Turbo Mark VII Time
Now the whole top half of the motor will be far to big for the bottom half.
Heads-5922 by Detroit Style, on Flickr
Next step is to clean up all the packed dirt, install the Team Z suspension, Cobra brakes, eliminate the electric brake booster, remove the rest of the engine harness and remount the intercooler into a new spot I found.
Dirty-6056 by Detroit Style, on Flickr
With out a flash under the car, the intercooler hides rather well.
untitled-6400 by Detroit Style, on Flickr
untitled-6405 by Detroit Style, on Flickr
untitled-6404 by Detroit Style, on Flickr
So, its no mystery if this project has stalled but there is a reason. I'll hopefully be closing on this non 1 car garage place to live next week.
I also had the conversation with the shop about getting a cam made for the motor as well so, things are still going forward, just at a slow pace.
I am very interested in what wires you took out & is every thing still working ??? I am also doing a project after a fire also I have no air bags or elec master cyl,need brakes,need info
noelhulsey@yahoo.com
thx noel
thx noel
I removed the air ride and brake system wiring from the car. Next up is the security system and that complex hunk of crap.
In theory every thing will work. The dash lights, and all exterior lights work. The engine harness was had two burnt connectors on it and after messing with it, I decided to get a new 1 piece harness later. I did find that some of the engine harness shared wires with the rest of that big harness so, if the car fires on the first try or not is unknown (the new harness should make that a non issue).
we are on few other forums together, and i have been watching this since day one. Congrats on the house. Tell me what other projects have you had?
Got the rear springs in today. Once I pull the rack off the other K, clean it up and put it in to the car, the car will be ready to head into the chassis shop.
BCN_7586 by Detroit Style, on Flickr
BCN_7585 by Detroit Style, on Flickr
Well, its ready to go to the chassis shop. Depending on how the car sits with the rear control arms that are being made for it, I may go back to the old springs to lower it.
BCN_7639 by Detroit Style, on Flickr
So, this one time I tried to put a 100lb 5ft long hood on a car by myself...
BCN_7652 by Detroit Style, on Flickr
BCN_7651 by Detroit Style, on Flickr
BCN_7642 by Detroit Style, on Flickr
BCN_7649 by Detroit Style, on Flickr
BCN_7655 by Detroit Style, on Flickr
BCN_7658 by Detroit Style, on Flickr
It's last night home for a while.
BCN_7664 by Detroit Style, on Flickr
On its way to Detroit for some chassis work.
BCN_7666 by Detroit Style, on Flickr
BCN_7667 by Detroit Style, on Flickr
The car is now at the shop, awaiting some love.
BCN_7670 by Detroit Style, on Flickr
BCN_7671 by Detroit Style, on Flickr
This should give you guys some hope, the Pacer X is one of his current projects.
BCN_7698 by Detroit Style, on Flickr
BCN_7693 by Detroit Style, on Flickr
BCN_7686 by Detroit Style, on Flickr
BCN_7681 by Detroit Style, on Flickr
Small update, the chassis work has started.
200,000 miles took its toll on the front control arm bolts (all of the suspension bolts really).
PSA: Do not stick your camera this close to a lit torch and oil/grease covered parts.
BCN_7933 by Detroit Style, on Flickr
BCN_7930 by Detroit Style, on Flickr
BCN_7926 by Detroit Style, on Flickr
BCN_7924 by Detroit Style, on Flickr
Someone out there must want a 5 lug conversion for the front of their Mustang... BUY THIS!!
BCN_7938 by Detroit Style, on Flickr
*No cameras or camera equipment was injured during the making for these pictures.
Got a sneak peak from the shop last night.
Started to make new seat brackets for the car.
BCN_8065 by Detroit Style, on Flickr
BCN_8076 by Detroit Style, on Flickr
BCN_8085 by Detroit Style, on Flickr
The hardest part so far, the bracket next to the tunnel has to have a contour made to go around the tunnel.
BCN_8091 by Detroit Style, on Flickr
Time to make a new way of mounting the seat, it sits far to high to be usable.
BCN_8251 by Detroit Style, on Flickr
BCN_8250 by Detroit Style, on Flickr
BCN_8249 by Detroit Style, on Flickr
BCN_8248 by Detroit Style, on Flickr
BCN_8246 by Detroit Style, on Flickr
BCN_8244 by Detroit Style, on Flickr
Recently, I had a snow tire let go on the beater and having killed two factory 18s, I decided to order to wheels for it. Downfall, no one had them in stock due to the bolt pattern. Well, the new wheels came in today so, I swapped the tires from the factory 18s over and put them on the car.
