Putter-GLHT
What Turbine are you using if I may ask? (A/R, Housing, Dia)
what about the mufflers and/or resonators?...
I am sad, I like numbers. You will post dyno slips after you spin the rollers no?
For sure, I hate midwestern winters for that reason. You know they keep racing all winter in the south....
Yes I will. The timing for when I finished the turbo system was not conducive to posting numbers shortly afterwards. I finished the system, tuned it, and the bad weather started setting in right after. The Illinois winter is to blame for that. I am sure that coming from Iowa you probably understand what I am talking about. In the springtime I will dig the car back out of its winter hibernation spot in the garage and drop the boost controller on it to raise the boost to 6 psi. Once I have rechecked the tune for the new boost level and fiddled with anything I might need to fiddle with then I will drop it on the rollers to see what it makes.If weather, and the terrible salty roads, permitted the car would have already seen the rollers a long time ago.
From a purely theoretical, math-driven basis, the improvement should approach forty percent. Subtract a little bit for pumping and frictional losses and something over thirty five percent is easily to be expected. I'm waiting with bated breath !!!
KenS from Ben's Place
There are many more variables to calculating the power gains in a forced induction piston driven engine. Using the simple pressure ratio formula you described does not take any of these into account and thus is usually very inaccurate. I tend to use personal experience with how much power is generated per pound of boost. In most turbo systems running lower IAT's you will gain anywhere between 17-24rwhp per pound of boost. Some have gained as much as 26rwhp per pound but most average right about 20rwhp per pound. Even that does not take a few things into account but it is usually a better average estimate than then pressure ratio method. We will see.
Your 20 hp per pound times 6 pounds would equate to 120 additional HP. That would seem to actually work out to about 43 % of the 280 advertised on the Gen 2. I'd certainly be happy with 120 on top of 280 if I were content with six pounds of boost. In fact, I believe that's just about perfect for daily driving. Once again we look to be in excellent agreement! Our major difference is that I will be using my car not only on the street but in a national racing venue. I'll try to set the blown record without the turbos---using just CH3OH and N2O---and then add the turbos to see how much difference I can achieve.![]()
Ken your figures are a little off. You have to compare rwhp to rwhp. Not fwhp to rwhp. 240rwhp is about what an average LS is at with CAI and tune. Some see more and some see less so we will average it to 240 for this purpose. So 120 / 240 = .5 That indicates a 50% increase in power which is an appreciable difference from 35%-40%. No worries.
Yep Ken I will be happy with 360-375rwhp out of the LS just on the turbo and maybe shooting for 400rwhp for track days on meth if I do that. That is as far as I plan to go unless I really come into some money to justify rebuilding the bottom end of the engine and the transmission. By the sounds of your plans it seems as if you plan to be king of the hill once it is all said and done. That's good with me, I have my other "king of the hill" vehicle which puts TurboLS to shame. While we are talking about personal vehicles, here within 3 years I feel a Corvette front mount custom TT build coming on.
What is Ben's Place?
hello to everyone . ILLS great work by the way i hope you round here. i was curious in some things about this turbo charge ls. first of all id like to ask you how much did you spent doing this? and what parts did you use to make it because we all know there is no turbo kit for this car and also las and more important question is it worth doing all this job? id say horsepower gain with about 8lbs i dont want to push my engine. appreciate your help
Thanks. Sorry, I do not release detailed parts breakdowns of the system except to customers. You can get an idea of some of the parts I used from my signature line though.
It is definitely worth it if you want a fairly fast LS.
I expect around 360rwhp from about 6 or 7 psi boost. I believe running 8 psi to just not be safe enough to run in a daily driven LS.
what do you mean by when you say only to customers? also how much would it cost me? i mean if you sell a turbo kit i will buy it from you somebody i can trsut
pretty sure he not just "selling a turbo kit" mach up, fabrication, tuning and intercooler could take weeks.. you'd most likely have to frieght the car to him.. i'm not speaking on his behalf, but i would imagine.. as for price, expect a large down payment, and a larger install fee.. but its worth every penny if you were to ask me![]()
What a nice brother.![]()
