At least on the '03-'06 LSes, the PCM is on the firewall behind the glove box. The PCM is in the passenger compartment, but its harness is in the engine bay, so the wires you seek would be in the engine compartment.
SoonerLS said:At least on the '03-'06 LSes, the PCM is on the firewall behind the glove box. The PCM is in the passenger compartment, but its harness is in the engine bay, so the wires you seek would be in the engine compartment.
from http://avic411.com Ive read the following
00-02 have a grey/black wire(make sure its not the speaker wire) behind the radio
03+ Speed Sense white/black driver kick, 20 pin plug, pin 9
Sure it does! How else does the car know how fast it's going? There are many items on the car that need VSS information.
On my 2003 Aviator, the radio had speed sensitive volume. The VSS signal is sent directly to the head unit and is in one of the connectors in the back of the radio. It is a gray wire with a black stripe. If I recall, the connector only had 2 or 3 wires in it...the rest were blank. It was a 6 disk radio. There has to be a VSS signal in the car...if you can't find a wire, it may be on the CAN Bus. If so, there are adapters out there. But I'm betting you have the wire to your radio on your year.
The VSS signal is also present to the windshield wipers if you have speed sensitive delay.
Hate to revive a 10+ year old thread. But I'm needing to figure out which wire is the speed sense wire for an install of a Kenwood DMX906S in my 2002 Lincoln LS. A poster above stated that it's the grey/black wire at the back of the head unit on my year of LS. Has anyone verified that? Thanks!
...I'm assuming that the only way for that to work is that there is already a speed sense wire going into the back of this head unit. Would my assumption be correct?
The wire you would need to tap into for the transmission output shaft speed sensor is white with red stripe, pin 26 of PCM connector C1758. It looks like at the PCM and at the sensor itself are the only two places it is at. It does say that the output shaft sensor is on the left side of the transmission.
Note that there is also a white wire with red stripe at pin 23 of the PCM. This one is the transmission temperature sensor.
Thanks! That'll save me some time. Can you confirm whether this wire is AC or DC? I'm sure a dumb question, but I swear I read a post somewhere that stated it was AC.
