pwr2killayak
^a race is the only way to tell(and take videos). jk. not really.
It looks to me like you put the turbo in the rear quarter, is this correct?
Did you have a blow-off valve anywhere?
You manage to put together a working kit in under a month or two? And show numbers, and possibly have it ready for manufacture within the next decade.
Quik's is setup for autocross I think. But I'd love to see what 1/4 mile numbers yours puts down.
How long do you think the engine will last, this has to severly decrease engine life right? Even if it's a modest amount of boost it's still a small 3.9 engine.
Second why a Garrett turbo specifically? What makes that special that you chose it?
And third what is the gas mileage like with a fuel pump out of a 5.4L car and 39lb injectors?
Im not pretending I know anything about any of what your doing. I'm just interested in all this, trying to learn. Beleive me I have an extreme amount of respect for you for doing this. Not only that but Quik's project is going on like 2-3 years now and there is no way all that custom work will ever be manufacture in a kit and we still haven't heard numbers, just the supercharger whine. You manage to put together a working kit in under a month or two? And show numbers, and possibly have it ready for manufacture within the next decade.
Lookin' good, man. Lookin' good!
What's out there for the STS as far as keeping the air filter from getting soaking wet on a daily driver? Custom shield, box, etc.?
lets see a WOT run on video?!
There is a filter shield that goes for $35. Another option is the Outerwears Drycharger "sock" that goes over the filter itself to keep water and debris away. That retails for $29.
Tuning- Did some tuning today. The part throttle and WOT A/F's are dialed in. Right now I have it set to only hit 2 psi of boost. Even on that low of boost and with tons of spark timing pulled it still pulls pretty hard.
You had to pull tons of timing on 2psi with the A/F dialed in correctly? Is the reason due to the 3.9s high compression ratio?
Are there any Pros or cons to a remote mount turbo?
You'll probably want to shield that before too long to keep the heat from melting your bumper.Ive always leaned more towards a Turbo than a Blower as the best way to add power. They're easier to hook up, make better power when tuned properly, and turbos just sound so cool once you get them spooled up. Great job man!