BCN_8271 by Detroit Style, on Flickr
BCN_8270 by Detroit Style, on Flickr
BCN_8268 by Detroit Style, on Flickr
BCN_8265 by Detroit Style, on Flickr
The rear coil overs came in yesterday and I put them on today. It is safe to say that with no weight in the car, I'll have to raise it up about an inch and do some fender work.
BCN_8353 by Detroit Style, on Flickr
BCN_8370 by Detroit Style, on Flickr
BCN_8374 by Detroit Style, on Flickr
BCN_8380 by Detroit Style, on Flickr
BCN_8376 by Detroit Style, on Flickr
BCN_8390 by Detroit Style, on Flickr
Yeah, I think I need to pull the fenders out a bit.
BCN_8395 by Detroit Style, on Flickr
BCN_8393 by Detroit Style, on Flickr
Picked up a different turbo than the On3 one that I have.
BCN_8599 by Detroit Style, on Flickr
Playing around with potential turbo placement and debating going to a tube front to make more room.
BCN_8629 by Detroit Style, on Flickr
Ready to pull all the wiring out of the car, a Mustang dash and a new column as well as finish pulling out the sound deadening.
BCN_8640 by Detroit Style, on Flickr
Figured that I'd knock out some work today so, here are the mid evening update. The column support is out, the main harness is about ready to be fully pulled out of the car and, the parking brake assembly is gone for good.
Parking brake cable is dying to get out of there.
BCN_8654 by Detroit Style, on Flickr
BCN_8663 by Detroit Style, on Flickr
The quicker, more pleasant way of taking the wiring out of a car.
BCN_8673 by Detroit Style, on Flickr
BCN_8676 by Detroit Style, on Flickr
It's starting to look like a welcoming home to a Mustang dash.
BCN_8677 by Detroit Style, on Flickr
Started to make a mold fo the deck lid in order to make a lighter than steel version.
BCN_8699 by Detroit Style, on Flickr
The car was a really nice color before the last owner made it flat black.
BCN_8703 by Detroit Style, on Flickr
Lots of waxy goodness ( I knew I kept this garbage wax for a reason).
BCN_8705 by Detroit Style, on Flickr
Made sure to keep the hump for all the Lincoln looks as possible.
BCN_8717 by Detroit Style, on Flickr
Left off with this for the night, tomorrow I'll attack the top side.
BCN_8720 by Detroit Style, on Flickr
Well, for a first attempt at a large panel mold, i don't think its too terrible. There is a lot of room for improvement but, not horribly terrible.
BCN_8721 by Detroit Style, on Flickr
BCN_8722 by Detroit Style, on Flickr
BCN_8723 by Detroit Style, on Flickr
BCN_8728 by Detroit Style, on Flickr
BCN_8729 by Detroit Style, on Flickr
BCN_8730 by Detroit Style, on Flickr
BCN_8731 by Detroit Style, on Flickr
I must have done something right, it fits with out the metal deck lid under it.
Now, its time to take what I learn from what I did wrong and do it for real with carbon.
I started to order stuff again, last week my motor plate stuff came in from Skinny Kid, this week a bunch of stuff from Rhodes Race Cars should be here. The goal is to have all the chassis work done by fall. Leaving the drive-line and fuel system for the winter/spring.
Started cleaning up the engine bay, there will be filler panels made for the firewall and then everything will be blasted, sealed and painted.
BCN_3282 by Jason Bacon, on Flickr
BCN_3280 by Jason Bacon, on Flickr
I haven't touched this car in a while, mostly due to have 0 money after bills have been paid but, that being said, I did just get back from the store, I am going to attempt to de-power the rack and get it setup to work with the SN95 spindles. The debate is, do I make a video of it or just a few pictures.
BCN_5541 by Jason Bacon, on Flickr
BCN_5542 by Jason Bacon, on Flickr
BCN_5543 by Jason Bacon, on Flickr
BCN_5545 by Jason Bacon, on Flickr
BCN_5546 by Jason Bacon, on Flickr
Well, the de-powering failed. The seal at the top of the steering shaft isn't removable. The good news is, the rack must be so far gone that, its actually real easy to move by hand so, I put it back together and put the SN95 bits on it. Tomorrow I need to get some sealant to seal up the ports for the fluid and install the rack again. It will be nice to not have floppy pickle wheels to make moving the car easier.
I should also say, I have been dicking around with the engine bay, slowly getting it stripped and ready for paint and fab work.
14902856_1730454500612259_6946149336847125794_o by Jason Bacon, on Flickr
Musical motivation provided by:
[video=youtube;gnslHZB_ukc]https://www.youtube.com/watch?v=gnslHZB_ukc[/video]
