04_Sport_LS
It should take roughly 8 - 9 quarts... Possibly more if you blew out the aux cooler with compressed air.
I can shift SST 1-5 up and down but still no reverse. So I still drive it just easy on the trans. I'll be getting mines swapped out in 2 weeksLooks like mine was a failed effort also. Its not the solenoid pack. Its doing the exact same thing. Its also not shifting quickly anymore, but I think I don't have enough fluid in there. Looks like I need a new transmission as well.
When I added my trans fluid I put too much and it was leaking from the top and the flywheel cover ooopsIt should take roughly 8 - 9 quarts... Possibly more if you blew out the aux cooler with compressed air.
You need to ensure the correct amount of fluid is in there or it won't work correct. Make sure the fluid is good before giving up on it. Also be sure to look with a code reader to see if any new codes.Looks like mine was a failed effort also. Its not the solenoid pack. Its doing the exact same thing. Its also not shifting quickly anymore, but I think I don't have enough fluid in there. Looks like I need a new transmission as well.
Yeah it stopped leaking. You think the band adjustment will help my reverse?There is a vent tube that runs from the body of the trans to the bellhousing. Fluid dripping from there is normal if overfilled. It would stop after a couple days of driving.
If it's not too late and toast... The trans might need a band adjustment. There are a few threads on here that cover that.
Here's one:
Band adjustment
10-4 Dale. AutoZone told me I needed 5 quarts, but when I checked the level at the bottom drain, none cl
If you did not check out the valve body there is always the possibility that the reverse spring in it is binded or broken that is why when I replaced my solenoid pack I replaced both that and the valve body. These cars has issues with both of them parts in general so I felt it was better to replace all that together.Yeah it stopped leaking. You think the band adjustment will help my reverse?
I also replaced the separator plate on mine but the old one looked ok but I also had heard they were known to have issues. So I went with the better safe than sorry method as I did not want to have more issues down the road.Maybe. Joe would know better. I don't have time to look at the shop manuals... And so far I have been blessed, ( so far ), with a well functioning transmission at 213k. It could also need the valve body rebuilt. I know there was a TSB for the separator plate in the valve body a number of years ago... And an issue with broken springs.
I did a quick search on the 5r55s and found this.
[5R55S] No Reverse | Can't Take Off In 'D'
It's for the Exploder... But basically the same trans.
I replaced both and also moved the metal looking thing and it moved and sprung back into place. All the bands from what I see when I dropped the valve body looked good. Nothing was on the magnetic no shaving or everythingIf you did not check out the valve body there is always the possibility that the reverse spring in it is binded or broken that is why when I replaced my solenoid pack I replaced both that and the valve body. These cars has issues with both of them parts in general so I felt it was better to replace all that together.
I just read this and he did the seafoam transmission and workedMaybe. Joe would know better. I don't have time to look at the shop manuals... And so far I have been blessed, ( so far ), with a well functioning transmission at 213k. It could also need the valve body rebuilt. I know there was a TSB for the separator plate in the valve body a number of years ago... And an issue with broken springs.
So as I pump in the new transmission oil the car has to be on right? And once it starts to come out then that means it's at right level Correct me if I'm wrong please lolIt should take roughly 8 - 9 quarts... Possibly more if you blew out the aux cooler with compressed air.
Thanks bro I did it yesterday and it's riding smoothly now way better All it needed was 1 quart but for some reason it still says check transmission while I drive it and the letter E keeps popping up but the car shifts smoothly by any chance do you know what that could be I read in one article it could be a computer of some sort ???Yes once it starts dripping from that hole it at maximum capacity
I know this is old but FWIW you can cut a 10mm wrench in halfI just dont have 72 for a single tool but I appreciate the help
Good call...I must be thinking of the solenoid packOnly if you have a hex drive to square drive adapter... and the proper socket.
The bolt for that connector is sunk down in the middle of the plug.
