Here ya go.Sorry to sound redundent but I see a lot of people saying that they have or will order the Visteon coils. Which sounds great, but I have yet to find a post where someone actually lists where to buy the coil.
Is it just ebay or is there some real website I can order from.
thanks
Can you use the K&N? Or are you using it dry. I was informed awhile ago that the wet filters mess up the MAS so shouldn't be used. Just curious. Thanks
Thanks for the link.
He wanted something other than eBay, so I found Amazon, lol. 3 posts above yours.Did you miss the first post?
It has the link right there. Or simply search visteon coils in ebay. Seller is AlanisDeals.
Should there be an issue with using one Visteon and the rest being motorcraft/oem? I have a bad coil in cylinder 4 but most the others have already been replaced.
Can someone explain what the differance is with the following numbers ?
DG508, DG515 & DG529
meanwhile, I'm having my buddy check to see if we can get them locally here.
... that link to the eBay seller, when I put in the year, make & model, it says those are not compatible with my car.
2001 LS V8,
Any idea anyone ?
@ jmtiseo,
Thanks, I won't worry so much about the revision then,
would be nice to have the latest revision but like you said, those will go in time as well.
There is a reasoning for the revision upgrades but if they all work, a part is a part.
