04_Sport_LS
Well by the original symptoms and condition of the fluid, (and knowing the fluid from the factory was missing an additive), the tranny still needed a rebuild.
Yeah, I have no doubt about that. I just think I could have possibly gotten by a little longer if I had actually replaced the valve body before having it rebuilt. I think if the valve body is bad then that played a major role in the failure.Well by the original symptoms and condition of the fluid, (and knowing the fluid from the factory was missing an additive), the tranny still needed a rebuild.
I may just let it sit for another week and save up for a new solenoid pack just to be sure. This crap has me nervous, to say the least. I am going to try to make them at least eat the cost of the labor in doing this crap since I have a transmission warranty and if they did not do this crap during the rebuild then they need to pony up and do it now if I provide the correct parts.Should be, (notice I say "should"). I would think they would have flushed that out with some sort of degreaser before reinstallation.
Correct. And I even had them replace the Transmission Range Sensor during their rebuild because I had a spare new OEM one for my previous LS that I had never gotten around to installing! I knew how them things can have issues on the older LS and since I had a brand new part I said use it please!So basically... while the tranny was actually having issues originally... the new symptom after the rebuild... is "shift flare"... correct???
I am going to call them tomorrow but they said they checked that on their 500-mile check and it was in line. I am going to go to another shop first before calling them just to be sure they got it right. I am trying to get a 2nd set of eyes at another trusted shop in town before I call so I can have all my ducks in a row.Well if the TRS is slightly out of adjustment... it's possible (maybe) that it is the issue... but I would consider that a "Hail Mary" fix.
The TRS not only controls the solenoid pack... it (indirecty through the PCM) reads the throttle position at the pedal and throttle body.
Joe will correct me if I'm wrong about that, (or if it's more complicated than that)
But if I find out the dang valve body didn't get addressed then the car is going to stay parked till that is replaced as I don't want to doom this transmission right off the bat. I would have a lot more mileage on it than the 700 miles if I felt safe driving it! But I cringe inside each time it flares! I will say though driving it harder has less of a flare, but it does have one still.Sounds like a good idea.
I would much rather it be the cable or TRS than anything inside of that transmission that they just did! But still would have a new valve body installed before I drove anymore if it never got done. I don't want to have issues later on down the road that could have been prevented in the first place. And I am even looking at that Sonnax upgraded solenoid pack if I buy their valve body.Then that might be an issue with the cable and/or TRS. I say "might be".
I still think the bands need adjusted...
