ID does assume there ‘is’ a design – not ‘if’ there is a design. Why call it Intelligent Design unless one assumes an intelligent designer is behind the whole thing?
So, because it is named "Intelligent Design" it must assume intelligent design
a priori? If you actually educated yourself on ID you would know that is not true and is patently absurd.
The fact of the matter is that ID is named after the
conclusion the theory reaches.
You are trying to mischaracterize ID through a
style over substance fallacy:
Style over substance is a logical fallacy which occurs when one emphasises the way in which the argument is presented, while marginalising (or outright ignoring) the content of the argument. In some cases, the fallacy is employed as a form of ad hominem attack.
You are looking at the name of the theory to draw conclusions that are A) wrong, and B) don't follow from the premise.
If you look solely at the name of the theory to find out weather it is a teleological process, the name could be due to an
a priori assumption that the theory makes (confirming that it is a teleological process)
or it could be due to an
a posteriori conclusion that the theory asserts (which would mean it has teleological implications, but is not, in and of itself, a teleological process). To prove either way, you have to be familiar with the theory, which you clearly are not.
Here is the thought process of Darwinism:
- Assume methodological naturalism
- Test (in some fashion) the hypothesis that new species are created through purely natural means
- Observe and interpret the findings
- Due to the info and its interpretation through the prism of methodological naturalism, conclude that the hypothesis is proven correct
Here is the thought process of ID:
- Test (in some fashion) the hypothesis that an intelligence is at work in the creation of new species
- Due to the info, conclude that the hypothesis is correct
What you are doing is asserting that there is an extra step in the ID thought process
before the first step and that the step is that there is an assumption of intelligent design. You are asserting this with a profound and obvious ignorance of what ID is and is not. However, you seem to have no interest in learning what ID really is.
The
IDEA (Intelligent Design and Evolution Awareness ) center has even a little ‘
Primer’ on the basics of ID shag – want to know what the first sentence is in that primer?
Intelligent design is the assertion that "certain features of the universe and of living things are best explained by an intelligent cause, not an undirected process such as natural selection."
Yes, that is the
conclusion that the theory reaches and what it, thus
asserts.
All scientific theories have a conclusion that they assert. You are mischaracterizing the nature of scientific theories to perpetuate your mischaracterization of ID.
Also, the quote does show that ID is only concerned with weather or not there is a design; design
detection. Not the
study of a design, so not a teleological process.
They ‘assert’ – wow – not ‘are looking into,’ ‘wondering if there is’… No ‘ands, ifs or buts’, they ‘assert’ - to state with assurance, confidence, or force; state strongly or positively; affirm.
Assertion does not equal assumption. and
definitely not an assumption,
a priori.
In fact, what you are doing now is spinning to setting up another type of fallacy call the
texas sharpshooter fallacy:
The Texas sharpshooter fallacy is a logical fallacy in which information that has no relationship is interpreted or manipulated until it appears to have meaning. The name comes from a story about a Texan who fires several shots at the side of a barn, then paints a target centered on the hits and claims to be a sharpshooter.
The name of the theory of "Intelligent Design" has nothing to do with any
assumption being made, but you are spinning and manipulating to characterize it as an assumption.
Do you really understand the blind man and the skyscraper analogy with regards to ID?
Yes.
So, what empirical results can ID point to shag?
I have already answered this plenty of times in other post, but you don't seem to want to accept it, so let me spell it out for you.
All the info you cite also points to ID as it empirically proves only adaptation.
Why go down the path of intelligent design, if we aren't the intended result, or at least on the path of the intended result?
I refuse to answer this question as it is a loaded question. Don't mistake this for an attempt to dodge the question in some fashion. I am directly saying, I refuse to answer this question.
It is a loaded question in a couple of ways.
First it mischaracterizes ID as some sort of exploratory path or process to determine
what the design is, when the theory is not even concerned with
what the design is. It is only concerned with detecting
if there is a design. Your question inherently mischaracterizes ID.
Second, your question inherently assumes that you have met the burden of proof in proving that ID is a teleological process when you haven't. All you have offered are specious arguments and baseless postulation. You are, effectively, attempting to deceptively shift the burden of proof; another fallacy.
What you are doing with your "teleological" talking point is to effectively assert and trying to justify a
distinction without difference. Outside of methodological naturalism and what that implies, there is absolutely no difference between Darwinism and ID except the conclusion, which ultimately stems from that difference in methodological naturalism. The process to reach the conclusion is the same except for methodological naturalism, but you are trying to claim that the process is different. This is based in ignorance of both Darwinism and ID as well as a blatant and willful attempt to obfuscate.
It is patently clear that you are more interested in rationalizing your attempt to dismiss ID as "bad science" through your "teleological process" talking point then you are in actually understanding ID and getting to the truth of the matter. That demonstrates a definite prejudice
against ID. Your habitual fallacious arguments here (proof by assertion, straw man fallacy, style over substance, shifting the burden of proof, texas sharpshooter fallacy) demonstrate that your bias has clouded your judgment here, and further confirm that you have a prejudice against ID. It is abundantly clear that there can be no honest discussion with you on this subject due to your prejudice against ID.
