). What Darwin calls adaptation, and others call evolution can be tested. But in any discussion of ID verse evolution, "evolution" is referred to in the Darwinian sense as that is the only type of "evolution" that ID challenges. If you are going to keep saying evolution when referring to what Darwin calls adaptation, you are perpetuating a dishonest equivocation.
So, what empirical results can ID point to shag? I am not looking to mislead or hedge anything shag, but unless you can point to empirical results on behalf of ID I will go with emergent properties. Once again, science has both tested and recreated evolution. Not just adaptation, but evolution shag...
I understand that you are claiming ID assumes something when it doesn't. ID looks at the info available without any preconceived notions (assumptions) and concludes that life could not come about randomly, and that it is more likely due to some sort of intelligence intervening in the process.
So, Shag - ID not only assumes end result, it assumes that design has to occur on behalf of an intelligent entity. It assumes that without intelligence intervening in the process, as you stated, we wouldn't be where we are today. Correct? It assumes 'intelligent' design. Shag, you do understand that there is provable design without 'intelligence' within science - right? Just like you understand the skyscraper analogy - right?
Second, to call ID a teleological process is to mischaracterize it and set up a straw man; something most people seem to do without realizing it when it comes to ID (the disinformation and lies about ID are very pervasive).
ID is a teleological process Shag - An object or a behavior is said to be teleological when it gives evidence of design or appears to be directed toward certain ends. You are using bounded or 'intelligent' design to create an end result.
Darwinism is not a teleological process because it doesn't care how 'we' ended up. We ended up as we are because of selection - not as a preconceived notion by an intelligent designer. If you assume intelligent design - you assume the designer has an 'ending design' in mind, therefore that is the difference, and why Darwinism isn't a teleological process. Darwinism doesn't have a preconceived notion on how the end result will look/act like, however ID, which involves the concept of an intelligent designer has an 'end game'.
If that isn't the case Shag - then the question is: Why go down the path of intelligent design, if we aren't the intended result, or at least on the path of the intended result? Can you answer that shag?
