ALVIN C LONG
I'm from Biloxi ain't this a small world lol. But how did you remove the 10mm bolt from top of the transmission thats the only thing stopping me right now
Search the posts on here from those who have done it.
It's a pain to get to the bolt on top of the transmission that goes through the electrical connector and into the solenoid assembly.
You need a pump of some sort to get the transmission fluid in after you are done.
Stay away from the chain transmission shops. Find a good local independent shop if you can't do it yourself.
It can be done without a special wrench, but boy is it a nightmare to say the least.Like he said, special wrench. I cheated both times. The one on the 04 was under warranty, and at 200K my 06 was in need of a transmission rebuild. (The 04 is well over 200K, and its transmission is still good.)
I've been in Gulfport about 20 years now, but I was where i actually came from for longer than that.
Yeah im not spending that type of money on a special tool. I'll just have to figure it outIt can be done without a special wrench, but boy is it a nightmare to say the least.
Exactly what I did for the thermostat housing bolts I bought a used snapon wrench and made my life so much easier. I picked up the tool for like $10 and it looked brand new. So I would check out ebay these tools are good to have. The 5r55 series tends to have the same problems so it could be a good thing to have in case you ever have to change it again for some reason. If people are not willing to spend a few extra dollars on a tool they have bought the wrong car for sure. Cause tools would be the least of my worries with all the expensive maintenance and such that has to be done on the LS.Again... Craftsman or Harbor Fright might have something similar... Or you might be able to pick up a used one on eBay cheap.
Guess I'll be getting this thing cut so I can get the ball rollingGuys - I finally got the 10mm bolt out. I went to Autozone and bought one of their ratchet wrenches in the 10mm size. We have a machine shop at work, and I asked one of the machinists to cut it down to 3.5". I then used the ratchet to help get the bolt out. Once I had the right tool, it still took 10 min or so to get the bolt out, because of the tight space.
I am shopping around online now for a replacement solenoid pack.
How did u work around the shift cable bracket I removed the bolt and the damn thing is still in the way really doesnt clear the way for meGuys - I finally got the 10mm bolt out. I went to Autozone and bought one of their ratchet wrenches in the 10mm size. We have a machine shop at work, and I asked one of the machinists to cut it down to 3.5". I then used the ratchet to help get the bolt out. Once I had the right tool, it still took 10 min or so to get the bolt out, because of the tight space.
I I R C... you can remove the PRNDL switch, ...
It's the DTR. Digital Transmission Range sensor.
2006 Lincoln LS Workshop Manual
Update after fighting for a good 5 mins finally got that cocksucker lol
I pretty much swap mines out the same day. Shift soleniods and vavle body. Gotta add fluid in the morning had to make me a custom pumpAlvin - No doubt it was a sum-bitch.![]()
I ordered my solenoid pack yesterday. I saw some cheap on Ebay, but I couldn't confirm that they would be exact fits in a 2000 model LS. I ended up buying one from RockAuto for $309.
I will probably put it in next weekend. Keeping my fingers crossed...
Jason
