ya , not with the sct thoughQuik LS said:I'm confused by this statement - you say you run a 100shot with no problems - but then you say you haven't been tuned yet.....
Have you really ran it yet on 100shot?
zexls said:ya , not with the sct though
I tuned the nitrous by using different jets trying to get the right air fuel mix.Quik LS said:sorry - still confused...
ya - you're tuned, but not with the SCT? Then with what?
or
ya - you run 100shot untuned
MrWilson said:oh yea, i know what your talkin bout....but seeing how the mark is runnin the B heads...it kinda makes it hard to bolt other intakes(specially the s/c) so id need heads and all too...longblock is a better option for me.
i checked out vt...their shortblock is $3495...i can get a longblock with the s/c for $3750 from my ford dealer...dont ask how, price is for me alone.
zexls said:I tuned the nitrous by using different jets trying to get the right air fuel mix.
2001LS8Sport said:I have seen some HORRIBLE nitrous explosions with wet kits...blows the manifold clear off the car. That's what can happen with puddling, etc. It's rare...but I've seen it. It's even rarer with a dry kit...and with the availability to tune for it with the SCT now, it makes no sense to add the extra expense and work involved to go wet. However, you need to make sure you have the fuel capablities and injector size to keep from going lean. With a small shot, you're probably ok...but the only way to know for sure is to toss it on a dyno and have the a/f ratio checked and make sure your MAF sensor isn't maxing out. Just MHO......
I agree you need to run the right plugs if not your fighting an up-hill battle.....You get s copper plug with a short strap(the finger looking thing) and you get 1-2 ranges colder (anything 100hp shot or more) and then back the timing 1-2 degrees (per 75-100hp) and you will have a much better running system and you will get a longer life out of it because you will not have any detination....Also run 93+ octane this will keep the car from having detination also(the ls need this no matter what but other cars that only run 87)....You will be so much happier in the long run by doing this....rocket5979 said:Ok, so you were running a wetshot to roughly set the A/F then.
Not trying to knock anyone's tuning preferences here but such things as spark timing retard and also spark plug heat range are some other things that are best addressed so as to prevent an engine blowing.![]()
Quik LS said:well - I'm no expert here - isn't that simply changing the 'shot' size?
the 'rule of thumb' is to decrease your spark by at least 2 degrees per 100hp. Most nitrous guys end up going at least a degree cooler plug at 100shot as well - while change to a standard cooper plug with a different gap. the nitrous reacts badly with the platium in our OE plugs.
the only way I know to change your spark and fueling curve is to use the SCT and flash the PCM with new curves.
so if you are reducing the nitrous jet - aren't you simply reducing the shot?
I not trying to call you out - I 'hang out' with the local racers sometimes here - 75% of them have a nitrous bottle in their cars, colored purge plumes all over the place..... but less the a handful actually have tuned and put a bottle through their engine. Most of their installs a for 'show' only.
I want to understand when you say 'I run a 100shot no problem' if that is really the advice you are giving because you have figured it out...
I ran 100shot only a few times - before the SCT tuner was available - and the a/f ratio was way way way off - I would never recommend it without the tune.
zexls said:No, What I ment is that with the wet kit i used i have never had a backfire or
any thing like that. I have used no2 on 3 cars and 1 bike and I am still learning the in and outs.
Quik LS said:cool - we are all learning....
so if you reduced the NO2 jet to maintain a proper a/f ratio - it's not likely you are running a 100shot any more....
our testing with a 75shot still put the a/f meter off the lean side of the scale....
zexls said:What engine size they are projecting the power gains. 302,351 ect.
When you use a jet chart it is for a 4cy V6 or a V8, but do you use the same jets for a 289ci that you would a 460ci? A far as tuning my LS I have tryed to stay around the recomended jet size. I am trying to put mine on the dyno when I get the time.Quik LS said:so maybe I'm slow.....
but you respond to the queation about 'you really are not running a 100shot' with this.......
"What engine size they are projecting the power gains. 302,351 ect"
what are you asking? 302, 351...?
OK what they do that for is two reasons....First being that a v6 and a v8 you can spray a bigger shot on an eight....and it you look at the 4 6 8 kits the nitrous for a 75 is the same (so are the 100 and etc....) the difference is the Fuel Pressure.... when I built a kit to ship out a 4cy would get a 35 50 and 75 and eight would get 100 125 150 and some 175...zexls said:When you use a jet chart it is for a 4cy V6 or a V8, but do you use the same jets for a 289ci that you would a 460ci? A far as tuning my LS I have tryed to stay around the recomended jet size. I am trying to put mine on the dyno when I get the time.
I use 30 fuel and 46 No2, on the ZEX jet chart the jets for a V8 100 shot are different than a V6 100 shot.SilverLS said:OK what they do that for is two reasons....First being that a v6 and a v8 you can spray a bigger shot on an eight....and it you look at the 4 6 8 kits the nitrous for a 75 is the same (so are the 100 and etc....) the difference is the Fuel Pressure.... when I built a kit to ship out a 4cy would get a 35 50 and 75 and eight would get 100 125 150 and some 175...
Like I said If you post what brand jets your using and size I can tell you what you should expect....
the N20 should not be...the fuel is though...zexls said:I use 30 fuel and 46 No2, on the ZEX jet chart the jets for a V8 100 shot are different than a V6 100 shot.
SilverLS said:OK with the jets your running you have a 96 hp shot and your fuel jet is bigger than it needs to be so your safe...Your going to run rich with it so your safe....you should expect to get 81-82 HP at the wheels....
Quik LS said:I understand it was a wet system - it's right about the 30 - 34 jet that you will be on the edge of OE fuel pump - with the incredible tuning that the OE's do on these engines running such little injectors - the entire fuel system ends up being much smaller than you would ever expect.
I could never get my a/f good all the way through the rpm band using the fuel jet only - I ended having to cut back down to a 75shot.
